Busted Branson
   / Busted Branson #11
I am a bit surprised, the korean machines are usually most excellent. I still like the Kioti DK45S. Just don't like their loader.
   / Busted Branson #12
"This would explain the trouble with cold starts and excessive smoke until engine was warm. I did not experience any loss of power or strange noises prior to engine failure.
As for the cracked sleeves???? Maybe a bad casting or is this normal. Branson must have had a reason for going to a sleeveless block.
So no further help from Branson though they did tell me they had almost 7,000.00 paid out for the block and crank. I asked the guy at Branson what the cost of a complete motor would be and he said 9 - 10k ballpark. I guess the mechanic or the Branson rep one was misinformed with engine prices. A lot of difference in 2,000 and 9,000...."
A couple of things.
-a newer tractor with obvious low hours shouldn't be having trouble starting as you describe............hard cold starts with lots of smoke. The smoke makes me think injector issue pretty quick. Bad on the the supplier. Did this not raise any flags for you 5 or 10 or 15 starts ago? It would have me. Bad on you.
-3 months out of warranty is not "in warranty." I've known people with cars 3 months out of warranty that were denied work for problems. Couldn't provide proof of service......couldn't verify start date of problem.....etc. Warranties have defined terms that work both ways. When you say "Well, the problems started 6 months ago" it raises the legit question in return "why didn't you say something to us then?" I work in the warranty/service/repair business so I see these things all of the time and from BOTH sides of the issue.
Reading this thread does not make me think less of Branson. It does not make me want to buy a Kioti. It does simply reinforce in my mind that I must buy and use with normal sense, understand my own responsibilities, and understand when, if I haven't done my own due diligence, that I should be happy when something comes along to help out.
That Century came along and ate a good amount of $$$ for an out of warranty unit is not bad on them nor is it proof of having been wronged for you.
   / Busted Branson #13
JoeinTX,
Yes, I kinda/sorta agree... in an IDEAL world we would jump on every little symptom at it's first or second occurrence, or 5th., 10th., etc.
In reality I think a lot of folk probably are used to seasonal equipment that is hard to start (partly) because it gets left idle for long periods.
Folk express SURPRISE that their lawn mower or snow blower "Starts right up, first pull".
I don't know how much of this carries over to tractors, but some of it probably does for some of us.
It seems to be getting hard to start, but it has been kinda cold and damp and I haven't used it for a while and that fuel has been in it a while.... line of thinking.
and it is easy to ignore that it is getting worse if it is getting worse slowly and we sub consciously make excuses for it.
I know I don't chase down every rattle.
Although the smart side of my brain says it is because two things are tapping against each other and that must be causing wear, the lazy side of my brain says it is probably just something that needs tightening and that can be done "later".
Anyway, sorry all this happened, I am going to take it to heart and really follow up on hard starting problems errrrrr,,,,,,,,, soon.
BTW, I think Kukje, Branson, Century fuel injector systems are Bosch - and so are a very large percentage of other CUTs, so the root cause is probably hard to get away from, e.g. by changing brand/badge name.
   / Busted Branson
I apologize to joeintx for not having the mechanical grasp that you do. Do you have any other helpful tips that might save me further aggravation due to inexperience?
   / Busted Branson #15
I can't speak for Joe, but I thank you for publishing this.
I think you have done the rest of us a great service.
I don't always "Get on it" when I know there are problems.
I understand enough about mechanical things to know that very few failure modes are "self healing", but I do tend to shrug and say it will either go away or break in such a way that the steps to repair will become obvious.
I think the BIG object lesson for the rest of us from this is that hard starting isn't "just the weather" or an indication that "Ya need a block heater or heated garage".
Diesel tractors start very easily in very cold weather when they are NEW.
So hard starting is a symptom of some malfunction or component deterioration and needs to be fixed before there is a cascading consequence.
Thanks again.
\R
   / Busted Branson #16
I made it sound a little harsh and I have a bad habit of doing that sometimes. I think Reg summed it up well.
Reg is correct as well that often time we hear that rattle or see that leak or feel that vibration and say to ourselves "Ah, heck, I've got an hour to get finished before dark. Let me do that and I'll check that out next weekend." And that next weekend turns into the next week and then the next month and then you don't use it for a while and forget about and then......BOOM!....it blows up on you in 6 months when you're right in the middle of a project.
:) "I apologize to joeintx for not having the mechanical grasp that you do. Do you have any other helpful tips that might save me further aggravation due to inexperience?..."
Like I said above, sometime I might over-do it in an effort to make a point. That's my bad. But I do hate to see a company or a product (and all the people associated with it and depending upon it for their living) getting a bad rap when it's not necessarily their fault.
Here's one other thing. If Century has a known issue or at least an alert involving bad injectors or bad injectors resulting in the kind of block damage you describe then you might have a better case to use with them. Did you ask them about this?
   / Busted Branson #17
I'm not exactly CUSSIN' about this thread, but I am halfway through pulling all my glow plugs and injectors out.
I will take them to the local diesel truck repair place and ask for spray pattern tests, pop pressure tests, whatever else they do, "balance - as a matched set" maybe something like that ?.
I will look for OBVIOUS signs of any one of them being different first, then we shall see.
I warmed it up on the lower hose heater before starting it this morning, then took the loader off for easier access.
DANG, but it is COLD out there.
Hopefully I can get through this and replace any parts (if needed) before I need to move snow around again.
If not, I guess it is back to the snow blower - if that will start.
Hmmmm, I keep meaning to check into the cold start problem on that thing, but
   / Busted Branson #18
I have come to a tough point in getting the injectors out.
Simple and straightforward according to the manual, I have the excess fuel drain hose off , I also removed the air intake hose and valve cover breather for easy access.
The sticking point is the injectors themselves.
As described in the manual they are held in place with a 22mm hold down nut and they go to some length to say that it is likely to be frozen/rusted in place.
Rust penetrant, then brass drift to loosen, then hold the body of the injector with a wrench while turning the hold down nut with a 22mm wrench.
They caution to NOT ALLOW the injector body to turn as that can damage the cylinder head.
OK, so the injectors are keyed to the head and must not be turned in the keyway, I get that.
My problem is that I can only get a 22mm box end wrench a very short way onto the hold down nut before it runs into the part of the head casting around the cylinder head bolts.
What I think I need is a much thinner walled box wrench, but it would have to be REALLY THIN to get in and down there.
I have been looking at oxygen sensor removal tools and there are some 22mm ones.
The guy at autozone assured me that 7/8 is 22mm - given that 22 is already a bit too big I don't see that 7/8 would be better.
What I would REALLY like is something thin like a chain saw plug wrench, but with top side access so I can hold the injector body at the same time.
Did we used to call those "Tube wrenches" back in the whenever_ago ?
Ahhh, plumbing dept (-:
Any and all suggestions are welcome; other than take it to the dealer, since I can't get it on the trailer in its present condition and I don't want to give up on just this little thing.
I've already spent some knuckle skin.
   / Busted Branson #19
Could you possibly grind down your 22mm box end wrench in the area of interference and still maintain wrench integrity?.....or perhaps give it the crows feet wrench look? I like PB blaster the best.
   / Busted Branson #20
Thanks, yes I had thought of that, but...
..well, but since the thing must have been assembled somewhere ...I guess I'm not taking it easy that it needs special tools for every little thing.
North American manufactured things; maybe.
Korean manufactured things; I hope can still be repaired with hand tools (-:
I went to Autozone again and got a much closer look at their 7/8 O2 removal tool.
It turns out that the CARD it is on is marked 7/8, but the tool itself is etched 22mm.
Not their fault, Great Bend makes it and packages it that way.
So I bought that and FINALLY used it this morning to get all four injectors out.
The manual is WRONG, they are NOT keyed into the head at all.
The 22mm is the base of the injector body, it is not a hold down nut.
The local diesel specialist place told me all four injectors were "junk".
Said they couldn't get a decent spray pattern out of any of them, didn't know if they would be able to get parts to re-build them, but their off_the_top_of_the_head estimate was somewhere around $75 EACH.
Somewhere he said that bad fuel was the most likely cause.
I might buy it 6 gallons at a time, but it is where I also fill up my duramax and it is a fairly high volume station.
OK, I wanted to go to my dealer anyway, so I called.
He was in the shop half under a tractor but guessed new injectors were about $25 each, then started quizzing me.
I showed up 1/2 hour later and he tested the glow plugs - all OK.
STRONGLY disagreed on the injectors and sold me a fuel filter - which I probably agreed to partly on the suggestion of the injectors guy.
So, it is 3/4 back together, the only hassle I anticipate is having to bleed the air from each of the high pressure lines. Tomorrow's task.
The good news is that I have gone through the exercise of pulling the injectors and glow plugs, know which tools, know the sequence, etc.
As with many hardware (and software) things, often just taking them apart and re-assembling them improves things considerably - IF DONE RIGHT (-:
2022 John Deere 1025R (A53317)
2022 John Deere...
2018 Chevy Traverse 3rd Row Seating (A56436)
2018 Chevy...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
2020 FREIGHTLINER M2 NON CDL 26FT BOX TRUCK (A59575)
2020 FREIGHTLINER...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Bobcat T590 (A53317)
