2007 6403
/ 2007 6403 #1
abb
Fayetteville AR
JD 6403
Im taking delivery of a 2007 MFWD 6403 in a couple days and i have some basic questions about that particular model. Anyone have any trouble ot tis about it? What transmission does that model have.
/ 2007 6403
sorry, meant "have any trouble or tips about that machine"
/ 2007 6403 #3
Welcome to TBN!
You may get more responses in the "Ag tractors and machinery" heading, I would give that a try.
/ 2007 6403 #4
The 6403 has been a very reliable model. It is a no frills, "price fighter" model. It does not have all the fancy creature comforts of the more expensive 6405, 6410,and 6420, but the machine is very strong and reliable. It has a 9 speed forward three reverse speed transmission. It is synchronized on the top shaft which means gears one through 3 are synchronized as well as reverse. A,B and C ranges are not synchronized. Tractor should be stopped before Ranges are shifted. 1st, 2nd, and 3rd can be shifted on the go using the clutch.
/ 2007 6403 #5
You spent a fairly substantial amount of money for a tractor but it doesn't sound like you did much research before the purchase. The 64xx series machines are pretty big and powerful (60 plus HP).What, if I may ask, are you planning on doing with it?
/ 2007 6403
Its through a family member that cant keep it and i'm helping out either way. Ill mostly be maintaining about 600 acres with it and 1996 jd 2wd 6200. Appreciate the replys, to clarify,i need to stop when i change a, b, or c with that transmission but that i dont have to stop when changing 1,2,3. Correct? Would that be the same with the older jd 6200?
/ 2007 6403 #7
The 6403 while higher hp is has a basic transmission as jd110 mentioned, the 6200 has two transmission choices either a 12 sp or 16 sp both of which are more deluxe models. The 6200 has a lot less power but may work out best where you need more manueverability, the 6403 will work out fine for heavy tillage work. Both would be good to have on 600 acres.
/ 2007 6403
The 6200 has 16 spds. I always stop between the A,B,C,& D gears but don't when i'm switching between 1,2,3,&4 gears. Is that okay?
/ 2007 6403 #9
As long as there is no gear grinding I think it is ok to shift without stopping.
/ 2007 6403 #10
You got it. The ABCD gears are the range gears.
8' x 6' Galvinized Shed (A66408)
8' x 6' Galvinized...
QA Pallet Forks (A64127)
QA Pallet Forks...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
Pallet Racking (A65640)
Pallet Racking...
4' Fence Gate (A64127)
Case 1150G Dozer (A66285)
Case 1150G Dozer...
