>>>ABRASIVE CUT-OFF or BAND-SAW ??<<<
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #1
BearKiller
I have had one of those generic "made in Taiwan" 64-1/2 x 1/2 metal-cutting band-saws for over thirty years.
It has served me well on countless projects, some quite intensive, such as building a deluxe fully-equipped 20-foot goose-neck live-stock trailer.
I have never used one of those H-F abrasive cut-off "chop-" saws.
How do they compare to my band-saw for general purpose cutting of such things as 1-1/2 x 3/16 angle-iron ??
I figure the abrasive wheels would be short lived; am I right ??
What can the "chop-saw" do that my band-saw can't ??
Is the chop-saw quite a bit quicker ??
Thanks.:)
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #2
This past year I gave my son my band saw from Harbor Freight. I finally went and bought a " good " one at a local tool supply. It is not a US made, but as high end as I could afford. I am totally happy. It came with a sample piece cut off an 1 1/2" piece of round stock. I put a mic to it, and it was within a few thousands of perfect. I have used it for months, and am still on the stock blade. That is a big deal compaired to the old one. The main thing I like about a band saw over a chop, is that you can open it up and "free style" cut. That is not possible with a chop type. The chop saw is fast but not as neat or accurate.
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #3
I have found that abrasive saws are best for thin tubing, anything heavier than 1/8" and they take forever to make the cut. I too have had the Taiwan 64 1/2"x 1/2" band saw since 1982, still works good. But in recent years have upgraded to a bigger band saw and to a Makita metal cutting chop saw. Makita Cold Cut Metal Saw I have used the Makita on as big as 7x4x3/8 wall tubing. Takes right about 1 minute to make the cut.
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #4
I have an abrasive Chop saw and small die grinder type abrasive cutters. I recently tried the Harbor Freight hand held cold saw and I am amazed at what that thing will do.Here is a link to the thread that I started on this saw. I cut that red piece of metal that is in the picture in a much shorter time than it would have taken with the abrasive chop saw. http://www.tractorbynet.com/forums/customization/157375-have-you-tried-hf-metal.html
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #5
a chop saw will be much faster on stuff like 1 1/2 x 1 1/2 x 3/16 angle, and they do well on heavier metal too, but do have limitations with width, too much surface area of the wheel in contact with material makes em very slow. chop saw is really noisy, and dusty. one place where a chop saw really excels in my opinion is rusty dirty material that would dull a band saw blade. will also allow you to cut material that is so hard your band saw wouldn't even scratch it. on the other hand, i love my band saw too. suffice it to say that one complements the other.
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #6
My biggest concern with abrasive chop saws is sparks going everywhere. Do you have a way to control where the sparks go so you don't have them find their way into something flammable?
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #7
I've been thinking of getting a bandsaw for metal cutting. I'm on my second Dewalt cutoff saw, my first one lasted just over 1 year and the armature where the brushes are started arching. The armature was ruined but the brushes still looked new. My second one is a bit over 1 year old now and is showing the same symptoms. My neighbor also bought his first one about the same time I did and his did the same thing. He ordered a new armature for his and it also did the same thing. I don't abuse mine but do use it and don't force it to cut fast and not really heavy stuff. That does seem to be a problem with that brand.
I do think a bandsaw is a better way to go now and you'll also not get the sparks flying everywhere out the back. You could make a barrier behind the say to somewhat contain the sparks since it does put on quite a show while cutting.
Topstrap
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #8
The main advantage of the abrassive chop saw is portability. For anything else else band saw is better.
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #9
I have never found the excuse to spend the money on a band saw,because the chop saw is far more versatile. Gotta get to work or I would give some examples.
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #10
Yes, the cut-off wheels are fairly shortlived but can be replaced for about AU$3-5.
Doesn't take much to get a band cutting crooked and then you're up for AU$30 plus.
I agree chop saws are messy but they handle just about anything you throw at them.
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #11
I've got an old DeWalt Chop saw, and it has served us well. It has to be 15 years old, and still going strong. It has cut a LOT of steel..!!
If you do get one, don't be afraid to spend a little more for a decent cut off wheel. I soon found the DeWalt blades last 4 times longer than the generic "Made in China" ones. For about the first inch on a generic blade, they cut great. After that, there seems to be very little abrasive. The DeWalt's seem to cut well, until they are worn down to the point, where they won't reach to cut anymore.
I have been know to use those blades in my HD Industrial Black& Decker 8" angle grinder, to cut light tubing, not possible to put in any saw...
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #12
There are best suited uses for each, band saw and chop saw.
light gauge tubing the chop saw is better. as the teeth break easly on a saw. the abrasive disks/wheels make a mess but work well enough as designed, work well for hard stuff but not as well for solid thick stuff round stock over 1/2" or bar stock over 1/4" thick the abrasive will/can clog up and burn/melt some, you need to keep a edge close by to knock off the BURNT cutting edge of the chop saw abrasive wheel to keep it cutting in heavy/thick stuff..
Mark
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #13
The cutoff saw will create more dust and noise. :D
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #14
Another thread mentioned an HF or NT metal cutting circular saw. It was very inexpensive and had a 7.25" blade. My BIL gave me his worn out Makita mitre saw, which I rebuilt, but it has a 10" blade, so no go on the metal cutting option. Then I did some snooping around and found these:
http://http://www.toolcenter.com/LENOX_circular_saw.html
Pri$y, but they have 10" & 14". If I end up doing a lot of welding I think it would pay for itself in quicker/ cleaner cuts , less heat affected area, less grinding for fit-up, less dust , and less time spent changing abrasive wheels. Depends on how long they stay sharp and I have to check if my miter saw spins at 5200 rpm.
-Jim
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #15
IMHO - Keep your band saw for cutting angle, or up grade your band saw to a larger one with adjustable hydraulic blade lowering control and coolant / lubricant pump. I had a small one like yours for almost the same amount of time, I finally wore it out. I bought a new 12" X 7" saw with coolant pump and adjustable hydraulic cut control. My blades now last a very long time, I really like using that saw.
Cut hardened steel like induction hardened cylinder rod, hardened grader / scraper blades, spring steel, cut hydraulic hose. I use mine mostly for cutting hydraulic hose as I make my own lines using re-usable hose ends.
It can be if you really lean into it. Blade life will suffer considerably if your in a hurry.
Larry
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #16
Does it work better than an abrasive cut off saw? Yes I have not used my cut off saw since I bought the $100 metal cutting cold saw. It is hand held I might add. I will buy a chop type cold saw when they quit asking $400 saw for the Chinese made stuff.
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #17
I use steel cutting wheels in my table saw with excellant results. Even up to 1/2" plate. Just made some nice replacemnt PHD teeth out of 1/4 stock. I have a Milwaukee cutoff saw but have not used it that much. A used Craftsman table saw goes for $25 - $50 on Craigslist... Sometimes its nice to have a long, straight, square edge on a piece of metal for reinforcements, pipe, blades and castings. Using the fence, guide and miter helps with making duplicates of your work.
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #18
I have both band saw and chop saw.
I use the chop saw for everything possible, then go to the band saw.
Nice thing about chop saw is when doing heavy tube, like for a trailer, you can do it all on the floor. No hoisting it up to the band saw.
I free hand angles all the time on my chop saw. Also notch, with grinder touch up.
Be sure to get a 14" unit, and I have found the "thin" blades work the best. When needed I have been able to get my chop saw cuts within .010". Plenty close enough for most all fabrication.
I hadn't thought of the ability of the abrasive chop-saw to cut the hardened stuff that would turn the teeth backwards on a band-saw blade.
That alone would justify getting one.
The rich guy down the road has a DEWALT saw very similar to the MAKITA pictured here :
He has his mounted in the center of a very long steel table, probably sixty-feet long, with a funnel/chute for the cuttings to make their way to a scrap bin.
How does one of these "cold saws" compare to the abrasive chop-saws ??
Thanks for the many replies and input.:)
/ >>>ABRASIVE CUT-OFF or BAND-SAW ??<<< #20
Day and night with minimal sparks.:) I also have a Milwaukee abrasive saw and have used the cheap blades along with the more expensive ones, I am not real happy with any of them.:( If you are cutting very thin tubing, then the abrasive saw is good, but anything else and you are better off with one of the other saws. These cold saws have their limitations also, I would say that they shine at cutting material that is 3/16-1/4" material. Blades will hold up for quite a while cutting that thickness of material. I have used it several times cutting 3/8" tubing and angle, but it takes its toll on the blade. My bigger band saw works best on the heavier material.:D There are many saw blades made for different types of material, it is always best to use the proper blade for the material being cut.
Just my experience with what I have and use. ;)
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2018 BOBCAT E45 EXCAVATOR (A59823)
2018 BOBCAT E45...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
Bell 1600 Gallon Nurse Trailer (A61307)
Bell 1600 Gallon...
(10) 24' Free Standing Panels w/8' Gate (A60463)
(10) 24' Free...
