logging winch
   / logging winch #21
I have a Norse 390 on my JD 4310. very nice unit . I picked it over the Farmi because of the lower pull point of the winch. makes the tractor a lot less tippy; it will drag the tractor before it will tip. much easier to control
   / logging winch #22
milemarker hydraulic winch run off the remotes
   / logging winch
   / logging winch
Mile Marker Winch showed up today. UPS driver said man is that heavy.
Well packed. It appears many sizes ship in the same box. The ports are SAE 10
OSB . No paper work tells that and when I spoke to the factory they told me it came with fittings for JIC 6. Fittings must be in the Power steering controls kit that I don't need. Unit looks good. I ordered valve and some other parts from
Burden Surplus today.
   / logging winch #25
I also have a small Farmi. I like the fact that it pulls from the top. It really helps when the tractor is backed to a rut or ditch or on a bank to have that upward pull when the log gets in close.
You will not pull the tractor over if you have the upper link adjusted so that the force is directed at the rear axel or below ( which means use the lowest
hole on the tractor end of the upper link).
The Farmi unit will definately not dissapoint you.
   / logging winch #26
Anybody have the 290 Norse? I've been wishful of one of those for a while.
Chilly
I've got a Norse 290 and I have nothing but praise for it. I run it on a JD 790 and That too is an excellent machine. I chose it over the Farmi for a couple of reasons one being cost although I would have spent the money if I thought I was getting a better product. Secondly I bought it from a logging supply dealer that I have done a lot of business with and will continue to. They gave me a good price, shipped to the local store for pickup and offered me a satisfaction garantee. I looked at them before purchase and they are well made and easy to work on if need be. I have run it through 2 seasons without trouble. I am also amazed at how powerful and quick it is. I thought about a hydraulic unit but when it comes to speed (rewinding 165' of cable how many times a day) nothing compares to the PTO winches. All in all 5 stars from me.
   / logging winch #27
I have an old braden " belly winch" , pins in to the drawbar and runs off a sprocket splined to the tractors pto shaft that drives a larger sprocket on the winch input. Barely had room but i could still fit a scrape blade on the 3pt, hung a big snatch block on the blade so that the cable was putting down pressure on the blade to hold the tractor ( 135 MF) in place. Engage the pto, pull a lever on the winch to start pulling, works pretty good, only problem, which i learned the hard way, once its pulling you cant disengage the lever on the winch, you have to step on the clutch to kill the pto. Still the whole rig cost around $500 and works great. Im thinking about building a brush guard of some kind cause i do alot of pulling downhill and sometimes a log will take off on its own, specially if its any bit muddy.
   / logging winch #28
Bob,
I have been following the thread but I don't quite understand if you are going to run it off of a hydraulic remote on your tractor? How exactly is it going to be powered? You are talking about getting a valve. Is that a tractor remote valve or specific for the Mile Marker winch?
Edit: I missed an earlier post where you do say tractor remotes. Is the large GPM output of your tractor ok with the winch. I believe they mentioned a 3.5 minimum but no maximum GPM pump requirement.
I'm in the same boat. Logging winches are great but they are way too expensive.
I have been doing a combination of chains, two snatch blocks, nylon rope and drive forward system. It works but makes even more of a mess on logging roads because I have to drive over the same ground more as I pull the logs out to the road.
   / logging winch
Bob,
Boy there are so many threads here I lose track of my own.
I am going to run the Mile Marker winch off a rear remote already installed on my tractor. You could just leave it at that except for a couple of issues.
The tractor valve is not a motor spool. Motor spools when centered dump the motor ports to tank. Prevents damage to the motor from over running loads. Don't know if it matters for this application but I am not willing to take a chance. Second, although the Mile marker will allow free spooling out , if you do that then you have to walk back to the tractor to engage the winch.
I also think the 3.5 gpm is a max because they specifically mention that limit when powering out.
So what I am doing is buying a Vickers 10gpm 12vdc sping center motor control valve. Burden Surplus has them . The use a 2 channel 12dc gate opener to pick it A coil or B coil Spool in or spool out. The Mike Marker also wants a 1500 psi limit. If the tractor valve is tied back, and the QD are connected to the Vickers and the Vickers is spring centered then flow is to the tank at 7gpm and 2250 psi. Too much pressure and flow for the winch. So after the vickers I added a double cross over relief valve set at 1500 psi and in one leg after the relief valve to the Mile Marker motor I added a flow control valve that works in both directions, i.e. no check valve to limit the flow to 3.5 gpm.. So I can walk around with the remote control and make the winch spool in or out. I posted attachments of all these parts way back at the beginning of this thread. All the valves came from Burden. Winch came from Summit racing. Gate unit came from gatehouse supplies. I have about $1000 in this at the moment. Hydraulic fitting and hose looks like another $100. If I had a hose fitting crimper ($1400) it would be half of that.
I will get some pictures going when I have some of the stuff mounted. Right everything is sitting on a piece of cardboard while I figure out he fittings.
Oh yeah I am putting a back up alarm on spool in so If I let go of the button and it keeps going I will know.
   / logging winch #30
I've had 2 Farmi's. My current one is a 501. There were both excellent. Comparing a real logging winch to a electric winch mounted on a plate is like comparing a backhoe on a BX to a 50,000 lb excavator. There just isn't any comparison as to capabilities.
Andy
excavator trenching bucket- one bucket per lot (A56436)
excavator...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A60460)
2013 Ford F-250...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
