Magnetic Work Light
/ Magnetic Work Light #1
bp fick
Super Member
Beaver Creek, Northern Michigan
John Deere X390
/ Magnetic Work Light #3
Got one as a Christmas gift. Here's a quick review for those who may have pondered having one.
It's Great!!!
No, seriously. It's pretty darn good. Works off a power point. Stick it where you want it, need it. Move it. For only $20 at TSC? I'd give it two thumbs up.
Blazer 12 V Magnetic Work Light CWL235 - 0283852 | Tractor Supply Company
I just bought one the other day. Now I have to hook up a power point. I picked up a "weatherproof" one from Autozone a while back (have to find the darn thing!).
Can I tap into the trailer harness pigtail on the back of my tractor as a power source?
There are a number of good options. Wire it to a power point, if you want a power point for something else, like an iPod. If you just want the light to always be on, any hot wire will work, I suppose. I wouldn't want it that way. I think I would like it in my running lights circuit and may wire it into that later on. For now, I will simply plug it in and unplug it, as needed.
Some newer tractors provide an unused lead under the seat or rear fender for additional lighting options.
/ Magnetic Work Light #5
Looks like a handy multi use light, I have a handheld one that I almost never use (sits in a box), I would use it more if it had a magnetic base. Could just leave it stuck on the tractor somewhere and have it ready to use when ever needed.
I had to put my own aux 12 volt power source outlet on, was surprised that my expensive, advanced JD didn't have one from the factory :(
/ Magnetic Work Light #6
I could use one of those.
Does it have something over the magnet to keep it from scratching the paint?
Ronnie
/ Magnetic Work Light #8
Harbor Freight has a magnetic ground block that has a very similar magnet with a hole in the middle for $6 - Harbor Freight Tools - Quality Tools at the Lowest Prices I used 2 to mount some lights on my tractor when I need them. Might work for your handheld light.
/ Magnetic Work Light #9
I like it. I will get one.
I am thinking of using a weatherproof switch (maybe mounted through the lights housing) and using the existing work light circuit that is tucked under the back of my BX 2660
/ Magnetic Work Light #10
I've got a TSC Blazer stuck to the chute on a Farm King 60" blower. I wired up a power point inside the cab of my B3030 and simply plug in when needed. The wire is run right out the rear window and I just close the window on the wire. So far there doesn't seem to be an issue with window gasket or wire.
Decent light for the money and does what little I ask of it.
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2018 FORD TRANSIT 350 SERVICE VAN (A59823)
2018 FORD TRANSIT...
1011 (A61165)
1011 (A61165)
HP ProLiant DL360p Gen 8 6-Bay SFF Server with Misc Servers (A59317)
HP ProLiant DL360p...
John Deere 4510 (A53317)
John Deere 4510...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
