Zerks that refuse grease!
/ Zerks that refuse grease! #41
I use several methods of getting a zerk to take. The main thing to to grease regulary or if your gonna put an implement up for a few weeks give it a fresh greasing. In the winter our scraper doesnt get alot of use. After about a month it gets hard if it was run and put up. On my excavator sideshift I have to offset the boo mand put a little dwn pressure on it. One trick to make a stubborn fitting take grease is to put a thick paper towel like a blue one on the nipple of the fitting then push the gun nozzle onto it. It really seals it off. I have a grease gun at work that I Have a small amount of grease in the bottom and I fill it the rest of the way up with hydraulic oil or motor oil and fuel mix. the articulation joint on the compactor at work is bad to jam up. I hook up the grease gun and use the towel trick on the nozzle and then holding the gun upside down I pump it. I use a long handle gun because it will build up a large amount of pressure and then you have to bear down on it. On the compactors joint you will hear a pop and then see the oil trickle out. Then its goog to go. I have also filled the gun up with Blaster for faster results.
/ Zerks that refuse grease! #42
Here's what it took to fix the self balancing shaft on my BX2660 MMM. In about 2-3 hrs I pounded the pivot pin out...took the entire joint apart. The zerk was fine...the pin was too tight. The bushing inner lining looked rough but had a slot where the grease enters. I sanded the pivot pin and its mating bushing...cleaned these brand new parts all up and reassembled. Now it will take some grease with a lot of force..but reluctantly. As far as I'm concerned, this was a factory defect.
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2011 Ford F350 Service Truck (A63116)
2011 Ford F350...
Electric Tricycle (A64194)
Electric Tricycle...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
