2002 F150 for towing
/ 2002 F150 for towing #1
mjonesnh
Tennessee
TC34DA
I am considering Purchasing a 2002 F150 XLT with automatic transmission and 5.4 liter engine with 3.55 rear end. This is a one owner truck with 38,000 original miler already equipped with trailer hitch and brake controller According to owners manual this combo should b good for 8300 lbs trailer weight. My trailer and tractor weigh approx. 6500 so I should be ok there. Has anyone here on TBN towed with this truck combo before?
/ 2002 F150 for towing #2
mjonesnh-Before I bought my 2002 Super Duty, I had a 1998 Ford equipped as you described. I only tow my 17 foot boat, and I thought the 5.4 L was gutless for towing on anything other than flat ground. It would bog down on the slightest incline. It might work for you for occaisonal use, but if you do alot of towing I would get something beefier. Regards, Mike
/ 2002 F150 for towing #3
I owned a 2001 F-150 Supercrew and towed this with it. It only got 5.5 mpg on a trip to Lake Cumperland Kentucky and back and had to use 4 wheel Low to get it up the ramp. I was over weight at around 9,500# with this load. That is when I went to Diesel for my real loads.
I am a boat dealer and have access to data for all trucks and did not see that tow rating listed for a F-150. What cab is it, bed, and also 2 wheel or 4 wheel drive?
I will say I have had tons of gas powered trucks over the years, mainly Fords, one Hemi Dodge, and my new truck, a Nissan Titan and they are all about the same. The Titan will walk all over the others in acceleration but gets a little worse MPG. The 3.55 gears are going to make it a dog. All my gas trucks had 3.73's or 4.10's so it was much more livable.
Chris
(I am a boat dealer and have access to data for all trucks and did not see that tow rating listed for a F-150. What cab is it, bed, and also 2 wheel or 4 wheel drive?)
Below is from owners manual
5.4L 3.55 5897 (13000) 3765 (8300)/
3628 (8000)
The (13000) is Max GCWR and the (8300) is MAX TRAILER WEIGHT
SuperCab/Super Crew 4x2 w/automatic transmission
4.2L 3.55 4530 (10000) 2495 (5500)
4.6L 3.08 4530 (10000) 907 (2000)
4.6L 3.31 4763 (10500) 2676 (5900)
4.6L 3.55 5216 (11500) 3130 (6900)/
2994 (6600)
5.4L 3.31 5443 (12000) 3311 (7300)
3628 (8000)
5.4L 3.73 6124 (13500) 3900 (8600)
5.4L 4.10 6803 (15000) 3900 (8600)
/ 2002 F150 for towing #5
I do not doubt you. My book shows the second number only of 8,000# tow rating. Not a major difference. 300# is not going to mean a thing.
I will say the worst truck I have ever used to tow with was my 2 wheel drive F-150. That thing got stuck everywhere. In Southern Indiana we have big hills and many gravel drives. I could not get up them, especially with a trailer and forget going into a field.
Chris
Diamondpilot:
Thanks for your replies. I did notice the dual numbers in the manual (8300/8000). I believe this has something to do with what size tire/wheel combo was Oem(16 vs.17 inch rims)
/ 2002 F150 for towing #7
Diamondpilot:
I think you hit the nail on the head. My book is just a guide and says to check the manual in the small print. I usually find they give the conservative numbers. Ford offers so many options on tires and you seem like a smart guy. Hey, your looking at a Ford.:D But many do not realize the bigger the tires the less grunt you have and the less braking due to more rolling mass. Because of this you take a hit. Larger tires are like dropping a rear end ratio but Ford has figured this out and corrected the numbers as you stated.
It kills me when you see the guys in a 80' Monte Carlo with 28" wheels but the factory drums and disc brakes on it. The stopping distance has probably doubled when they went to the big wheels. You would think if you can afford to put $5000 wheels and tires on a $800 car you could afford to spend $1000 and upgrade the brakes.
Anyway, I think this rig will do everything you want with your current load. Just make sure it has the towing package. Its more than just a hitch on a Ford. You get a larger power steering cooler and a larger tranny cooler.
Chris
/ 2002 F150 for towing #8
I had an 02 f-150 supercab 4x4 with with 5.4 and 3.73. The truck was a good dependable ride. It was good for towing my atv trailer but not for pulling my tractor. I was towing max cap and as others have said the 5.4 is a real dog when towing. I sold it in 05 with 38k and got a new F150 supercrew with the 3 valve 5.4. It was better but still not great. The mpg was consitent. In late 05 I decided to go diesel and I think I'm done with gas engines for towing.
Matt
/ 2002 F150 for towing #9
My 2001 F150 has the 4.6L engine, 3.55 rear end and is rated at 7200 lb towing capacity. When I moved from So. CA to Sacramento a few years ago, I towed stuff in a twin axle 6x12 ft U-haul trailer with GVWR of 4250 lb. I had it fully loaded. Did OK on the LA freeways, but really bogged down on I5 on the Grapevine and Tejon Pass through the Tehachapi Mts. Couldn't get more than about 45 mph out of it.
These older F150s are not my idea of good towing vehicles. Right now I'm looking for a used Dodge Ram 3500 diesel to do my serious towing (4500 lb tractors with a 20-ft deckover GN trailer).
/ 2002 F150 for towing #10
2 issues with the F-150 you had. First the 3.55 gears. Second, the 4.6L engine. They only made 231 HP and 293 FT TQ. These were 2 valve engines. The new 3 valve 4.6L makes a much better 292 HP and 320 FT TQ. A far cry from the 320 HP and 390 FT TQ the 5.4L makes.
Chris
/ 2002 F150 for towing #11
I tow with a 98 dodge 1500 with electric brake controller and 5.9l gasser.. works good.. also tow with a gmc yukon 1500, 5.3 gasser, electric brakes..e tc.. both of these vehicles should be right near your intended vehicle. for towing 7K or less I've never had a problem.. except feeding hungry gassers.. :)
soundguy
/ 2002 F150 for towing #12
I'm the guy who researches things to death before I spend a dime. I'm learning much. 2 questions. When did the Ford V-8's go to a 3 valve head? Also, someone mentioned getting stuck alot in 250 & 350's. Am I correct to assume they are attributing this to being nose heavy because of the diesel?
What is a good later model GM V-8 p/u for moderate towing duties? (other than the 6.0)
Chris
/ 2002 F150 for towing #13
The Duramax.
/ 2002 F150 for towing #14
The issue with the Ford Superduty line is it has a solid front axle. This is the only way to go for jobs like heavy towing and hanging a snow plow off the front. The down side is it does not do as good in mud and snow but is rock solid strong. Also as you mentioned its heavy.
Trucks like GM's, Toyota Tundra's, F-150's, Nissan Titan's, ect have independent front suspension and is much better in snow and mud but not as bullet proof and not as good of a setup for heavy towing or snow plows.
The 8.1 gasser and the Dmax are the only way to go in the GM trucks. Unfortunately the stopped making the 8.1. Ford has the 6.8 V-10 which is a good motor but a gas hog also along with the Powerstroke. In the Dodges they put the Hemi and the Cummins. Cummins is great but the Hemi is not a truck engine and not a good choice for truck work. Its a good race engine.
Chris
/ 2002 F150 for towing #15
The load our OP is intending to tow is well within the range of the truck he is considering. As most of us know, I have been a Ford man all my driving life, but recently bought a 2500 GMC. I have, like Chris, had some experience with the 150s of the vintage discussed. They tow fine and can handle a 6500 pound load without difficulty. The Ford 5.4L engine is simply not a very good towing powerplant. Unloaded it does well, but towing it lacks the power to pull a pretty heavy 1/2 ton truck and the load without dipping deeply into its reserves and using a lot of fuel. The reality here is that most of us, and perhaps our OP too do not tow that much of our actual driving time. I own a diesel and feel like I tow a lot, but really it is probably no more than 10% of my actual on road time. If our OP is also of this type percentage--or less--he will be fine with this truck. It is not the best out there but is a solid and safe towing machine.
With regard to 2500 level trucks and their offroading prowess, I have found my GMC to be the best truck I have owned in this regard. Generally the heavy suspension and less articulation and the added chassis weight make the 2500 level trucks less good off road than a 1500. Obviously, the best towing vehicle would be anything with a diesel but for our OP it seems a 150 such as his example would fit his needs pretty well, unless he literally was towing all the time. It will struggle on the hills, get pretty poor mileage when towing, but like most Fords will be safe and stable from the chassis perspective. I agree with Chris the Hemi, though powerful for a gas engine, does not tow very well because its powerband and tranny gearing is not well matched to towing duties, unless someone tows at 4000 rpm all day. Those I know that like it for towing either don't really tow much or aren't realy towing much weight.
John M
/ 2002 F150 for towing #16
John M
Very well said.
The GM 3/4 and 1 tons are kind of in a different class than the Fords and Dodges. As you know they are only about 7/8th the size and weigh on average 800# less then the competition. This helps with off-roading. They also utilize the same type front suspension as 1/2 ton trucks being independent and torsion bar. This makes them superior in mud and snow along with the light weight of the D-max as compared to the Powerstroke and Cummins helps. The down side is its not quite as strong, can not handle heavy loads as well, and is not a good choice for snow plowing applications with out modifications.
Anyway back to the 1/2 ton F-150. I feel it will do what you need. Many many of them out there on the road towing all the time. Just looking at the marina where I work atleast 1/2 of the 400 vehicle parking lot is filled with F-150's every weekend. The are a very popular daily driver and family vehicle because of the Crew Cab size especially and can get the job done when its time to tow.
Chris
Update:
I decided to purchase the F-150 as this truck is in "almost new condition". 38,000 miles on a 8 year old truck in my area is almost unheard of. I still have my 1995 Dodge Ram 1500 5.9 liter that will be my primary tow vehicle. This truck has towed the 6500 pound load for several years without complaining.
The majority of my towing is a 35 mile trip one way to the farm 2-3 times/month. Not very far but some of the hills can be demanding. I personally believe the Ford can handle this trailer without undue strain, but for now the Dodge will still be my "farm truck".
/ 2002 F150 for towing #18
Update:
The 5.4 Ford and the 5.9 Dodge are very similar motors. Both have good low end torque and develop a good amount of it, something like 80%, below 2000 rpms. I think you will find them both similar in performance and that the Ford is a little better on the chassis and brake end of things.
Sounds like you made a good buy. Now we need pictures.
Chris
/ 2002 F150 for towing #19
Chris, Thanks for your input. On an aside, I still feel the GM trucks are towing monsters. I would have to say this current ride for me tows as well or better across the board than did my 2008 Ford 250 and is better to drive everyday. I suppose the size of the truck is largely a function of its sheetmetal, but I agree they are a little lighter and perhaps more susceptible to winds and load shifts--I just have not experienced that and the power is certainly there in spades. As for the not "as strong" part, I would have to differ. The Duramax/GMC combo I am running so far has been pretty darned strong and is a real upgrade from the 2006 model I drove when looking once before. It also still has the highest factory torque and horsepower numbers of any of the big three and the transmission is really nice. I have not had much seat time in the Dodge 2500 but I must say the couple examples I have driven did not leave me overly impressed. My Ford was a great towing machine and nice on the open road but was not nearly so nice to drive everyday.
John M
/ 2002 F150 for towing #20
Also Chris, one more thing, I think you might have been mainly referring to the front suspension more than the GM truck itself. I agree with you there, too. The solid front axle trucks are the way to go pulling heavy loads and or doing snowplowing work. The problem is the drive like crap, ride roughly and many times have numb, slow steering to achieve 1000-1500# more load and axle capacity. To those that tow super heavy every day, the compromise is worth it, but to me as an occasional tower it is not. I have not been able to find yet any measureable difference in my truck's front end stability when towing heavy v. my Ford. I do not run a snowplow so maybe there would be a difference in that, but again, even in high snow areas many folks don't plow as much as they perceive they do.
John M
2014 Bobcat T550 Compact Track Loader Skid Steer (A61567)
2014 Bobcat T550...
New/Unused SD Lanch EDLL Mini Skid Steer (A61166)
New/Unused SD...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
2018 Ford F-150 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
2025 SDLANCH IRET13 Electric Tricycle (A60352)
2025 SDLANCH...
1660 (A59213)
1660 (A59213)
