Cooling welded connection
/ Cooling welded connection #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
This is just a question I have. I seen some people to cool down welded piece by dumping it in water to be able to work on it sooner.
I always feel it should cool down on it's own.
What do you think?
/ Cooling welded connection #2
i have never used water to cool welds, maybe after burning I would drop it or run it under water
/ Cooling welded connection #3
It depends on the situation and what you are trying to make. For most projects the ability to continue working and ability to handle cool pieces far outweigh the thermal shock to the steel.
That said, sometimes when working on something critical or difficult to weld especially something where thermal shock and various contraction properties will cause problems (cast pieces in particular come to mind) then I will look for different cooling methods, maybe allowing the piece to cool at room temp, maybe burying in my sand box, or maybe wrapping it in a thermal blanket.
/ Cooling welded connection #4
For most applications, I don't think it makes a difference. We aren't welding containment vessels for a nuclear reactor or pipe fittings for the sewer output from a truck stop bathroom.
I use water or snow for the smaller pieces, and for big projects like the plow I'm making now, I just don't bother. Compressed air will also work.
I'm applying this to simple metal/metal attachment, not working with forgings or other large chunks of material.
/ Cooling welded connection #5
When needed, I don't even hesitate to grab the hose.
"Were not building watches here"
/ Cooling welded connection #6
Extreme differential cooling can crack, or strain the metal and make later cracking more likely. It is more of an issue when thick and thin are joined. When I need it quick I use a spray directed to favor cooling as uniform as possible down to a reasonable temp - then dunk to cool to touch.
larry
/ Cooling welded connection #7
I seldom use water to cool a piece down. Sometimes I will just set it down on the floor and let the cool concrete pull the heat out of it, or just go get a beer. I am rarely in that big of a rush. I weld stuff not to break. Rushing the process may lower my chances of being successful!
/ Cooling welded connection #8
Another option is to limit heat input to the work in the first place. If you can do downhand welding and it'll work for your situation, things won't get as warm as they would if you were to weld uphill.
Having a piece that's too hot to work on sounds like a good excuse to go have a coffee. :)
/ Cooling welded connection #9
I used to do that, until I had a piece break just after the weld. I also noticed, that if I tried to drill a piece which had been dunked - it didn't drill very nice :)
No more quick cooling for me.
/ Cooling welded connection #10
It just came back to me: Once a coworker was doing a weld repair on an excavator stick and the owner arrived as he was finishing. The owner asked if it was done, and my friend said he could use the machine as soon as it cooled off. A minute later, when everybody's back was turned, the owner took the shop water bucket and threw it on the still-hot repair! He was informed that there would be no warranty on that particular job.
/ Cooling welded connection #12
Never, not for me. I just don't like what flash cooling does to metals.
David from jax
/ Cooling welded connection #13
Pouring cold water on a hot weld will almost guarantee the weld to fail.
/ Cooling welded connection #16
So your saying every hot weld you hit with water fails ?
Are these 'your' welds ?
/ Cooling welded connection #18
I do and have hit many of my new, hot welds with water.
None have failed and no parent material near the weld has failed.
Were building 'farm implements' here.
/ Cooling welded connection #20
I don't think it's a great idea to quench a red hot weld/steel with cold water. I don't know the facts, but stands to reason that going from opposite ends of the temp spectrum like that would cause great stress to the material, especially if it's for a critical application.
If I need to speed up the handling time, I'll blow compressed air over it, or if outside use a hand held leaf blower, that moves alot of air around the work area.
JB.
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59912)
2019 WABASH...
2022 EZ-GO ELITE...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
generator trailer (A61569)
generator trailer...
