goosneck or bumper hitch
/ goosneck or bumper hitch #1
johniebomb
green ridge mo.
175 Allis gas
Hi all this is my first post and I am sure my answer is in the search some where but I have not been very good at using the search. Heres my dilemia, I cut apart a 76 one ton dually that had a flat bed on it to make a trailer out of. I was going to put a gooseneck hitch on but was thinking that since the trailer is already so balanced maybe I would be better off putting on a bumper hitch. I will be pulling with a F 350 super duty and plan on putting on a old 8 foot dump truck bed to haul gravel with. I was also wondering if it would be worth it to put on a surge brake hitch since I still have the brake lines and brakes on the axle. Any help you could give would be greatly appriecated.
/ goosneck or bumper hitch #2
With a heavy load, I believe a goose neck will pull and handle the weight better.
But, making the hitch on a tag trailer is much simpler.
Depending on the weight class of the license plate, brakes and/or inspection may be required.
Is this for on/off road, or off road only?
/ goosneck or bumper hitch #3
In reality you will never be over say 7,000# on the trailer. That is trailer and payload. Now with that being said I would not tow any trailer with that weight on a single axle trailer..
Chris
I want to be able to lience it to so I can take it to the quarry to get rock but will only be pulled localy with in 25 miles of home. Why would you not pull anything like that on a single axle trailer?
/ goosneck or bumper hitch #5
I have towed about 10,000 miles a year for the last 10 years or so and towed 4,000 miles a year prior to that for about 15 years and that much weight on a single axle trailer is scary when everything is good. Blow a tire and it would whip around my F-350 like a rag doll.
Chris
Good point about the blown tire, the trailer is a dually so is that going to still be a problem with a blown tire? Also my F350 that I will be pulling it with is a single wheel 4x4 diesel. If I go with a bumper hitch would it be worth it to put a surge brake acuator on it? Thanks for all the replys.
/ goosneck or bumper hitch #9
Unless you want to rig up an electric conversion kit (lots of time and probbaly a pain to do) or get an electric over hydraulic brake actuator ($650) you need to get a surge brake actuator ($200ish). From what I hear you want to find one that has an electric lockout solenoid so that you can back up without applying the brakes.
I would recommend keeping the emergency brake cables (if so equipped) and setting them up so that you can use them as a parking brake.
Aaron Z
Great point about the e brake cables, is there any body that has posted free plans on building a goose neck hitch for a trailer?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
2025 GPS Trailers (A56857)
2025 GPS Trailers...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
1997 John Deere 5300 (A60462)
1997 John Deere...
