Grading Rear blade?
   / Rear blade? #1
YotaBota
Winnipeg, Manitoba, Canada
2009 Kubota BX25
I was planning to be plow snow this year with the FEL on my BX, BUT that's not very efficient. Spending another couple grand on a snow plow is out of the question this year. How well does a rear blade work? Eventually I would like to get a snow blower but until then.....
   / Rear blade? #2
Like you, I started plowing the driveway with just the loader and it didn't take long for me to get a rear blade. For the past 22 years I have been plowing my driveway with a Kubota L2550, front end loader and rear blade. The rear blade cut's the time in half and allows getting close to walls, doors etc.
This year I sold the L2550 and replaced it wilh a B3200 with a FEL. I did get the 63" snow blower for it and still use the rear blade as well. Just be sure to get one wide enough to go beyond the rear tire width.
   / Rear blade? #3
Only problem I found useing rear blade..can't push snow banks up/pile higher,maybe the fel can do that.
Little hard on the neck and moving around in seat.
I use my rear blade for pulling also scraping snow.
   / Rear blade? #4
What kind of driveway surface and how long and how much snow do you get?
   / Rear blade? #5
Rear blade and FEL has worked fine for me for the last few years, though I'm thinking of adapting a front blade on my B2710 over next summer. I've seen a few others do it on TBN and think it may be just what the doctor ordered for my 200' drive.
I also like the idea of putting an ABS or HDPE pipe on my blade or FEL to prevent digging in on my gravel drive. So many good ideas, so little time...
   / Rear blade? #6
Sixgun.
"Rear blade and FEL has worked fine for me for the last few years, though I'm thinking of adapting a front blade on my B2710 over next summer."
Twice the fun in half the time:)..and you can really pile snow.
   / Rear blade? #7
I'm thinking of the frame mounted version. I've got a friend that welds so I was thinking of fabbing it myself using my grinder and bolts, then having him weld it together. Then I'd but a double action cylinder for the lift function and add this to the front of my 'bota and then, well..I'd be ready to do some real damage.
   / Rear blade? #8
One of the limiting factors to a rear blade is the weight of your tractor versus the weight of the snow. I have had heavy, wet snow simply push the rear end of my b7100 sideways.
The snowbanks might be a problem for you where you are. Here it snows for a bit then gets nice and everything melts then snows again etc etc. The FEL does work to push the banks back but it is kinda slow work.
If you get a rear blade make sure it is wide enough to cover your tracks while set on an angle. I use a 6' blade on my b7100 and it works good for snow.
   / Rear blade? #9
The combination of a rear blade and FEL is great for places that get moderate snowfall amounts. Use the blade to push or pull snow, then use the FEL to clean up and stack piles.
If you are working on pavement you can face the concave (front) side of the blade in the direction of travel (either going fwd or reverse) and angle it to one side. I have found that reverse works better if the snow is heavy. Less chance of the rear end kicking out sideways. But if the snow is dry, it is faster to pull it going forward.
If you are on gravel face the convex (back) side of the blade toward the snow and push in reverse. This way the blade will float over the gravel instead of digging in. If the snow is heavy the blade may not have enough weight to stay down. In this case, you will need to periodically empty the blade to keep the snow load light enough that the blade doesn't ride up and over the pile.
Of course, if you live in the great white north all bets are off using a blade. There, the blower is king.
   / Rear blade? #10
Having a rear blade on a BX is not the same for a B or larger I think. You need a rear blade heavy enough to make a difference in wet driven over snow. My rear blade is 4 foot and on the BX I think its 1 foot too small. I hung all the chains I had onto the rear frame of the back blade for more downpressure. I think If I gotten a more heavy duty type and and at least 5 foot would be goodd to go. However it was great for scraping off the snow from blacktop to get the ice off if I turned the blade rearwards and go sllllllooow backing up.
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
Willmar 4550 Wrangler Articulating Loader (A56435)
Willmar 4550...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55787)
Toro GreensMaster...
Kubota RTV X900 (A53317)
Kubota RTV X900...
2015 Chevrolet Silverado Pickup Truck (A55315)
2015 Chevrolet...
