Barlow Feedback Sways Towards Kubota
/ Barlow Feedback Sways Towards Kubota #1
BobWoodhouse
I have been open to Green, Orange, and Blue. The Barlow Equipment feedback swayed me to start searching the Orange path more. I wrote them this letter just now, which I figure I should put here, too, in case there is some good perspective on what I should be looking for:
Here's what we have today:
I'm in Northern Illinois on 12 acres of loamy and sandy dirt in a low-lying, but not swampy area.
7 acres is farmed by a real farmer.
2 acres is a long (90' x 1,000') grove of pines.
3 acres is yard with a few buildings, plenty of individual trees, crumbling old concrete foundations, gravel driveway.
I have a John Deere GT325 with 48" mower and a rear 30" tiller (used to establish my racetrack, not gardening).
Also have a walk-behind Yard Machines 24" snow blower.
I have no real problems with what I have right now, except for these wants:
1) I borrow a friend's skidsteer to change around my remote-control racecar track. I would like a FEL to take over this task of moving around. It takes him about 1.5 hours for this task performed 2-3 times per year. I would like to break the task down into more times per year, but smaller effort each time.
2) I would like to have dirt hauled in to cover the concrete foundations (too thick for me to remove), then spread and work the dirt for a nice finish.
3) The grassy yard is rough. I would like to smooth it out and make it easier on my mowing chore.
4) I maintain the trees, so I must thin them out and move to the burn pile. A way to drag, lift, or somehow move logs and branches across the field (have the tractor pull its own trailer, etc.) to the burn pile would be good. It would be really awesome if I could remove/grind stumps from 20-year old white pines from my dirt.
I have been told by a few folks that I would want 4WD with the FEL. And I know a box blade is an popular counterweight.
Some folks say get rid of the old tractor and maintain only one, but the JD GT325 is great for getting under trees and around obstacles for mowing.
I can park in a heated barn with door size just under 8' wide and height around 9', with ceiling of 11'.
I would pay cash (not finance), so every dollar is looked at, and no hurry for a financing window.
I might consider features that aren't "essential" but would dramatically hurt resale if missing, but not too much plan to resale.
Just starting to look. No hurry. And not wanting to waste your time by just teasing with questions.
So, any first ideas or questions about this topic?
/ Barlow Feedback Sways Towards Kubota #2
sounds like you want to go with a B or L with FEL and 4wd. You can add a back hoe to the tractor to get rid of those pine stumps instead of grinder. If you add a grapple on FEL you can move brush, stumps, logs to new location. a less pricey item instead of grapple is a thumb for backhoe to pick up pine stumps after its dug out and move.
A cab on a tractor really helps sales I beleive- everybody wants a cab, but cant afford new. I betcha that once you get a tractor, you will end up using it for snow clearing as well instead of blower. I know I did. :D My blower still sits in shed for almost 4 years now. Every year I start it up and change oil but never used it in winter.
You could go smaller or larger then B or L like an BX or M but it becomes cost or timewise issue for your sized lot and needs.
/ Barlow Feedback Sways Towards Kubota #3
I agree with radioman on a larger B or L series machine except maybe for the racecar track removal/installation chore. I really don't know what's involved with that except you state it takes 1.5 hours each time with a skid steer and you'd like to do it more quickly with your tractor. Since skid steers usually have larger FEL capacities that tractors, this chore might be your limiting factor and one that necessitates a larger machine - grand L or M series, BUT, perhaps you can clarify more specifically what this chore entails and how much weight your talking about moving.
The racetrack is 6,000 square feet of dirt. I mis-spoke perhaps: I would like to change it more often, which would almost certainly mean moving less dirt each time, so it would probably be faster due to the more frequent moving of portions of the dirt. There is not really a "productivity target" for the racetrack maintenance, just that I would like to have the dirt-moving equipment at hand, so I can use it whenever I want. I guess there is no harm to point out that there are pictures and vids of my racetrack at outbackrc.com.
I am certainly going to study the suggestions, and I am glad to hear that a small backhoe might take out a 20-year pine stump. But definitely like to keep refocusing on small price targets as much as possible.
/ Barlow Feedback Sways Towards Kubota #5
I would recommend a B2620 or B3200 with hoe and thumb. That rc track looks fun. With all of small bumps and jumps, I think you would appreciate the manuverabilty of the small B versus the L series
/ Barlow Feedback Sways Towards Kubota #6
I would also suggest a toothbar for your loader. Your jumps look like they are faily hard packed and the toothbar would help immensely in breaking them up and moving the dirt. The more I look at your track, I'm sure the B2620 would handle your track chores very well. I box blade might help in smoothing things out too.
/ Barlow Feedback Sways Towards Kubota #7
Yes, the more I look at you track, a box blade and loader would do wonders in altering the topography of your track. You don't have alot of large piles to move, just smaller ones.
I may not have mentioned that I could also stand to maintain my gravel driveway, so maybe a boxblade would help there.
I did a quick scan for pricing on a 2620 setup with FEL and BH and thumb. An example was almost exactly 20K. So maybe I would delay the backhoe until later, after trees are cut and hauled off. Definitely don't like getting up into the 20K range so much.
Sorry if this is a silly question, but I saw folks putting the 3200 QA and forks on the front of a 2620. Would it be "practical" to lift tree stumps out of the ground by sliding forks under the major side roots, keeping in mind the small/medium-sized trees and the soft soil?
/ Barlow Feedback Sways Towards Kubota #10
I doubt you could get the stumps out with a set of forks. Better to get the hoe now than later, it will be cheaper in a package deal. You said you would be paying cash, but taking advantage of the Kubota's free money is always an option. With as much ground as you have, you will find all kinds of uses for a hoe.
/ Barlow Feedback Sways Towards Kubota #11
Well put!
I himhawed about getting a tractor with a backhoe...now I will always want one!
Deano
/ Barlow Feedback Sways Towards Kubota #12
Around my area, you can rent a backhoe for the weekend for a reasonable price which is what my brothers do.
I am a stickler on the cash. Maybe a used one will appear, or some ideal circumstances will come together. Maybe a cash discount.
I only risked asking about lifting out a stump since a friend's grad-all telescoping lift was able to lift one out with a chain tied around the trunk.
Discounts for packages, such as the backhoe are compelling.
Good point, too. I rented a skisteer once, was rained out, got no work done, and lost out -- no re-do from the rental place.
/ Barlow Feedback Sways Towards Kubota #15
I'm with MDM....... smart man. I also recommend the hoe WITH the tractor at purchase, it will be cheaper to do it all at once (than add later on). If the backhoe puts you in a price range thats a little tough to swallow, why not finance a few thousand at 0%?
/ Barlow Feedback Sways Towards Kubota #16
Just depends on how much you will use one; even a rain out or two or three
is a LOT cheaper than buying one. We had one for years; still do, but we don't use it enough to keep it up in shape, so we just rent one when needed.
I can afford to buy one; just won't need it, so I will keep my money. Of course in addition to my Kubota, I do have a 80 HP with FEL that will get stumps and such out if needed.
Your situation my dictate otherwise.
Did I mention that I hate to spend money...
/ Barlow Feedback Sways Towards Kubota #17
Without doing an in depth analysis it looks like you want to push some dirt around several times a year, maintain 200 to 400 trees, maybe a driveway.
And you are about as cheap as I am.
Without the "farmed by farmer" land youve only got 5 acres.
You don't need anything big. Look for a used B7800, or go smaller w/ a B7610 (like in my pic). A BX MIGHT do the trick but I consider the ones under 23HP on the small side. Get a box blade and log arch.
I'd recommend a backhoe, but as far as I'm concerned they are a waste of money, and that's how I want to waste my money.
/ Barlow Feedback Sways Towards Kubota #18
I seen a b26 on net for low 20's in the your area. it would do it all or find a b21. If you buy a BX it think you will be disapointed go for a b or l with hydro.
Obviously, I waste a little money -- racetrack in backyard....
But what's the "log arch"?
I would like to smooth out the turf, as is was never finish graded everywhere. Then there is the "bury the concrete" project, where dirt is dumped on top and need to be smoothed over. But, you're right.
On another reply, it's not that there is a shortage of money on hand, but rather a limit to the amount I can justify for the mission, so any financing will still take away dollars, just later on. On the plus side, with the chipping-in we do at the racetrack, there is a certain level of expense that can be justified, purely from that hobby alone, perhaps mitigating 2K to 3K per year of expenses
/ Barlow Feedback Sways Towards Kubota #20
Log arch - to trail logs
Definitely get the box blade.
YouTube - Norwood Industries SkidMate - Tree Felling Jack - Log Skidding Arch - MultiMate
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 Kia Sorento AWD SUV (A59231)
2015 Kia Sorento...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
2012 FREIGHTLINER CASCADIA SLEEPER (A59905)
2012 FREIGHTLINER...
