Is a BX tractor right for me?
   / Is a BX tractor right for me? #21
Now that you ask I was in the hospital 12-7-9 through 12-11-9.
Had a small stroke.
Didn't do much damage except left part of my right hand slightly numb. I"m glad i'm left handed.
I considre my self very fortunate .
It could have been a lot worse.
I have surgery scheduled for 1-11-10 to clean out the left Karoted arety in my neck .
Thanks for asking about me .
Mr Brown, I'm happy to see you back. I too was wondering where you had gotten to. Best Regards and Happy New Year!
   / Is a BX tractor right for me? #22
Welcome back LB. Glad to hear you are feeling better and pray your surgery goes well in a few weeks.
   / Is a BX tractor right for me? #23
Had a small stroke.
Sorry to hear you have been ill; hope things go well with your surgery.
   / Is a BX tractor right for me? #24
I own a B2920 and a JD 425.
For mowing, especially if you're doing grass collection, it's hard to beat a JD 500-600 series (children of my 400) that has a blower and the material collection system on it. It will hold about 18 bushels in it's tow behind cart, and you can dump the cart without getting off the mower. These are true JD mowers and should not be confused with JD rebranding of Lowes or Home Depot mowers. So if 99% of what you want to do is mow without grass collection, look at the zero turn models (Kubota sells some). If you want to do 99% mowing with grass collection, look at the JD 500-600 with material collection system.
When I bought my B2920, I was tempted to sell off the 425 and use the money to buy a large mid mount mower for it, but there really was no way that I could match what I had for the grass collection. So now I have both.
The BX series are (as others have mentioned) true tractors. If you have sloped hills to mow, the BX has a much lower center of gravity then the B series. If ground clearance is more of a issue, then look at the B series.
Kubota is doing some good financing systems now, so consider getting everything you need as a initial purchase, rather then just getting what you can use now.
Hope that helps
   / Is a BX tractor right for me? #25
   / Is a BX tractor right for me? #29
I have a friend just bought a BX2660 with mmm. He is looking at getting a bb. I feel a 6' blade is not too big for dragging sand around his place on level ground or grating the drive. All the salesmen want to sell him a 4' based on tire width. I feel this is because many folks will snag things due to not being able to operate the equipment properly, not based on equipment capability. I used a 6' blade on a smaller, lighter 21hp 2wd and steered with the brakes. I just can't see a 4'. What do most of you guys use with your BX models?
   / Is a BX tractor right for me? #30
Carter, In my opinion, the dealer is a bit closer to the reality than your desire for a six footer. That would be a load, trust me. Not saying it wouldn't work, just not nearly as well as a 5', which would split the difference. I agree that a 4', when tilted, would not be wider than the track of the rear wheels. The BX is a blast, but a lot of the joy disappears when attempting to use too large of implements, for my money.
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
2008 John Deere 6330 Premium with Trebro Sod Harvester (A52128)
2008 John Deere...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52128)
Gooseneck...
IH 1566 Tractor (A50514)
IH 1566 Tractor...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
(3) PIVOT TIRES (A51244)
(3) PIVOT TIRES...
