YANMAR 2002D TACH CABLE LEAKING
/ YANMAR 2002D TACH CABLE LEAKING #1
winston1
Super Member
gilmer tx
Bobcat CT235
My 2002D tachometer cable leaks where attached on housing in front of engine. One fellow said the housing would have to be changed to stop this. Any other advice out there? Also wondering what John Deere would be closest match to this Yanmar? Thanks, Winston
/ YANMAR 2002D TACH CABLE LEAKING #2
It' really hard to tell from here whether the housing is bad or just needs tightening or thread sealant. If you need one, why not a Yanmar parts dealer.
/ YANMAR 2002D TACH CABLE LEAKING #3
You may need to replace the O-ring, it's an odd size. I should have a housing if you need that.
Danny
/ YANMAR 2002D TACH CABLE LEAKING #4
If it's that odd of a size you would be amazed what straight cuts to shorten it and a drop of super glue will do for you until you get the correct one. Most likely very little or alot of cases won't leak at all.
Carey
The parts drawing does not show an o-ring on the tach cable. I tried putting one on it with no success. Winston
/ YANMAR 2002D TACH CABLE LEAKING #6
winston , have you considered the gasket in a tube? you could also try Hoye for that housing. russ
I have tried a silicone gasket sealant after cleaning everything. May not be the best sealant for the job. If you know of one that might be better I might give it a try. I haven't tried to locate a housing yet. Figure it will be pricy and I'm hoping for a cheap cure. I've been called cheap before.
/ YANMAR 2002D TACH CABLE LEAKING #8
There is no O-ring on the tach cable, the O-ring is between the tach gear housing and the front cover housing. There are 2 nuts that the tach gear housing on.
Danny
It is leaking where the tach cable screws in. It is tight. I cleaned all the area good and put silicone gasket sealant all around it. Still leaks. Not leaking around the housing. Thanks, Winston
/ YANMAR 2002D TACH CABLE LEAKING #10
Spring for a $ 10.00 tach cable, if it still leaks replace the housing.
Danny
/ YANMAR 2002D TACH CABLE LEAKING #11
I suspect there is a seal of some type inside the gear housing. The cable housing is probably not intended to prevent leaks. Take a look.
Just wanting everybody to know I have a new tach drive housing, o-ring, and tach cable ordered. Will not remove the old one till new one arrives. Might want to do a little work before then. I will inspect the old housing closely and report back any findings of interest. Thanks for all the input, Winston
Recieved my new parts from Hoye this morning and got them installed. No leaks now! The little tach drive housing has brass bushings in it that the 2 shafts run in. I suppose thru about 26 years of running the clearance had gotton great enough for oil to come up thru the housing. Thanks for all the advice on this project. Winston
2005 Butler pole trailer (A62679)
2005 Butler pole...
New/Unused Wolverine Quick Attach Quick Coupler (A65583)
New/Unused...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
