TBN Server News
/ TBN Server News #21
Is there an issue with searching? I cannot get the search function to work right now. When I search for anything I get sent immediately to TractorByNet.com - Search Forums and it says 'done" but nothing happens, no page loads or anything.
This is on FF 3.5.6 on Windows 7 x64
Edit: on the same computer with IE8 I get a 500 error when doing the same search
Thanks
Aaron Z
Thanks, I'm getting the same error... but only on certain search terms. We're working on it.
/ TBN Server News #24
Even if no results are found it should display a page showing the number of results.
/ TBN Server News #26
Hi Muhammad, I got kicked out and had to log in when replying to a post this morning. I know I was logged in because I was looking at posts I was participating in at "My Home" at the time. No big deal but I know you like to hear about any unusual things during a server switch. This one has been smoother than some I recall.
MarkV
/ TBN Server News #27
Just received this error 5:06 PM EST when trying to go to the second page of Jinman water leak thread:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, you@example.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
I was then able to back up and try it again and it worked fine on the second attempt.
/ TBN Server News #28
MarkV
I was logged in, and tried to post, and got this message.
You do not have permission to perform this action. Please refresh the page and login before trying again.
Okay
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
Thompson Water Pump Diesel Engine (A66734)
Thompson Water...
CASE SV208 SMOOTH DRM ROLLER (A67714)
CASE SV208 SMOOTH...
Engine knock
Engine knock
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
