Basic Oil change question
/ Basic Oil change question #1
mrlullabye
Member
I changed the oil on my Farmtrac 360 for the first time yesterday. I changed it just like a car, removed the plugs, while it was draining spun a new filter on, replaced the plugs, and refilled with Castrol HD diesel oil. Just like I would for a car.
I am curious though, since I will be picking up tractor maintenance as a new hobby. Is there any good site that has basic suggestions about filter/fluid changes?
I was sitting there thinking "I sure as **** hope there is no special oil priming procedure for tractors I never knew about" Someplace that might help me avoid those easy pitfalls.
/ Basic Oil change question #2
Oil filter,I like to rub oil gasket..better seal also easier to remove.
/ Basic Oil change question #3
the only thing i can think of is dont change the fuel filter at the same time as you change the oil as it will and can rev up when you first start it thus takeing out the bearings. change the fuel filter only after you have started it and checked for leaks don
/ Basic Oil change question #4
My tractor has a fuel shut off knob to pull as I turn the key off, to stop the engine. I usually leave this knob in the off position as I crank on the starter for a few seconds after an oil change, till the oil pressure builds a little bit, then push the knob in and crank as usual.
/ Basic Oil change question #5
Backdoor stole my thunder. I read here a while back that spinning the motor is a good thing to build up some oil pressure. I did not forget and I spin the motor with fuel off, particularly when it is cold out, to build a little pressure prior to starting.
The best place I've found for technical and maintenance advice is here on this forum.
Joel
/ Basic Oil change question #6
Only other thing I do is fill the filter with oil prior to installing but your filter may not go on vertical like mine with the gasket up. I also do a good visual inspection on bolts, nuts, belts, hoses, ect. Check the sumps for proper level. My tractor is 4x4 so I have a front axle, main transmission, and hydraulic oil sump. My tractor does not have a common sump. I also check the air filter and change my injector pumps oil every other oil change. My tractors injector pump has it own oil sump for lube.
As for basic maintenance here is the schedule I follow:
Oil & Filter=50 hours
Injector Pump Oil=100 hours (every other oil change)
Air Filter=As needed
Hydraulic Filter=250 hours (every 5th oil change)
Fuel Filter=200 hours (every 4th oil change)
Hydraulic Oil=500 hours
Tranny Gear Oil and Front Axle=500 hours
Chris
/ Basic Oil change question #7
Chris
Do you do the hubs on the same schedule as the front axle?
/ Basic Oil change question #8
G'day for those out there with FWA units we change the final drive (front hub ) oils with every eng oil change (not diff), however we work on 250 hr service schedule we also like to use an 80w90 gear oil instead of trans oil as most manufactures suggest and have not had any probs with some units now up around the 15k hr mark, was in one the other day just ticked over 12k to replace a seal that had been chewed out by a bit of wire and it looked like new
Jon
/ Basic Oil change question #9
I am not sure what you are asking but maybe this will answer your question. My front axle has 3 drain plugs. One on the center section, pumpkin, and one out at each end of the axle at the hub area. It all filled from one location on top of the axle where the dip stick is. It uses 80W90 gear oil.
My tractor calls for 15W40 for the engine and injector pump. It calls for 80W90 for the front axle/hubs and transmission. And it calls for AW32 for the hydraulics.
So I guess the answer is yes.
Chris
/ Basic Oil change question #10
Chris
Ahh... The hubs on my JD 2240 are seperate from the pumkin and have their own fills/drains. I didn't know any tractors had them connected where they would all fill from one point. Hence, my curiosity about the hubs.
/ Basic Oil change question #11
I would get a manual for your tractor and follow the recommended schedule.
/ Basic Oil change question #12
gonna have to wave the BS flag on that one.......
gee, ive been in the heavy equipment/large truck repair and maintenance industry for quite a while now, and have never heard anyone say this, seen anyone do this, or been told to do it this way. i always change the fuel filter while the oil is draining. i have never seen, or heard of an engine revving up when it first gets started after a filter change. even if it did, there's still oil in the pan for it to use; i dont see how a bearing could get taken out. its not like its going to run at redline for several minutes.
i work on very expensive machinery, and if a boss or owner thought their machine was going to spin a bearing b/c the fuel filter was changed at the same time the oil was, i am sure i'd know about it.
2011 FREIGHTLINER M2 112 CNG (A59909)
2011 FREIGHTLINER...
JOHN DEERE 3032E TRACTOR (A62130)
JOHN DEERE 3032E...
2016 Boxer 700HDX Compact Skid Steer (A63116)
2016 Boxer 700HDX...
2016 CASE IH MAXXUM 115 TRACTOR (A62130)
2016 CASE IH...
Bobcat T650 Compact Track Loader (A64047)
Bobcat T650...
1989 SEABRING MONTEREY 23' SPORT BOAT (A62130)
1989 SEABRING...
