Chains Part # for 2320 Tire chains
/ Part # for 2320 Tire chains #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
anyone have the part number for 2320 tire chains for the R-4's?
the tire size is 31x12-16.5
I have not been able to find any tire chains that specific size and dont know how to cross that to another size.
thanks
brian
/ Part # for 2320 Tire chains #3
I have a 2320 w/r4s and when I ordered chains from Tire Chains by TireChains.com the numbers they needed were 12-16.5 hope this helps.
Tim.
For my 2320 with R4's I just called the people at TireChains.com, told them the tractor and tire size and discussed why I needed them, I was good to go. Good people to deal with.
/ Part # for 2320 Tire chains #4
This is one of the few sizes Deere does not offer a tire chain for. I do not know why other than this is the same size tire a med frame skid steer.
thanks for the feedback.. I was trying to match the all digits in the tire size, but I did find the 12-16.5 chains..
WOW... those are some expensive chains.. expecially when I only need them for a few neighbors driveways (so far with no more snow than we get) and I dont charge the neighbors.. :-/
Under 'car chains' in the drop down menu they have a 12-16.5 (there is one for 'tractors' as well).. Does anyone know if the cable chains listed would work on the tractor ?
thanks
brian
/ Part # for 2320 Tire chains #6
Here's a link for you.
12-16.5 Tractor Tire Chain
Tim.
Edit: When I first read your post I thought you said( "is there one for tractors as well") guess you already found that page.
/ Part # for 2320 Tire chains #7
Here's a couple of pics of what they look like on my 2320.These are the Duo-ladder combos.If you have to drive over any asphalt you definitely know you have chains on! Rough ride.I don't think those cable chains would work very well,I think they would work there way in between the lugs?
Tim
/ Part # for 2320 Tire chains #8
t man,
I should have gotten those.
IMG_0263_1.jpgHorse manure, don't ya know!
/ Part # for 2320 Tire chains #10
Gizmo wow! Talk about working there way in between the lugs.If there was ever a competition for that you would win for sure.:p
Tim
Yup, that made me feel real good.:D As I live and learn!
<deleted text> I don't think those cable chains would work very well,I think they would work there way in between the lugs?
Tim
I have seen some cable chains that the cross links run diagonally (vs straight) across the tires.. I thought that may help keep the cross links from slipping into the lugs..
Brian
/ Part # for 2320 Tire chains #12
Brian[/QUOTE
Possibly they would work?
Maybe someone who has used them will chime in.
Good luck. Tim.
We got another 'significant' snow coming this weekend, so we will see how it goes this time.. I was hoping to only spend about $70 or so for them, not the hundreds it appears they will cost
brian
/ Part # for 2320 Tire chains #14
hi:
Has anybody tried to use steel cable in middle of chains to stop them from getting into lugs? Or maybe a link or 2 apart and making a long skiny U shape with cable.
2021 BROWN & HUBERT 10' SPOOL TRAILER (A63276)
2021 BROWN &...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A67147)
2005 KENWORTH T800...
2023 KOMATSU D51EX-24 CRAWLER DOZER (A65053)
2023 KOMATSU...
2022 EZ-GO ELITE...
LiuGong 9027FZTS Mini Excavator (A64553)
LiuGong 9027FZTS...
