LA130 John Deere Riding Mower
/ LA130 John Deere Riding Mower #1
brin
Super Member
Georgia - Mt. Vernon by The Store just 5 miles eas
I searched on TBN for any previous threads re: a LA130 John Deere Riding Mower and could not find anything..
I have a chance to buy one for $650 ..22 HP with 48 inch. cutting deck, seller says it is in good shape but I have not seen it yet....does anyone have any experience with this model...Thanks...
/ LA130 John Deere Riding Mower #2
How many hours are on it? Remember these lawn tractors are almost throw aways any more. I don't know what differences there are between the LA130 and the L130; but I call mine the L(emon)130.
The biggest gripes I have with mine is it's prone to throwing mower belts and puking electric PTO clutches. My clutch puked at 56-hours and cost ~$150 to replace if you do it yourself. I also had to borrow an impact wrench to break loose the clutch bolt from the motor's crankshaft.
Picasa Web Albums - Matt - John Deere L1...#
Thanks for that information...I had Googled the LA130 and found many complaints about the belt throwing and a few about the clutch as well and I wanted to post on here to validate that information and now you have...so I will pass on the tractor...Thanks for your help !!
/ LA130 John Deere Riding Mower #4
Id say thats a good price, I picked up a similiar one for around 700 a year ago
/ LA130 John Deere Riding Mower #5
The L130 is a 2005 series tractor with a Kohler engine. The LA130 is a 2007 series tractor with a Briggs and Stratton engine. I own a LA145 that is a 2008 model and have not had a single problem with belts being thrown nor any problem with the electric PTO clutch at 70 hours. I have had to replace one idler pulley on the deck and expect that idler to be a continuing problem since it is the first pulley off the electric PTO and takes one heck of a stress when the PTO is engaged. On the bright side, the idler is less than $9 and very easy to replace. At $650, you are getting the LA130 at around 1/3 of the new price. That's a pretty good price and a good mower for just cutting grass and pulling a fertilizer spreader. I expect mine to hold up for many more years with only an annual oil/filter change and chassis lube every 25 hours. I do try to lube my deck spindles every 8 hours, but the zerks are on the top of the deck and easy to get to.
/ LA130 John Deere Riding Mower #6
Not sure about this model, but we found on our GT275 that the thottle need to be 75%+ to engage the mower or it fries the clutch...Once I figured this out, (and replaced one) the same PTO clutch has been in there for 15 years...The idle pulleys are a 4 year replace item on JD lawn tractors.
/ LA130 John Deere Riding Mower #7
I have a LA140 and it does what I ask of it. Even had to use it to push my Chevelle into the garage one day. It cried but it did it ;)
/ LA130 John Deere Riding Mower #8
I have an L130 and yep it throws the deck belt pretty easy. It's easy to get back on though so i never thought much about it. The only other problem I've had was a bearing siezed on a deck pulley. Again it was a pretty easy fix, just put a new one on. Bearing was sealed so I had to put on a new pulley. If I could get one for 650 or so, low hours, I'd probably jump on it.
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
VERMEER S725TX STAND ON SKID STEER (A62129)
VERMEER S725TX...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lift (A61568)
2010 Ari Hetra...
8' DISC HARROW (A60430)
8' DISC HARROW...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61569)
2017 Load Trail...
