Foot Treadle
/ Foot Treadle #1
TractorGolf
Lewisberry, PA
PT 425, 154 Cub LowBoy
So far the PT 425 has been flawless.
Now there is an occasional problem with the foot treadle. The machine suddenly stops moving for no specific reason. Everything works fine except the machine won't move backward or forwards. I shut the PT down and then restart, then I'm good to go with no further problem.
Here is the question. Can the valve that controls the forward/reverse movement be failing? And, what and how is the best way to identify if there is a problem?
The last thing I need to happen is to have the machine stop dead in the middle of the driveway.
All help appreciated!
/ Foot Treadle #2
Is the tram pump operated by a cable or hyd circuit?
/ Foot Treadle
Treadle is operated by the hydraulic circuit. I'm trying to figure out if there is a valve going bad or if the pump is failing.
I've attached the wheel motor circuit.
Hopefully you can make heads or tails from the circuit drawing.
/ Foot Treadle #4
There is nothing about the tram circuit on the schematic.
/ Foot Treadle #5
Someone had a tram problem quiet a while back and it turned out that there is a pin that the treadle rocks on and it had backed out and caused it to have tramming problems. Don't know if that might help but it is something to check out.
/ Foot Treadle #6
I agree. That looks like the tram pump, the wheel motors, the hydraulic tank and the filter. But there is nothing showing the treadle valve and hoses.
Anyhow, as someone else suggested, make sure the treadle pedal is actually operating the treadle valve first. That seems like the logical place to start.
/ Foot Treadle
Thanks for the input guys.
I couldn't identify the foot treadle either. I'll check the pin first and then may have to give Power Trac a call for any hints to the problem.
I'll let you know what I find out.
Thanks
/ Foot Treadle #8
It's been a few years since I fixed my treadle. But I think it was the pin that had backed out and was lost. Called Power Trac and they had to rob one off the parts pile for me.
Recalling back, it was held in by a set screw (Allen). Also on mine there were two of them, one set on-top of the other. Very tight to work on, I had to make a tool from a Allen wrench so I could get in there.
Also- I might have taken the whole treadle loose, so I could get to the back side. All of this is off the top of my head, my PT is not near me so I could not go and look at it.
Selkirk
/ Foot Treadle
Just to let you know what I found in the foot treadle. The pedal assembly was working loose from the mounting block, thus not making the valve to actuate properly. Haven't had a chance to test the PT, but I think that tightening the screws to the mounting block will do the trick.
/ Foot Treadle #10
I had the treadle pin problem back in '05, and back then I posted what I found and the remedy, along with some pix as part of our ever-developing "master manual" for our machines. The post is still in TBN archive and so are the pix! They are here: http://www.tractorbynet.com/forums/power-trac/66042-treadle-pedal-troubles.html
Basically, there is a pair of vertically stacked Allen screws (2.5mm) The top one acts as a "jam screw" once you tighten the deeper one against the brass pin to secure it. After tightening the top Allen screw, I applied some GREEN Loctite into the little well around the screw head (post-assembly Loctite formula) and it got sucked down into the threads, just as nice as you please. I haven't had a lick of trouble since. Hope this helps.
/ Foot Treadle
Well, we had about 20 inches of snow in the Central PA area. I ended up using the old sears snow blower to start clearing the driveway before using the snow blade on the PT to finish the job. The driveway is about 200 ft. long. That is just a little too much snow to move with the PT snow blade. Once I had a path made for the PT the 425 earns it's worth. The ability to raise the blade to push snow works great.
After finding the mounting block screws loose on the foot treadle, I thought I had fixed the problem. Unfortunately, the PT stopped dead in its tracks, but only once in 3 hours of plowing snow. I'll have to go back into the treadle assembly and double check the center pin screws in the foot treadle suggested by Tracdoc.
I still wonder in the back of my mind if there is a valve sticking in the system.
/ Foot Treadle #12
It could still be a valve, TG, but the treadle is pretty easy to check first off---unless it's outside and blowing snow :eek:
To date, we've had ~50" of snow so far this winter in our area of sw VA. In a "normal" winter, we get 8-12" for the entire season. I've plowed more snow this season w/ my PT than I really care to. We have a 900' driveway, most of it climbing uphill to the street. Plowing 25" deep snow w/ the 5' blade was fun at first, but has become more tiresome w/ each new snowfall. I must say, though, that the 6 motions of the blade on the PT were a huge help in going uphill. I was able to push, then curl and lift the blade up with a load of snow, and then tip it right or left to make the blade act as a chute to clear the uphill path. Once that's done, I can plow the rest going downhill.
Have fun in the snow and let us know what you find.
/ Foot Treadle #13
HELP MY POWER TRAC DIED!!! I have no forward or reverse movement. The front lift works and curls and side to side works. The steering works and the motor works fine but no forward or reverse. It don't even sound like anything is even trying to catch. It started to move slower and slower and then I heard a clank. That was it, I pushed it back to my garage and it pushed so easy. Usually there would be some resistance but I didn't have any. I need it badly and I rely heavily on this tractor. What do I do?? HELP. Could it be somewhere in the treadle valve. I don't know where to begin.
It don't even feel like the treadle is doing anything, it did lock in forward for a couple seconds so I went in reverse and it wanted to lock in there for a second or two also. So I went forward slightly to unlock it and that is when it clanked. Now the treadle doesn't do anything. I hope you guys can help me.
Thanks to everyone.
Brian
/ Foot Treadle #14
Thanks to everyone.
Brian
Sorry to hear of your troubles. You should call Terry at Power Trac ASAP tomorrow. :(
/ Foot Treadle #15
I sent an e-mail but will call early a.m. I just don't know what it could be.
Thanks
/ Foot Treadle #16
Don't waste your time with the e-mail. I have owned my PT425 for 9 years and have learned, you just call on the phone. :rolleyes:
/ Foot Treadle #17
Thanks for the sympathy, I called Terry this morning and he believes it is the tram pump. I took it out this evening and I think it is to. It rattles and you can hear metal rattling around inside when you tilt it side to side. Like metal pieces and the shaft catches on something inside. It is toast but they want me to send it down to them to look at or rebuild. I only have 73 hours on the thing. I just hope it is cheap to fix.
/ Foot Treadle #18
I hate to hear that it is something major. Hope it don't cost too much to have fixed and up and running again. Keep us posted on what happens.
/ Foot Treadle #19
If it is under warranty, no cost. If out of warranty, those pumps cost up-wards of $800 to $1000. However, if that pump came apart, guts and all, there is all kinds of stuff/debris in the closed loop system. You will have to do some thorough cleaning, hoses, wheel motors, filter, etc. Maybe Terry can tell you the best way to accomplish that.
/ Foot Treadle #20
Ouch. :( Sorry to hear that.
2001 International 4000 DT 466E (A60462)
2001 International...
2014 New Holland B95C (A60462)
2014 New Holland...
SDLanch SDLGC80 (A60463)
SDLanch SDLGC80...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
2022 John Deere R4023 (A60462)
2022 John Deere...
2010 John Deere 568 Megawide Plus Round Hay Baler (A60462)
2010 John Deere...
