Tractor Cab built from PVC
/ Tractor Cab built from PVC
Murph - it was simple and kinda fun. I especially liked that there is no permanent change to the machine. Thanks for the nice feedback - good luck if you or anyone else is going to take a crack at it. I am sure mine will look the prototype that it is.
/ Tractor Cab built from PVC #22
Very nicely done. I've seen others here used copper, but I like the pvc for several reasons. It looks reasonably strudy too, but I'm wondering if you could more firmly anchor it to the top of the ROPS, if it wouldn't be rock-solid. In-fact I was wondering if instead of tie-wrapping to the ROPs, did you consider attaching at least the plywood with something a litte more substantial? How about one of these ideas.
- Extend the plywood a bit closer to the ROPs and tie wrap it up tight though several holes place in the plywook immediately adjacent to the ROPS.
- Extend the plywood on top of the ROPS and drill and tap a couple of small (such as 1/4"-20) holes through the plywood and into the top of the ROPS.
- Drill and tap ROPS on top and extent some sort of metal plate or tabs onto the top of the ROPS
- Build some sort of metal clamp that would go around ROPS (similar to how the ROPS attaches to the axle) and bolt it to the plywood, again extended slightly closer to the ROPS.
Anyway, you did a really nice job. One thing I was wondering though was how did you attached the plastic to the pipes, is it one the inside of the pipes (appears to be) and did you try to use one continuous piece as much as possible other than at the door?
/ Tractor Cab built from PVC #23
.......those type of nuts that bite into the plywood from the back - what do they call them?
T-nuts.
Also, I painted the PVC direct vent piping fr my furnace w regular latex house paint. You can't scratch it w your fingernail. I was surprised, as I usually swear by proper surface prep and proper paint.
Dan and DJ,
T-nut. That's it. Those will work great. Concerning the suggestions about rigidity - it seems to be very stable with the tie straps. The most vulnerable side is the side opposite of the door. Technically I should put one more piece of 1 1/2" going horizontal about half way down such that the clear sheeting will not act like a sail (although I have had no problems yet even with moderate winds).
The rigid 3/16" clear plastic is on the inside while the clear sheating is on the outside. Not sure why I went on the inside with the rigid plastic...I think it had to do with the fact that screws would be inside leaving a cleaner look. In any case I tried holding it up both ways and went for the inside. For the clear sheet - it seemed better from the outside as winds would compress it against the PVC vs. pushing it away...make sense??
Opinion - the PVC seems stronger than copper in this case...unless you went with really big stuff. I suppose one could fill up the PVC with something if you wanted to be more rigid - foam stuff or something. I filled a 4" pipe with concrete one time using a funnel. It made the basketball support pole solid...literally like a rock.
By the way - I would never drill the ROPS...even with a small bit. Alteration of a safety device would not be recommended due to potential legal technicalities in case of an accident.
/ Tractor Cab built from PVC #25
So, is there any benefit to having the rigid plastic on the inside (vs not having the rigid plastic there)? I am thinking of making a cab for our B7510 similar to yours but with a Golf Cart roof as the top of the cab (I have one available). It would mainly be something to keep the wind off. If I can direct some of the air that comes past the radiator and engine into the cab to warm it up some that would be a bonus.
Aaron Z
The rigid plastic is just easier to look through than the clear plastic sheeting...because it is stable and flat where the plastic sheeting may change shape from one area to the next. Either way - the sheeting will work if all you are trying to do is keep the wind off. Frankly, this project is so easy that if you have the money and time you might as well build it up in a similar manner.
Concerning the heat - my muffler is on the side of the tractor so I would not want to bring that heat into the cab unless I wanted to go to sleep permanently. :) Best bet for me for heat would be a small heat exchanger with a fan and thermostat from an old car. They are about $50-$100 on ebay.
/ Tractor Cab built from PVC #27
So, what order do you have the plastic layers in?
Is it something like this:
Or does the flexible plastic not go over the windshield?
On this tractor the exhaust is on the front, so if need be, I could bring in air from next to the engine, but CO2 would be an issue... have to think about that one. Perhaps I will skip heat for now and do it if needed later on.
Thanks
Aaron Z
/ Tractor Cab built from PVC #28
I like it ! Simple,cheap,fast,removable,easy to alter,Best in all worlds
I'm sure some of the purest s wont like it but all it has to is work.
I'm in the process of putting a golf cart top on my L3400. I may steal some of your ideas.
/ Tractor Cab built from PVC #29
Here are the answers to the questions:
8) You can bend the PVC without burning its surface - I was just in too much of a hurry and using my salamander style heater. Stay away from the fumes and have adequate ventilation. After bending to shape I took the pipe outside of the garage where it immediately hardened.
CD I know you said you just heat the pvc with your salamander to bend it but everyone should know that burning pvc gives off extremely toxic gases. I don't know how hot you can heat it to before it starts outgassing bad stuff.
ACZ,
Take a look at this. No, the clear flexible stuff does not go over the windshied. See my attachment.
CTGoldwing,
Good point.
PVC emits toxic fumes even when warmed. It is especially dangerous when heated to a state where it synges or worse yet...burns. Trick is to have real good ventilation and don't breath it in.
/ Tractor Cab built from PVC #32
Aczlan, just a small heater core from a car and a few hoses would do your heat since you have a liquid cool engine.
/ Tractor Cab built from PVC #33
hey would wraping the fexable stuff around the pvc and then fastening it with screws thru the plexiglass work:rolleyes: i guess the plexi would need to be inside that way.
I have thought of wrapping the plastic around a small piece of something flat...then screwing that to the pvc.
/ Tractor Cab built from PVC #35
Well CDCOLE I like it for same reason as you, keeps snow out of your face, cost a lot less that anything you can buy. Plus who needs it in the summer, just lift it off, and store for summer.:cool:
No lack of imagination in your family.:D
/ Tractor Cab built from PVC #36
Then I would have to do something to get it out of the way in the summer... It will be something to weigh in my mind when planning
ACZ,
Take a look at this. No, the clear flexible stuff does not go over the windshield. See my attachment.
Got it. Thanks for clarifying that.
Aaron Z
Check this out - now my friend down the street built one for his Kubota!!!
/ Tractor Cab built from PVC #38
hey CD, Nice low cost innovation.
After battling our east coast blizzards this winter I can understand, anything to cut the wind chill and snow in the face.
For ultra-low-cost, (and basic survival) I resorted to a piece clear plastic, cut arm holes and a head hole. it covered the seat and controls like a big poncho. I still had a face full of wind and snow (not fun), but it kept the snow from piling up on my back and thighs and melting, basically soaking me through. It also kept the wind off of my legs and body, that was a help too.
i can't imagine how much nicer it must be to be fully enclosed! :thumbsup:
Your design has me thinking.....maybe the next step is to use EMT tubing and a tubing bender? .... it's got me thinking.
Well - 3 of my friends have now built one or are planning to. The Kubota one is nice and big inside - not cramped at all and is capable in terms of allowing all controls to easily be accessed. He is putting a beacon on too.
2025 Wolverine PFF1-13-45W Pallet Fork Frame and Hitch Skid Steer Attachment (A60353)
2025 Wolverine...
2025 SDLANCH IRET13 Electric Tricycle (A60352)
2025 SDLANCH...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A61567)
2025 BS43 44in...
UNUSED KJ 25'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 25'X12'...
AirCo Radiograph Track Burner (A60353)
AirCo Radiograph...
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR4AJ276527 (A61165)
2010 International...
