Best Attachment fer road maintenance
/ Best Attachment fer road maintenance #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
what would be the best attachment to maintain 1 mile of gravel rd.
for a Kubota B7800 30 hp
/ Best Attachment fer road maintenance #3
The above mentioned items will all do a great job but to buy anyone of them you had better have deep pockets, especially a laser guided unit.
If you have normal pockets like most of us. A box blade and or a Landscape rake will do a very nice job.
/ Best Attachment fer road maintenance #5
If I could only have 1 implement for the job - I'd get the widest box scraper I could handle. This allows you to rip and move material, unlike a rake that really is just for finish work. If you have pot holes, they'll need to be ripped out with the scarifiers. With the box scraper you will not windrow off the top material.
/ Best Attachment fer road maintenance #6
A landscape will indeed remove pot holes, I do it every spring on over a mile of dirt roads. But the road materials has to be loose enough for the tines to cut into.
I certainly agree that a box blade w/ scarifiers would be a much better tool to break up and grade the roads surface and cut a crown. The landscape would do a very nice job for final smoothing and grading, although I am sure that the box blade would do just as well at this.
Unfortunatly I only have the rake. I would very much like to try a boxblade on the roads this spring just to see how it would work in comparison to the rake.
/ Best Attachment fer road maintenance #7
I do gravel road maintenance among other things with my tractor for a business and have more than one tool, but if I only could have one tool, it would be a Box blade with Scarifiers. Pot holes won't go away unless the hard base underneath is broken up and made as lose as the surrounding material.
David
/ Best Attachment fer road maintenance #8
I'm pleased with the job my LandPride grader/scraper does on my lane. The
B3030 with turfs pulls it in 2wd most of the time. I have actually never needed to use the rippers.
/ Best Attachment fer road maintenance #9
a angle blade if you could only have one thing.. but a box blade would make a good addition/
soundguy
/ Best Attachment fer road maintenance #10
soundguy
That would also be my order of attachments. The angle blade gives the ability to move gravel/rock back and forth over the road, can level and fill in holes well. Look at road maintainers, angle blade and some will also have a drag. If you have a HD angle blade and don't want it to cut in too deeply, just turn the blade around backwards and does nice job of smoothing the surface.
/ Best Attachment fer road maintenance #11
/ Best Attachment fer road maintenance #12
i wouldnt do road maintenance with anything other than a rear blade.
box blade you can not angle to drag loose material from the edge back to the center, does not roll the material over to mix the fines with the larger rocks to give you a good surface.
/ Best Attachment fer road maintenance #13
I have a box scraper, rear blade and a rake. What works best for me is the box scraper then the rake for reshapeing and knocking down windrows.I use the rear blade for working the ditches and removeing snow, my loader and tire chains really help with the snow removal.If I could use just one it would be the rake, have to wait till the moisture conditions are just right.
/ Best Attachment fer road maintenance #14
I said a box blade IN ADDITION to an angle blade.
Sometimes you get areas you need to dig out or mound.. and a box digs better than a scrape blade..
sounbdguy
/ Best Attachment fer road maintenance #15
I have the Dura-Grader and there is nothing better for maintaining gravel drives and roadways in my opinion. They do work best when there is a little moisture in the ground. They will churn up the old gravel and lay it back out nicely.
/ Best Attachment fer road maintenance #16
I have a dura grader, too, and have a roller on back end, raises and lowers hydraulically, so not only packs down, but acts like gauge wheels to keep depth of cut constant ...but, mine is HEAVY.
(I went to the site and no longer see the roller as an option??? but, for me that's the best part)
/ Best Attachment fer road maintenance #18
The Road Boss is a good piece of equipment. Pricey, but good. I have had one for about three years. Use it 2 - 3 times a year, depending upon the amount of rain we get.
/ Best Attachment fer road maintenance #19
Note to the Mini Maintainer people: I like web sites that have at least a town and state so I don't have to do a reverse area code look-up. A real address is better. Also, give me some idea of cost. At least a "MSRP". Cost is as important a specification as any dimension or weight.
On topic: I'll be using a box blade for my driveway, but I have a problem I've not seen discussed on these threads: my driveway base is a thin layer of crusher run , then railroad ballast, then more crusher run. If I tear it up too much, the big rock comes up and will never go down again. So I'm working to find a source of screened crusher run so I can have a top layer of 1/2" rock and smaller/fines that I can re-work without tearing up the base.
Boxblad will be on a TNT, I don't see using the scarifiers for the above reasons. Once I get it right (again), I have used my landscape rake to tweak it. If it's beyond tweaking, it's box blade and possibly more gravel.
For the $s, I'd probably get a land plane before a rear blade, but just because of the other implements I have. I would have no other use for a rear blade.
Pete
/ Best Attachment fer road maintenance #20
Obviously this is only my opinion, but to be clear, you are asking about maintaining the road. I also maintain over one mile of road. I have 4 implements that I use at different times. I have a roll-over box blade, a landscape rake, a rear blade and a grader blade very similar to a Road Boss grader. They each have a purpose, and each can and will maintain a road. But, if I only had one, the one that I would prefer to have to maintain my roads would be the Road Boss type of grader blade. Relatively easy to use, hard to screw things up with it and no moving parts to fool with. A very tough implement. I actually have 2 of them, a 7 footer for my bigger tractor and a 5 footer for my 32 horse tractor.
Is your road on flat ground, or do you have inclines that you have to go up? If flat ground you may be able to get away with a 6 foot wide grader, but if you have to go uphill, I would stay with a narrower blade, 60"-66" I would think. If you consider a grader type of blade, check around, there are several makes and check the weight of them, the heavier the better for this type of work.
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
Mounting Plate Skid Steer Attachment (A61572)
Mounting Plate...
86 (A63290)
86 (A63290)
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
