Pasture Maintenance - Landscape Rake?
/ Pasture Maintenance - Landscape Rake? #1
pitt_md
Pine Island, MN
Kubota MX5000
I know this question is out of season but I was curious if any of you horse owners use a landscape rake to bust up the piles in the summer?
/ Pasture Maintenance - Landscape Rake? #2
I use mine, I usually turn it around backward so it doesnt tear the grass up too bad. I also pull a chain harrow behind, to break the piles up even more.
/ Pasture Maintenance - Landscape Rake? #3
I use a chain harrow with the least aggressive setting. The landscape rake tends to tear out more grass for me. Never tried the landscape rake backwards though.
/ Pasture Maintenance - Landscape Rake? #4
I used a chain link fence hooked to a telephone pole with a chain to the tractor.
/ Pasture Maintenance - Landscape Rake? #5
You could probably accomplish the same thing by leaving the landscape rake by the shed and pulling the chain harrow alone.
/ Pasture Maintenance - Landscape Rake? #6
I pick mine up with a manure rake then compost it. Then spread it once it is composted 6+ months. Pr gie to neighbors.
I know...****!!:eek:
Deano
/ Pasture Maintenance - Landscape Rake? #7
We scoop ours daily, keeps the mess down, the neigbours happy, manure pile full.
That said, as i add another much larger pasture next spring, we wont be able to scoop that as frequently, so we'll use the diamond drag harrow to break it up and dry it out. At least that's the plan, my wife is pretty picky about that stuff, so Id bet by bottom $ she'll be out there scooping it up anyway.
/ Pasture Maintenance - Landscape Rake? #8
I use the backward landscape rake approach. I have about 3 acres of pasture, and it does a good job at breaking up the big piles and spreading it out...after running the field and a rain, you can barely tell horses were on it.
The backwards landscape rake also works will to work pasture seed into fresh earth.
/ Pasture Maintenance - Landscape Rake? #9
Chain Harrow - I like to use it in the aggressive mode (teeth forward) - do it two three times a year when it is hot and dry. It is not practical for most people to pick up the poop when you have a lot of acreage ( We have 11 acres of pasture).
/ Pasture Maintenance - Landscape Rake? #10
I'm too lazy (and the wife doesn't pay enough) to pick the manure up out of my two horse pastures. I use a chain harrow set on the aggressive side in the pastures (seems to work better in taller grass). I drag once a month after the horses have been moved to the other pasture.
/ Pasture Maintenance - Landscape Rake? #11
I use a 3pt spike tooth harrow for this about every two or three weeks with cows on a pasture. I also clip the pastures using a high setting on the RC to eliminate patches and weeds from taking over.
2022 John Deere 410R Sprayer (A63111)
2022 John Deere...
Yale GLP070VXE 6,500lb Propane Forklift (A61572)
Yale GLP070VXE...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
HARBIN LIGHT PLANT (A63569)
HARBIN LIGHT PLANT...
MILITARY STYLE S/A CARGO TRAILER (A63291)
MILITARY STYLE S/A...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
