Valve education?
/ Valve education? #1
dcyrilc
Super Member
Woodinville, Washington
John Deere 2240 MFWD
OK, this is for all you knowledgable folks out there who have been playing with hydraulics since before there was dirt.
I'm eventually going to be adding rear hydraulics to my 2240 tractor with CC hydraulics. I figured it was time to begin looking at valves to see what I will need.
There are A LOT of different types of valves out there. How do I decipher the different valves to know what they are and how they will work?
I realize that my valves will need to be CC, but single acting, double acting, single spool, double spool, stack, etc... what are they?
Further complicating things, how do I know the difference in spools? I have read threads on different types that respond differently for opening and closing proportions, etc.
/ Valve education? #2
You will have to learn to read and understand hydraulic valve symbols....
/ Valve education?
What are the differences between "SV valve", "20 series valve", and "cesna valve"?
I think I figured out everything except the cesna.
/ Valve education? #4
The pic I Posted is from the Prince 20-series valve spec pdf file....SV valve and cesna valve I dont know....where did you get all those terms first of all....???
Cessna is a manufacturer brand....aircraft maker that also makes hydraulic parts....
/ Valve education? #5
SV and 20 Sereies are "stack valves" from Prince...just a model number for them. Stack valves are Ala cart...you buy each piece (section) to build a valve that meets your needs.
Cessna is just a company that makes valves, it's not a "type" of valve. Husco, Dinoli, Gresen, Cross, Sauer/Danfoss are some others that are commom names.
"Spool" is just a term for how many sections or functions a valve can do. Like a loader valve has two spool's-dump/curl and lift/lower.
SA (single acting) valves are made to operate SA cylinders only-those with only one hose attached to it.
DA (double acting) valves are made to operate DA cylinders-those with two hoses attached. They can also operate a SA cylinder. 99.9% of the valves used on newer machines are DA.
Usually the description of the valve is noted when you buy it. Terms like "work ports blocked in neutral" and "spring return to center" are common and tell you how the valve operates.
Just reading through the Surplus Center website or catalog can be a great education.
/ Valve education?
Thanks kennyd.
/ Valve education?
From the Surplus Center website, under the list of valves. https://www.surpluscenter.com/item.asp?UID=2116012207371877&item=9-2594&catname=hydraulic https://www.surpluscenter.com/item.asp?UID=2116012207371877&item=9SV-1-Z&catname=hydraulic
A Cesna valve is also listed on JD Parts as one of the possible loader valves for my 145 FEL.
OK, gotta leave for work.
/ Valve education? #8
I just went through this to some extent as I am going to buy a new valve for the used loader i just added to my tractor. I am going to buy a double acting 4 spool valve with Power Beyond. I only need 2 for the loader, but while i am spending $ and installing, I thought it would be nice to have an extra port already plumbed in for my grapple I plan to add, and a 4th valve for anything else I might dream up. I will extend to the 2 loader valves handles out so I dont grab the wrong handles since i will be using those 99% of the time.
Burden Sales Surplus Center Item Detail
/ Valve education? #9
By CC, I presume you mean closed center. Is this true and do you know the difference between closed center and open center hydraulic systems?
If not where did you get the CC requirement from?
Once these questions are answered we can go on to these.
What do you want to do with this valve?
How are you going to plumb it in?
Roy
/ Valve education? #10
Roy
He has an older JD tractor, it is indeed a CC system.
/ Valve education?
Roy
Yes, my JD 2240 has Closed Center hydraulics. Open Center is Constant Flow & Closed Center is Constant Pressure usually with a variable displacement pump.
Initially, 3 valves will be for T&T with tilt control on both sides. 2 additional valves will be for future rear remotes.
The pressure line will be plumbed from the (currenly plugged) factory port on the priority valve where factory rear remotes are plumbed from. The return can be plumbed back to the filter or to the resivior or both. Factory remotes are plumbed to the filter with an optional kit allowing a split return to both the filter and resivior.
I plan to use stack valves to create the configuration I want, however this post came about when I began looking at valves and was lost in the abbreviated names of the valves. IE:SVS1GA1AA (DA CYL SERIES SPOOL SPRING CENTERED) $114.00 & SVW1BA1 (DA CYL SPOOL SPRING CENTERED) $67.00. I've yet to figure out the difference between these two valves. I guess it comes down to that I don't know what a series spool is. Both of these are listed under 1 SPOOL SV CLOSED CENTER NO RELIEF in the area for stack valves on Surplus Centers website.
I started this thread because I realized that I didn't know terminology well enough to properly understand what the valves were that I was looking at by the descriptions. I've figured out some of the abbriviations, such as SA - Single Acting, DA - Double Acting.
After realizing the short commings in my understanding of terminology, I decided to start this thread both for my own knowledge and also so that others can learn as well.
I realize that nearly all newer tractors are Open Center, so the plumbing requirements for my tractor will be different from most of what is dealt with here on TBN. I don't plan to get into exact plumbing plans here as this thread is for education of terminology rather the actually plumbing my machine.
/ Valve education? #12
  • PLUG-OPTIONS-PRINCE VALVESVInstS.pdf
/ Valve education?
/ Valve education? #14
Question.
If an SA cyl attached to this valve, Is there a good reason that Prince recommends that port A be plugged, and the cyl connected to port B?
1. Do you mean why A port is plugged at all??
2. Or do you mean why not B port is plugged and cyl connected to A port?
answer to #2....My self, I think it would make more sense to connect cyl to A port and plug B....but it is just a matter of what side of the spool that have the lands for a plugged port.
Like Prince shows on this Serie20 3 way spool.....B port is Obviously plugged on this one....see symbol....
Woops...my bad....of course A port is plugged in this one too....
/ Valve education?
answer to #2....
My self, I think it would make more sense to connect cyl to A port and plug B....but it is just a matter of what side of the spool that have the lands for a plugged port. Like Prince shows on this Serie20 3 way spool.....B port is Obviously plugged on this one....see symbol....
So is the "A" work port not blocked in neutral?
I think I just answered my own question. "One way motor valve" the "A" port is not blocked because of possible torque from the motor. If connected to the "A" port, an SA cylinder would bleed down when the valve is in neutral. Correct?
/ Valve education? #16
On the one J_J refers too , YES, on the one I show, NO, and they are two different Prince valves....I noticed this "discrepancy" a while ago.....no biggie....but a little disturbing....because it is inconsistant....I think that it is, sort of, common custom in valve industry, to have B port plugged, if it is a 3way valve for a single acting cylinder....
WOOOPPS my bad...to tired.....sorry....A port of course plugged on my picture too...
/ Valve education?
I was looking at your picture and trying to figure out why "B" and not "A". Didn't realize they were different valves.
Another example of how much I need to learn before purchasing valves and why this should be a good thread for the beginner.
/ Valve education?
answer to #2....
Can you give some explaination of the meaning of the different parts of the schematic you gave in this post. What does the symbot on the left edge mean, and what does each section from left to right mean, and lastly what is the symbol on the right?
/ Valve education? #19
Sorry dcyrilc....I messed up here A port is plugged on both J_J's valve and the valve I referred to....But I still stick with my other statements.....
I changed the picture too....Wish I could UNDO the whole thing....LOL...well good night now....
Later
Per
/ Valve education? #20
FarmerFord did a excellent job of describing series vs. parallel valves in post #7 of THIS thread. Also the link provided by Shaley is great also. The short story is though for loader and backhoe valves parallel is preferred because you are often doing more than one function at a time. You would not need that for your remote valve so save the money and go with the series.
2004 STRICK 53X102 T/A DRY VAN TRAILER (A59914)
2004 STRICK 53X102...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
ATS Mini Excavator (A66285)
ATS Mini Excavator...
ASSET DESCRIPTIONS & CONDITION (A59914)
ASSET DESCRIPTIONS...
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
2012 International DuraStar 4300 Digger (A62613)
2012 International...
