mf 165
/ mf 165 #1
carlackerman
Just purchased an older 165--wheer is the oil filler "cap" located on this. It has a Perkins diesel
/ mf 165 #2
:pSitting on the tractor facing the front on the left side near the front of the engine block midway between the top and bottom of the block,It looks like a flat cap with a tee on top you need to turn the tee a few turns to beable to remove the cap.Its right next to the injection pump.:DLarry
/ mf 165 #4
your welcome just remeber to tighten the tee handle backup when your done.I didn't tighten mine up enough once and it came off while using the tractor.:eek:I notice oil on the loader arms and realized what had happened.It was a good thing that I wrapped the block heater cord around it as it kept it from getting lost.:DLarry
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2016 INTERNATIONAL...
Kubota L175 Tractor (A62613)
Kubota L175...
MASSEY FERGUSON 5 BOTTOM PLOW (A64278)
MASSEY FERGUSON 5...
Knoelder Dial-A-Mix Auger Wagon (A66408)
Knoelder...
