Help Needed: How to split huge rounds
   / Help Needed: How to split huge rounds #21
Trust me, I still cut and split. I do about 5 truck loads a year. Just nothing too heavy.
Chris
   / Help Needed: How to split huge rounds #22
Here is how I do my large rounds. Set the splitter on the ground, roll the rounds on and quarter them. From there I can put my 4-way back on, set the splitter back on it's stands and 4-way the quarters.
Andy
   / Help Needed: How to split huge rounds #23
+1 on the "digging in" method for horizontal spitters on large rounds. I've used this method before on someone else's unit. Work smarter, not harder. A lot of pieces to be had in a 30"+ round, if I cut it going to find a way to use it. But I do see why some decide not to mess with 'em for their body's sake.
All that said, when looking at splitters one of the first things I consider is the ability to operate vertically as well as horizontally for this very reason. I would also caution on the use of skidding tongs in a lifting situation, can be done but don't put anything underneath you are not prepared to crush (yourself included).
Chainsaw quartering is viable method as well for "hard" hardwood (i.e. oak, S. Maple, etc). Start a cut (with grain) a few inches into the round, through the sapwood and finish with a wedge. Oak/maple/etc usually will pop apart no problem. Softer species may not be worth the effort though as they require more cutting................unless you enjoy making long curly saw chips.
   / Help Needed: How to split huge rounds #24
I was hoping to just hoist these onto the splitter with the loader........ but on second thought........................................ :eek:
You guys giving away the big rounds, I wish you were near here. :(
   / Help Needed: How to split huge rounds #25
Since our splitter is 3pt, we opted to lower it down, and 'quarter' them up, then lift it back up, and put the legs back on.
My Dad on the splitter...
Don't have a loader, but I guess a cherry picker would work the same, or block and tackle.
Works for us.
   / Help Needed: How to split huge rounds #26
Hey Will, a short piece of PVC pipe say 1 1/2" slipped over the valve handle will help with the bending down aspect. I use a piece on my tractor mt 3point splitter. Makes a big difference in the old man back syndrome.
tom
   / Help Needed: How to split huge rounds #27
Well, we don't have hard wood here (bummer), but my preference is 8" and under wood. One split is enough, if needed. I usually can't be that selective -- but nothing over ~18". A size I can handle, and not too much for the chain saw if it has knots (to cut it in half). I usually use a Chopper1. Not much help on large stuff. Sweat boy, sweat! And nothing wrong with the thermostat (good thing wife doesn't monitor my posts).
Tip a friend of mine showed me to decide when the chain is dull: A sharp chain makes nice chips. A dull one makes almost sawdust sized ones. Look at the chips with a freshly sharp chain for a reference.
Lots of good ideas here though, especially if I ever get a splitter.
   / Help Needed: How to split huge rounds #28
nothing fancy hear
2-3 wedges a sledge some safty glasses and a splitting mall have busted up 5-6' dia rounds for me in the past.
if its something nasty to split i just take a quick sec to slice it half way through with the chain saw and then its no prob to pop apart.
   / Help Needed: How to split huge rounds #29
Ditto what Schism said. Just because you have a hydraulic splitter doesn't mean you can't go all old school on those rounds. Wedge & sledge is fast and fun. I have had good luck with just a splitting maul. Cheap, too!
-Jim
   / Help Needed: How to split huge rounds #30
-Jim
Yep, Me too. I can split by hand to knock every thing to a lift able size then the splitter takes over while I catch my breath!:D
TOOLBOX/FUEL TANK COMBO (A50854)
TOOLBOX/FUEL TANK...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
2017 Wacker Neuson ST31 Compact Track Loader Skid Steer (A49461)
2017 Wacker Neuson...
2017 MAHINDRA MAX26XL TRACTOR (A51243)
2017 MAHINDRA...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
S Houle WD-10B Pull-Behind Hydraulic Turf Aerator Tractor Attachment (A49461)
S Houle WD-10B...
