JD hyd fluid specs
/ JD hyd fluid specs #1
cowsrus
NE Oklahoma
JD 6110, JD 5510
Had a hose come loose on my jd tractor and lost all my hyd fluid. My tractor manual calls for HY-GARD JDM 20c or JDM 20d. I've always used a universal hyd fluid and it is listed as for JD20a/b/303/ HY-GARD. Is the jdm 20c just a new jd number or is it a different fluid than the other. Confusing, but the difference in price is $25. for the universal vs $56. a 5 gal bucket for the jd fluid
/ JD hyd fluid specs #2
If me, I'd buy the Deere fluid. Small price to pay, in my opinion.
/ JD hyd fluid specs #3
Around here, even the Wally World universal is ~$50, and Costco is $45 for 5 gal.
I would be very suspicious of anything that was only $25.
/ JD hyd fluid specs #4
Usually, right beside the universal hydraulic fluid is "replaces" John Deere hydraulic fluid for the same price. That stuff should at least meat the J20C specs, which are not the same at all as J20A/B.
John Deere Hy-Gard is J20C with better antiwear and better brake chatter additives. All Deere requires is J20C, but Hy-Gard is much better than that.
I went ahead and bought the JD HY-GARD, it was $55. for 5 gal. The service manager told me the other would be ok but later on if something went wrong, i would always wonder if that was it. So anyways i'm set for now. Thanks guys
/ JD hyd fluid specs #7
JD always tries to scare people into using their fluids.
Theres some truth to that, BUT...$55.00 for good quality oil in a JD pail that is "guaranteed" to work or $55.00 for "should be ok" oil....
Yeah I know you can go buy generic branded oils of questionable quality for less, but any brand name good stuff is right in line if not more then the pail of JD stuff. Go price out Donax TD or Mobilfluid TD (or similar brands/qualities)....it was CHEAPER for me to go with the Deere stuff and sleep easy at night.
I will say that more then a few people I know all say the same thing, use OEM oil in your Deere/Kubota/CaseIH.....I've had personal experiences which prove it too...
/ JD hyd fluid specs #8
John Deere HY-GARD is a copy of IH Hy-tran. One big advantage these oils have over J20a/b/c, ISO32/ISO46 hydraulic oil, engine oil and ATF is how they deal with water. They were designed to be able to sit in an unused machine for extended periods of time and keep the components from rusting. If that sounds like you - invest the money.
ISZ
/ JD hyd fluid specs #9
ISZ
HyGuard and HyTran have completely different viscosity profiles. They are quite different oils and are not cross-compatible except to those who think "oil is oil, it all comes from a hole in the ground".
/ JD hyd fluid specs #10
You might want to tell that to IH and Deere since if you look at there spec pages they list them as being compatable. NOTE: CNH MS-1209 & MS 1210 are HyTran
Applications
Hy-Gard hydraulic/transmission oil provides the best performance and wear protection for John Deere hydraulic and transmission systems.
Recommended for equipment with either common system reservoirs or separate transmission and hydraulic systems, including those with wet brakes and wet clutches.
Service Ratings
AGCO
Massey Ferguson: M1135, M-1141,
M1139, M-1143
White: MQ-1722, Q1766, Q-1766B,
Q-1802, Q-1826
Allis-Chalmers, Deutz-Allis, AGCO Allis:
Power Fluid 821XL
CNH
Case, Case-IH: MS-1207, MS-1209,
MS-1210,
MS-1
Ford/New Holland: ESN-M2C41-B,
M2C134-D, M2C48-B, M2C48-C,
M2C159-B/C, 159B/C, M2C86-B,
FNHA-2-C-200, FNHA-2-C-201
Caterpillar: TO-2
Clark: MS68
Deutz: Hydraulic transmission fluid
Dresser: Transmission hydraulic fluid
(HMS B806-0002)
Eaton Hydraulic Division: Hydraulic transmission (Form3-401-123)
IHC: B-6
John Deere: All-weather hydraulic fluid
(JDM J21A)
Kubota: UDT hydraulic transmission fluid, Super UDT
Oliver: Type 55
Sunstrand: Hydrostatic transmission
Zetor: OT-H, GL-4
ZF: TE-ML03E, 06D, 06E
Test Analysis
Viscosity @ 40ーC................... 59 cSt
Viscosity @ 100ーC................. 9.4 cSt
Viscosity index.................. 140
Density............................. 0.89 g/cm3
Pour point......................... -40ーC
Flash point......................... 227ーC
/ JD hyd fluid specs #11
Regardless of specs, compatibility, ford vs chevy debate, etc... I have to laugh....
Here people are, spending 20k +/- on a tractor and they're looking to save 10/20 bucks on a pail of oil....Actually if you buy a GOOD oil, you're not saving a penny as they are all around the same price point. After the 100 hour break in (you dont have a choice on the oil it came with :D) and you get 400 hours on an trans oil change, how much more does it REALLY cost...
As a note...I couldnt find anywhere where HyTran Ultra meets the Deere HyGard specs...Other then various CaseIH specs, it appears to me it only meets CAT TO-2 and Allison C-3 specs...You have a link for those specs? I couldnt find it anywhere here: http://hytranman.com/hytran_specs.php
IMO if you dont have the money to put good oil in, you shouldnt have bought the tractor in the first place.
/ JD hyd fluid specs #12
Applications
Service Ratings
AGCO
M1139, M-1143
Q-1802, Q-1826
Power Fluid 821XL
CNH
MS-1210,
MS-1
Caterpillar: TO-2
Clark: MS68
(HMS B806-0002)
IHC: B-6
(JDM J21A)
Oliver: Type 55
Zetor: OT-H, GL-4
Test Analysis
I wonder what "service rating" is supposed to mean? Pretending that HyGard can be used in place of NH 200A and Kubota SUDT in applications where the advantages of a low-viscosity hydraulic oil are REQUIRED is ludicrous. Especialy whan Deere markets its own low- vis Hygard which isn't listed in the "service rating" list.
Smoke & mirrors.
/ JD hyd fluid specs #13
are REQUIRED
is ludicrous.
Smoke & mirrors.
You all should take this elsewhere. :(
"Oil, Fuel & Lubricants
The Never-Ending Discussion of Oils, Fuels and Lubricants Continues Here..."
Bob
/ JD hyd fluid specs #15
"I couldnt find anywhere where HyTran Ultra meets the Deere HyGard specs"
Do you honestly think Ford is going to recommend GM oil? Same thing. One easy way to check is to look at 3rd party oils. They will list the relevant JD, Kubota, IH, etc. spec numbers they meet so you can use them like a cross reference. Just do your due diligence and check more than one source in case one of them gets a little "creative" with their compatibility claims.
ISZ
/ JD hyd fluid specs #16
ISZ
Umm....If you go to JDParts and look up HyGard you can see ALL the specs it lists... So I can see where HyGard meets HyTran specs, but not vice versa...
Your analogy is a little off...Ford wont Reccomend GM oil, but for WILL certianly say that their Motorcraft oil meets GM specs, Dodge Specs, etc, if in fact it does... so they can sell their oil. Nowhere in my posts did I say anything about IH Reccomending JD oil or vice versa... I just said I could not find anywhere in any CIH litrature regarding HyTran where it met HyGard specs.
3rd Party oils dont decode the mystery either...some of those oils are "Jacks of all trades, master of none"....when you get into the high end oils like I mentioned, you're at the same price point if not MORE then what you'd pay for a pail of HyGard, HyTran, or UDT.
Saving $25.00 in a transmission oil change on a $30k pice of equipment is just as they say "stepping over dollars to pick up pennies"
/ JD hyd fluid specs #17
Guys I too would like to buy $25-$30 5 gal pails instead of $55+ HYGARD hyd fluid for my J D tractors and dozer, But its all about additive pkg's, mostly best anti-wear aditive AKA-- ZINC. Go to Oils and fuels for more info on who it appears blends John Deere's HYGARD Hyd oil or Email me.
/ JD hyd fluid specs #18
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
2017 Dodge Journey SUV (A61574)
2017 Dodge Journey...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
