FEL/ Hooks
   / FEL/ Hooks #21
I might add that it's never a good idea to mount hooks on your bucket outside your lift arms if you like your FEL. Your outer hooks should be in line with your lift arms. Otherwise, you're just begging for twisted loader arms. I think I've cut off and re-located a dozen now for guys with twisted loaders.
   / FEL/ Hooks #22
LOL, I gotta ask, do you have to turn your hat sideways, wear grills on your teeth and have your pants on the ground to drive that forklift? :D
   / FEL/ Hooks #23
The greater threat IMO is flipping the machine on it's side, if some one were foolish enough to use just one hook. Ever catch just the corner of your buckets cutting edge on something and try and lift, especially if your a little lite in the rear, you will end up heavy in the old shorts :eek: as you feel the whole machine trying to go over.
That's why I like the center mount receiver set up, Don't want to have to fool around with 2 chains.
JB.
   / FEL/ Hooks #24
You can't mount a hitch in the middle of a HD bucket that also works on a skid steer. On smaller buckets I've mounted a hitch receiver in the middle of the bucket for moving trailers. With the hooks mounted in line with the loader arms I've never had a problem just using one hook with a 100 hp tractor. Using the grade 70 hooks I get for about $7, I've never had even guys using 250 or 300 hp tractors have an issue using one hook when it's welded on in line with a loader arm. Mount one outside the loader arm and you'll not only twist your loader, but also easily flip your tractor on it's side. I just cringe every single time I see guys posting pictures of their proudly mounted hooks on the outside edge of their buckets. When they least expect it, it's gonna bite them.
   / FEL/ Hooks #25
Did you turn down the Spinners for the forklift? lol
Nice looking equipment. I'm always in awe on the cosmetics of your equipment, always clean.
   / FEL/ Hooks #26
:D Ya I thought they might put it over the edge. I'm just going to install a DVD player and a GPS and call it done. Thanks!
   / FEL/ Hooks #27
I feel that it is much safer to lift long items(16'-20') with the hooks spaced out as far as they can be. We have done this for years and have had no ill effects. Now we aren't lifting anything close to max weight and we do not lift from one corner only, the load is equally loaded on the bucket.
My guess would be that the guys that you have relocated the hooks for, forgot to use a little common sense. But then I don't know any of their circumstances either. What I do know is what works good for us, and that is having the chain hooks out on the ends of the buckets.
   / FEL/ Hooks #28
As long as like you said you always use both I don't see a problem, unless something shifted or came undone, putting all the load on one side, that could upset the applecart in a hurry.
What I don't like is that now you're forced to use both all the time, I don't like the idea of just one chain even if the hooks are in line with the cylinders like many are, seems it's still an unbalanced lift.
I'll stick to my center mount, it's so versatile :)
JB.
   / FEL/ Hooks #29
No, it's simple physics. Without any doubt whatsoever, it's never a good idea to have hooks mounted on the outer edges of a bucket; period. You exert forces for which the bucket was never designed, for which the tractor arms were never designed and you can't possibly pull from a place on a tractor that will upset it more so than the outer edges of a bucket. You can generally get by doing things with equipment and tools that they weren't designed to do for a while, but not forever. I've used a cheater bar on box wrenches before, but it's not a good idea and they were not designed for such.
If I continued to do so it's pretty well a guarantee that sooner or later something bad would happen. It's the same with trying to ignore physics and the design of a front end loader on a tractor. You can most likely get by with it for a while but, perhaps when you most need it, it's going to bite you. I'll repeat, without exception, it's never a good practice to mount hooks on the outer edge of a FEL bucket. The common sense exhibited by the many tractor and skid steer owners who have had me relocate their hooks was when they realized that they were going to either break something or get hurt with the hooks mounted where they didn't belong. Sorry man, not trying to be rude, but this is a mathematical matter that is easily explained with simple physics, it's not a guess or opinion. I sincerely hope you don't tear up any equipment or get someone hurt; absolutely no sarcasm implied or intended.
   / FEL/ Hooks #30
Paul, that fork truck belongs in a cruiser magazine or on "Pimp my Ride"!
That is one beautiful truck! I love the custom chrome stacks.
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
UNUSED FUTURE CAT 305 44" EXCAVATOR RAKE (A57193)
UNUSED FUTURE CAT...
1779 (A51248)
1779 (A51248)
2013 Audi A6 AWD Sedan (A53424)
2013 Audi A6 AWD...
2019 BOBCAT T450 SKID STEER (A52707)
2019 BOBCAT T450...
2015 Nissan Altima Sedan (A55853)
2015 Nissan Altima...
