KAMA 454 battery replacement
/ KAMA 454 battery replacement #1
Paddy
Bloomington, IN
Kubota, G5200, KAMA 454
Hi there, long time no see.
My KAMA's battery finally gave up. It lasted quite a long time, over 4 years. The last legs, I had it on trickle charge to get it started. This was even in the Summer when warm. But I waited until she would not start. But now it's very cold and snow is on the way. I will be heading to Interstate battery tomarrow to get the replacement. There is not much written on the battery, just 6-QA-120S. It is a big battery. Foot print 6.25" by 15.75", standardard batery height I'd guess.
Any cross over reccomendations?
Thanks for any in put,
Patrick T.
Greg,
Thank you. That's exactly what I needed to know. Hope all is well with you in KY
/ KAMA 454 battery replacement #4
Pat,
I believe your 454 is physically the same as my 554.
I have an Interstate "Workoholic" 950 cca and it fits in the battery tray. It sure is a good extra heavy duty battery though. I replaced the original after 1 year so this one has been in service nearly 4 years now. It cranks over my 4 cylinder 495T2 engine easily.
3RRL,
I went with the Interstate 93 series, 850 CCA. She fired right up. The posts were on the oposite sides but still had plently of cable to reach.
Patrick T
/ KAMA 454 battery replacement #6
Or - you could have just turned the battery around.
//greg//
/ KAMA 454 battery replacement #7
I've got a 254 and a nortrac dozer, I went with the highest COLD cranking amps I could find that fit in the container and my buget. I believe the tractor has 850CCA and the dozer is 900 something CCA I'll have to look .
/ KAMA 454 battery replacement #9
I have the Kama 554. Is this a big 12 volt battery or 24 volt battery? Thanks Much...
By the way, I've this tractor over 5 years and haven't had to jump it off once. Now the battery is too weak to turn the engine over....
/ KAMA 454 battery replacement #10
12 volt system. And my KM454 started first time every time too. I give credit to the direct injection.
//greg//
/ KAMA 454 battery replacement #11
Thanks Greg! Thought I had used an analog volt meter to check the voltage and read something around 24volts; must have been looking at the wrong scale... :| Hooked up the 12v charger after refilling all the cells and now it cranks right up!!!! Thanks again, KevinW
213098 (A64276)
213098 (A64276)
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2015 Chevrolet Equinox SUV (A64557)
2015 Chevrolet...
2020 Hino 195 Landscape Dump Truck (A64556)
2020 Hino 195...
HARDEE LR40142 DITCH BANK MOWER (A64278)
HARDEE LR40142...
2022 EZ-GO ELITE...
