Zerks that refuse grease!
/ Zerks that refuse grease! #1
Coyote machine
Super Member
Southern VT
22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
My relatively new tractor, 150+ hours seems to have some zerk fittings that refuse to take on grease. When the nozzle is applied the grease squirts out between the zerk and the nozzle and does not go into the fitting. Have tried several different grease guns, lever and pistol grip handles, and one hand holding the nozzle on the zerk and any other way I can think of. In one case I unscrewed the zerk and attached the gun hose directly to the port and had some better success, but when I removed the gun's hose from the hole the pressure in the fitting wanted to return the grease to my shop floor.:mad:
Am I missing something?
I know TSC has a fitting that is designed to blow out zerks that don't work or joints that are filled with hardened grease with a penetrating oil or something similar- would this be advised?Grease Joint Rejuvenator - 3950995 | Tractor Supply Company
Any comments, suggestions, solutions would be appreciated.:)
/ Zerks that refuse grease! #2
When that happens to me, I swap in a new zerk. They are about a buck a piece. I degrease the old one with some engine cleaner and put it back in the box for next time I have a problem.
/ Zerks that refuse grease! #3
A new zerk would be my first attack of the problem. If that doesn't work, or you know that the joint is packed with hardened dirt/grease, then taking the joint apart and cleaning it is the second line of attack.
/ Zerks that refuse grease! #4
That happened to me on a brand new MMM. I tried every trick just like Coyote did but never did get the grease into one of the leveler zerks. So I mowed all summer with out fixing it. With the mower off now, I'll fix it...just haven't got to it yet.:eek:
/ Zerks that refuse grease! #5
Often heating the zerk with a plumbers torch will free it up.
Also a light tap perfectly centered to pop the tiny spring loaded ball valve back is all that is neded.
/ Zerks that refuse grease! #6
I take the zerk out- remove the pin from the tractor- clean the pin and remove any debris from the zerk and from the zerk hole- reinstall and I know everything is good to take grease- if this still fails- replace the zerk
/ Zerks that refuse grease! #7
I use one of those rejuvenators. They work well. I also read about loading a second grease gun with an oil and using that to blow out the zerk. Plan on trying that this summer. The loader has a lot of fittings as does my zero turn mower. It would be nice to "clean" them all out at once and shoot in some fresh grease.
/ Zerks that refuse grease! #8
Some times if you change the load direction on the pin it will go in I usually try that first the pull the zerk put it on the gun and see if it passes grease if it does
I ream out the hole in pin if I can.
then use cleaner to clean passage if that strikes out i pull the pin
tom
/ Zerks that refuse grease! #9
I carry a 16d nail with me when I grease. The nail lets me force a rag or paper towel into a recess around a zerk to clean it, and if the zerk is stuck and won't accept grease, I can push hard with the point of the nail on the little ball in the zerk, which has never failed to free it up.
/ Zerks that refuse grease! #10
Bingo! This has never failed with hundreds of zerks over the decades. Now I almost always just change the zerk while I'm at it if there has been a problem with it. When bought in bulk, replacements are about a quarter. At that price they aren't worth my time to fool with.
/ Zerks that refuse grease! #11
I agree, and I also find many time that its not the fitting thats crudded up but just past that point where it meets the pin. I don't remove the pin all the way drive it out till the Zerk hole is free and clear it out drive the pin back in and away ya go.
/ Zerks that refuse grease! #12
Well, Bingo, I tried that and it still didn't take the grease. Even though the MMMwas brand new, the joint must be frozen some way. So this spring I'll take it apart or soak it in penetrating oil then try to grease it.
/ Zerks that refuse grease! #13
If you changed the zerk cleaned out any possible obstruction behind the zerk and removed any other possible obstruction, you have issues that nobody here can assist you with. What was described leaves nothing but a grease gun problem. However, if your last two statements are true, you didn't do what I quoted another poster recommending. Bingo! ;)
/ Zerks that refuse grease! #14
Have you adjusted the grease gun tip to hold on to the zerk fitting. That might be your problem The tip is a two part mechanism that can be loosened up or tightened down to adjust to zerk fitting diameter. Your tip may be tightened too much to allow it to snap over the zerk. Also if you get it too tight, you also will have trouble pulling it off the zerk.
Check that and see if it helps. The tip should snap on to the zerk and hold itself on. If it doesnt, then it needs some adjustment.
/ Zerks that refuse grease! #15
Did you remove the pin??
/ Zerks that refuse grease! #16
Heat from a hand torch has always worked for me.
/ Zerks that refuse grease! #17
with my new loader (m8540 but could apply to all K loaders) i had similar problems with about 6 zerks. I noticed that the heads were different (shorter) than others on the chasis and were not fully mating with the gr gun head....replaced them from dealership (metric) and they worked fine....I think your problem could be related. bb
/ Zerks that refuse grease! #18
When I was a kid, heating the zerk always seemed to work. Then I began to notice a few years later (different zerks) that the grease would often extrude back out through the zerk after greasing. So I use the method of removing the zerk and try passing grease only through the zerk to see if it is blocked.
Conclusion: There was a period when the metal balls in zerks were replaced with plastic. I hope that is a thing of the past, and has not continued to the present day.
/ Zerks that refuse grease! #19
My old IH 18 ft disc seems to have about 50 fittings on it. The grease rejuvenator works on about 90% of them. It forces diesel fuel into the fitting to clean it out and then you fill with clean grease.
Thanks all for your great suggestions, replies, etc.:D
It turns out I may have multiple problems you have described. I did take apart the nozzle end and adjust it to latch on better than it had, but the problem with grease squirting out between the zerk and the nozzle end still occurs. I have removed the zerks in question and made sure they can pass grease and that the hole into which they screw is not otherwise obstructed. I am seriously thinking of getting a zerk rejuvenator but it is expensive- nearly $50!:eek:
Anyone know where to buy one for more reasonable $ ?
Does anyone have a copy of the directions for a rejuvenator- I can't seem to find any online so as to determine how it works or if I want to buy it.
Also I don't understand how an essentially brand new machine ends up with zerks that won't deliver grease- I can see why if it was an old machine with lots of hours on it - but new from the factory?!:confused:
And the fittings I am trying to grease are not disassemble- able like a pin in a loader arm. The one in question is the big knuckle between the two tie rod arms that go out to the wheels. Mine is a big joint that has a bolt and lock nut in the front of the assembly and I cannot see any grease pushing out at where it mates with the front axle. And the tie rod ends where they attach to this big knuckle area do have a pivot pin of some kind that they rotate on, but I can only get grease to push out between the knuckle and the bottom of the plate it attaches to, not at the top of the knuckle. So when I lift up and down on the 'ball like' joint (the same kind as on the ends of 3ph arms), I can still hear a metal to metal clunk. I don't know if this is 'normal' for grease to only squeeze out from the bottom of the joint. Should I just brush grease on with a paintbrush at the top of the joint top keep it from clunking?
Thanks again to all who replied.
Caterpillar 980F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 980F...
2022 JOHN DEERE 26G EXCAVATOR (A64279)
2022 JOHN DEERE...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
PALLET OF ROW MARKER PARTS AND HOOD (A63291)
PALLET OF ROW...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
