Cooling welded connection
/ Cooling welded connection #22
Just what in this forum fits in that category ?
I suspect that some people are talking about quenching red hot metal and others black hot. There is a lot of difference in how this affects.
/ Cooling welded connection #23
Anything that if it comes undone someone could get hurt.
And many FARM IMPLIMENTS do fit that category for sure, IMO
JB.
/ Cooling welded connection #24
Agreed, and that's alot of my point.
By the time you get ground disconnected and the piece brought to water, 'red/orange' is gone.
Remember, we're talking 'backyard/garage' stuff here.
/ Cooling welded connection #25
I was gonna say I've never done it in all the years I've been welding, but I must have cause I know exactly what it sounds like.
That sound kinda tells you it's not real happy :(
Just cause somethings made/repaired in a back yard or garage, doesn't make it less critical.
JB.
/ Cooling welded connection #26
You have been lucky.
Rapidly cooling a weld is a bad idea
it causes differential stress in the metal in the weld and the surrounding metal
in the HEZ =Heat Effected Zone
Some metal will become hard a become like glass ...snap...that's a bad thing
Some metals like cast iron need pre and post heat treatment so it expands and contracts evenly otherwise it will distort or i have had it crack while it was just air cooling but it all depends on the base metal you are working with
As a rule of thumb don't do it ;)
/ Cooling welded connection #27
Cast iron is not even a question. Don't do it. Welding cast the metal should be uniformly preheated first, then allowed to cool S L O W L Y. Many people will keep hitting it with a torch to slow the cool, or bury it in hot sand. mild steel is more forgiving of quenching but cast iron is NOT friendly to quick cooling.
/ Cooling welded connection #28
Cast iron is a different beast altogether. Rare is a welder these days that knows how to braise or NiRod cast iron. Cast iron is becoming a thing of the past.
/ Cooling welded connection #29
My last post on this one, and disregard if your working for NASA or 3RR.
If your welding old bed frame together or repairing a 3pt implement or equivalent and it's too hot to handle after welding, don't worry about blasting it with the hose.
It won't change a thing.
/ Cooling welded connection #32
Well I just have to throw my $.02 in here also. Having welded a substantial amount of pressure piping and taken numerous pipe welding test where the test straps(2" wide sections cut from the welder test coupon) were dropped directly into a bucket of water and then bent into a 180 after cooling to room temperature, I have never had a failure of the weld. Quenching like dumping into a bucket of water does not make mild steel welds subject to brittle fracture. I have actually seen fellow welders straps break when he slow cooled them when mine bent perfectly. I dont know if it was the welding or what, be both looked visually the same and same rods, same everything else except the quenching. Tempering where you dunk them and take them out several times will make them harder and possibly break rather than bend.
Cast iron needs a postweld heat treatment to relieve the internal stresses. When I welded them, I would use a rosebud to bring the whole piece up to about 1000 F and then wrap it in insulation till it was cool. Cast steel, I just let air cool.
So I would say that if your weld is sound and no trapped slag, porosity cold lap or lack of fusion between passes, etc. no matter what you did to cool it, it will most likely hold. A bad weld is likely to break regardless of cooling technique used.
/ Cooling welded connection #33
I never do it unless it is an ornament or something equally useless (ie."non-critical") Quenching only serves to make a locally tempered area around the weld and within the weld itself and this can be very brittle.
As far as cherry or black heat....I sometimes temper knife blades with just the residual heat from the anvil.
/ Cooling welded connection #34
I don't know too terribly much about metals, but I would have to agree with Gary. The low carbon content in mild-steel will not have the ill effects from quenching like a high-carbon steel such as cast iron, or knife blades. I have had coupons cut from weld tests using .045 flux-core wire welding, and have always quenched them between weld passes. As long as you have all of the slag cleaned out, and no porosity you shouldn't have any issues (given the assumption that you have a good weld to start with :) )
/ Cooling welded connection #35
I am not as good of a welder as a lot of folks on this forum, but I did work for 15 years in a plant that made hi tensile steel wire/cable. For 5 of those years, one of my jobs was to test a weld from every operator on shift, every day. Since we had the machine to do it, one of the local testing labs would bring their weld test samples in for us to test. I have watched a lot of guys cooling welds in different ways, but one thing was for sure. Cool the weld too fast and it is going to break prematurely. Maybe not behind a 12 to 30 hp tractor, but it will break sooner than it would have if proper procedures had been followed.
Why would you want to take the chance that it "MIGHT" break if you cool it too rapidly? Are any of us in so big a hurry that we can't do the job correctly?
The best way to test a weld is to run it thru a wire drawing machine. If it isn't done right, I guaruntee it will break when it is being stretched to 30% of it's original size by being pulled thru a tapered die.
David from jax
/ Cooling welded connection #36
I've never had a problem arise by doing that, but the truth is that like many people who build things with steel for their own use, I know that the steel/weld will never be "put to the test" in terms of ultimate strength.
If I were welding for someone else (and I have), or working with high carbon/high yield steel, then I would never cool welds or flame cut pieces in water.
/ Cooling welded connection #37
As a rank beginner backyard welder, I often use a handsprayer to cool my welds. This appears to be a compromise between no cooling and drown in a water bucket. No sudden temperature changes just quicker cooling.
Weedpharma
/ Cooling welded connection #38
I'm not an expert welder, and I don't play one on TV. But, 50 years ago a blacksmith taught me to quench cherry red steel in a bucket of water to "take all the temper out." Then you start the process of putting the temper back in the steel by heating in the forge and cooling slowly. Carbon content has big impact on how quenching will affect the molecular structure.
Brittleness is not the only bad thing that can come from quenching. If cooled too rapidly, the weld can develop internal stresses that will cause it to rust more rapidly than the surrounding area. If you stretch a barbed wire fence too tightly, it will rust much faster than the wire stretched straight, but with no tension.
/ Cooling welded connection #39
That would make the inside soft but the outside would now be hard, but that depends on how long it is submerged. A quick dip wouldn't be bad because the internal heat would migrate outward.
Rapid cooling does not anneal.
/ Cooling welded connection #40
already said, most projects are not that critical. slow cooling should be allowed for high stress and load points.
example: underwater welding is very limited these days, reason is the weld puddle quenches rapidly causing the weld joint to loose its ductility. another factor is hydrogen contamination which multiplys problems. habitat welding is the prefered method, wet welds are temp patches.
sure i do it, but it does reduce weld quality. components subject to vibration also should cool on their own.
had to add two cents
2014 Jeep Patriot SUV (A64557)
2014 Jeep Patriot...
KIVEL TRAILER MOVER ATTACHMENT (A64553)
KIVEL TRAILER...
2019 CATERPILLAR 239D SKID STEER (A65053)
2019 CATERPILLAR...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2014 Kenworth T370 21ft. Flatbed Truck (A64194)
2014 Kenworth T370...
