What do you guys think about this 10k trailer?
/ What do you guys think about this 10k trailer? #1
Bama67
Enterprise AL
Branson 5520H
I have been looking for a 10k capacity 7x20 ft trailer for a while. I wanted to find one used, but they are few and far between. I have priced them at numerous dealers around here and the going price for one like this is about $3,500. Then I found this one in MS for $2,500 out the door. Here are the specs:
New 6'10" X 20 Equipment Trailer
6ft 10 inches between the fenders, 20ft bed length.
(2) 5,200lb axles with electric brakes on (1) axles GVWR 10,400 lbs
Pressure treated wood floor
Heavy duty adjustable pin up kicker ramps
2 5/16 coupler, breakaway box, safety chains, hd jack and all lights and wiring
(4) New 225/75/D15 Tires on 6 lug rims
Stake pockets located on both sides/diamond plate fenders
Trailer is made by a small outfit in MS called BTM. Trailer has a data plate, title, etc. Anyone heard, or had one by them? Here are a few pics, what do you guys think? I haven't found any other trailers any better for anywhere close to that price point. I haven't looked at the trailer in person as it is about 4 hours away. Thanks
/ What do you guys think about this 10k trailer? #2
I would not want to tow the trailer at 10k with brakes on only one axle. Upgrading the brakes to a 2 axle system should only be a couple hundred bucks more, and something I would highly recomend.
/ What do you guys think about this 10k trailer? #3
The trailer looks very nice, If it's new ask them to put brakes on the other axle, or you can have it done yourself, if that's possible.
I've got a 20 footer as well it's nice having the extra room. I looked for a long time before I found one for a decent price
Here in CT I think it's required to have brakes on both axles, never seen one without.
The only other thing, I can't see how the coupler is done, I prefer the adjustable and easily replaceable channel type.
Good luck.
/ What do you guys think about this 10k trailer? #4
Looks like a great deal. In your area brakes one one axle is fine because its pretty flat except in the north as long as you have a 3/4 ton truck or more. Now like the others said a second axle brake setup is only about $200 and is money well spent.
It looks like a good trailer all in all. I would also spend a extra $200 and get a spare tire and mount.
The only other issue I see and it may not be a issue for you is a winch will not be easy to mount without fabrication. I have a winch on my trailer and could not live with out it so that is something to think about.
Chris
I was already thinking about added brakes to the other axle. Either way it will be much better than the one I use now that I borrow from my brother in law. It doesn't have brakes at all. And I already have a spare that I think should fit. I will be pulling it with an 05 F-150, that is until I sell it. Then I think we will get an Nissan Armada, which also should handle it quite well. I will be putting a weight distb hitch on it.
And you are also right about a winch, I picked up an old Blazer recently and had to come-a-long that thing all the way on the trailer. It was a real PITA.
/ What do you guys think about this 10k trailer? #6
That is a nice looking trailer... I sent you a pm
/ What do you guys think about this 10k trailer? #7
I want one!:D:D:D
/ What do you guys think about this 10k trailer? #8
That is good looking trailer! I agree about adding a second set of brakes on the second axle.
The Bulldog Collar-Lok Ball Coupler is more fool proof, easier to use, and stronger than the commonly used channel type coupler. I've used the Bulldog Collar-Lok Ball Couplers for many years and unlike other couplers, except for the Pintle Couplers, the Bulldog Collar-Lok Ball Coupler is one of the stongest available.
Jim
/ What do you guys think about this 10k trailer? #10
I was just about to head to the same place and check them out since I was going North of Birmingham anyways and in the area. Did my share of shopping also and they did seem to be priced lowest for my area.About the same distance away as you. But lucked up found the one I have on CL. and went with it only 1yr. old and had the title. 7m, Dual brakes,Spare,stow away ramps and Winch with a remote for the same price with a few nicer extra features. So I offered him the same price and he agreed. I had been looking hard and just got lucky,if this one did not come up nothing I seen local to me came close to that Esp. being 10m. IMOP. Also see what they can do about the brakes and a winch. Take the others good advice on that also.
Carey
For a little more you get a LOT more. These people are the best in the business.
Kaufman, Trailer, Bobcat, Backhoe, Constuction, Flip Up Ramps
Tilt Bed Trailers
Those are some nice looking trailers, and that 18 footer they got on special is a good deal. I just need a 20ft and I also don't want to drive from south Alabama to North Carolina to pick it up.
I work offshore of LA and I can pick this one up in MS on my way home. I also emailed the guy about adding brakes to the second axle, he said he would have to talk to the builder Monday but said he thinks it is $150, not bad.
/ What do you guys think about this 10k trailer? #12
$150 is a good deal for brakes. That is what the parts cost alone. I have added second brakes before and charge $200 getting $50 for my labor. Not a big job for a guy who knows trailers, maybe 10 minutes a side.
Chris
/ What do you guys think about this 10k trailer? #13
If you NEED 10K of trailer capacity, then you need MORE than a half ton truck to pull it. I've pulled a fully loaded 7K trailer with a half ton and it was a nervous undertaking that I only did a couple of times a year. As a minimum, you'd need a weight distributing hitch setup, but even then I think it would be too much for your truck.
As for the single axle brakes might be okay since you are in flat terrain, that has nothing to do with the need for adequate brakes for an emergency stop.
It's best to take a good close look at similar trailers. When I bought my 14K gooseneck last summer, one dealer had one that looked a little skimpy compared to another dealer that was only $500 more. The first one only had single axle brakes and the ramps were narrow and weak compared to the better one. I have a lot more faith in the quality of the one I bought.
Ken
/ What do you guys think about this 10k trailer? #14
Ken
Don't F150's have a 10K tow rating?
/ What do you guys think about this 10k trailer? #15
I doubt it, but even if they do, that doesn't make it safe or sane.
I remember when the Chevy towing guide said that a Chevette (70's compact car) could tow 3000#. I never even figured out how you could attach 3000#s to a Chevette.
Ken
/ What do you guys think about this 10k trailer? #17
I have pulled 10K with a 2002 F-150 and had no issues other than horrible 6mpg fuel economy I took it all though Indiana, Kentucky, Tennessee, Pennsylvania, Virgina, West Virgina, and Georgia.
Chris
/ What do you guys think about this 10k trailer? #18
Up to 11300 with the 5.4 3 valve and 6 spd auto for 2010.
IMO, that's insane.
It points up the difference between "ability to pull" and "ability to safely control in an emergency":eek:. There is a world of difference between those two.
Ken
I was hoping we weren't going to get into the 1/2 ton 3/4 ton debate. My truck is rated to pull just shy of 10k. It will do just fine, this F-150 is twice the truck the old F-250 we have on the farm; stouter frame, more powerful, heavier, and much better brakes.
My wife daily drives the truck all over the place why I am on the rig, so I am not really wanting to get a huge truck for no more than I will be putting it to good use. Trust me, I would love to roll around on a big diesel F-350, and for the longest wanted to upgrade. I even made a thread here about it; I just decided that it was not really necessary. Because once I sell my home, I will hardly ever be towing the tractor.
To start a bigger debate, if I decide to ever sell the F-150, I gonna be pulling it with a Nissan Armada, a 1/2 ton SUV. :D Now, that is a powerful beast, I think Nissan is conservative on their 317 hp rating. What suburban sized, nearly three ton beast scamps 0-60 in 7 seconds flat? It can; it's an impressive platform.
What I really need is, is like one of the dozen trucks that Dpilot has. lol
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
