Need help
/ Need help #1
colonel54
White MT's of NewHampshire
John Deere 425 & LX176 & Mahindra EMAX20SH
I have a JD 318 with mower deck and plow I picked up last year . I want to take the deck off and put the plow on it . I had a friend do this for me last year ,but he is no longer available
I have looked at it and every thing looks easy enough . But would like some guidence .If the deck was not there I could put the plow on ,as I figured that out . Also do I have to remove the mule when I take the deck off .?
I love this tractor it is better then some of the new stuff thats out there
Thanks in advance
The Colonel
/ Need help #3
Take the mule drive off! Without the mower deck attached it will fall off anyway. Make sure you also remove the lift brackets under the tractor and store them with the mower.
Once you get the mower off, the plow fits on the front frame pretty easy. The hardest part will be lining up the frame of the blade with the frame of the tractor and getting everything latched on. Doesn't take very long, but your first time will be a little bit of a struggle.
/ Need help #4
Yes! What he said.
/ Need help #5
Doh! Sorry, too early in the AM for me. Indeed, take the mule off if going to a mower.
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
Ford N Series Tractor (A66285)
Ford N Series...
2008 Ford F250XL, Crew Cab (A62679)
2008 Ford F250XL...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
