powering a log splitter. ideas?
   / powering a log splitter. ideas? #31
my log splitter, has a 4" cylinder, (you want as heavy of a shaft in the cylinder as you can get), no fun bending up a new or even a old cylinder, (wish I would have gone with a 5" or a 4.5" at least),
I have a 24" stroke, I have about 2" from the end of stroke to the wedge,
my wedge is on the end of the I beam, that way it just keeps pushing the wood out and away from the splitter, (it more or less does it own house keeping),
you do not have to retract the cylinder all the way, if you do not want to, on shorter logs, or stack two to split at once,
I ended up adding some supports or a table like situation on each side of the I beam, I made it twice as wide on the opposite side of the valve, that way I have a place to set the split log for respliting, and it lets the split log fall open and then off the end of the machine,
at first I had it as a three point and used the tractor as the power unit, and it was fine when diesel was under $1, but when I started to figure what it was costing me a few years ago how much it was taking in just fuel at nearly 5 gallons an hr, the price of the motor and pump did not look so bad, (I actually payed for the motor and pump in fuel savings in less than one year ,my SIL used wood heat as well and he sold some also), and when you look at your SUV, it will burn most likely 4 gallons an hr, where the small engine, will usualy burn about gallon, or less,
yes they make hydraulic pumps that have a electric clutch like an air conditioner pump but if you look in to one of them your not that much savings in comparisons to the (Honda copy engine and a two pressure log splitter pump), Hydraulic Clutch Pump | Pumps | Northern Tool + Equipment
you have two basic costs your building cost and your operating cost, for the most part the operating cost will be fuel, but say you run your splitter for 40 hrs a year in your fire wood business, off the SUV, 40 hrs at any RPM would be some what like driving it , 2000 miles, (if the RPM were close to traveling 50 mph), now even at $3 a gallon if you get 20 MPG that would $300 in fuel operation costs and were on a car engine,
and you will have to have the SUV and the splitter next to each other to work it, plus the modifications to the truck, now if you use a Honda copy motor some of them are reasonably low cost, here is a 6 hp from Northern, Powerhorse 208cc OHV MaXX Series Horizontal Engine | Powerhorse | Northern Tool + Equipment for $150,
the other Idea that across my mind is if you can find a old lawn tractor and pull the motor off the tractor, and use it there is nothing that says you need to use a horizontal shaft motor to power the pump, for the most part even the small law tractors are 9, 10 hp, and many times you can get them for next to nothing, or even given to you,
If it was me I would either vote for a electric using a 2 hp motor with a matching pump, or step up to the heavier motor and go for some speed, I have a 9 hp and matching pump and with the two speed pump there is very little wait time, and with the detent log splitter handle one can put the handle in the return position and it will retract and pop to neutral when it hits the end, of stroke,
IN my building experience, I think one is better off building it to what you want the first time, even if you have to wait or it cost more than one wants it to, than to under build it or not built it big enough or with enough power or cylinder, it will end up costing much more in the long run,
Im not exactly sure what i want yet, so i think i am going to build a small one with the 2HP motor and a small 2 stage pump. then decide on what cycle time two people can barely keep fed and build one using this ( Hydraulic Clutch Pump | Pumps | Northern Tool + Equipment ) or similar one to run a 5" cylinder and 4 or more way wedge. i don't think that there is any way that a 10HP motor could run a pump like this at 20gpm/2500psi.
   / powering a log splitter. ideas? #33
The advice of the post above is good advice - It makes no sense to use a 150 HP motor in place of the 10 - 15 hp motor you need. I have a 65 HP tractor and will not even use it to run my log splitter because it is an all hydraulic tractor so the rpms will be higher than a normal geared tractor.
i have a Tecumseh 10 HP vertical motor off of a small garden tractor and that is my backup if the 5 HP electric does not work well. I have a 24" 24 ton gas splitter (5 HP i believe) that i can take down into the woods. But i really want a 28" or so long one that is electric so i can split at night or in the morning without bothering neighbors down the road.
And the pump you are looking at costs more than buying the two stage pump and a cheap new or decent used gas motor.
Ken
i might have put the wrong link in this is the one i meant to use High Pressure Hydraulic Clutch Pump — 2.32Cu In. | Pumps | Northern Tool + Equipment
for those of you who use a 4 way wedge and a 2 stage pump, how many inches of the stroke is it in hi pressure mode?
How much maintenance is a 15HP engine going to be, and where should i look to buy a used one. i will have to ask some friends that live on farms if they have anything laying around they would sell.
Payton
   / powering a log splitter. ideas? #35
it is in low pressure until it hits some thing that cause it to load and then the smaller pump is the only one pumping, and then gives you the pressure to split, with,
example: if there is nothing on the splitter the low pressure high volume pump is the one pumping, and the cylinder cycles fairly fast, but if you put in a log or load the system, then it kicks down to the high pressure low volume pumps side, and continues to work.
if you have a 10" log then it will travel up to the log in fast and then slow, if no log in it will travel at fast all the way and return in fast,
if you put in a log say 24" long then it will hit the log and then kick in the slow mode.
but will return in fast, or low pressure mode, unless some thing is jamming it,
hope I made sense.
If it was me I would use the log splitter pump with the hi and low in it, and you will do fine if you match one up with a 10 hp or so gas motor, (there are a number of different pumps) the larger the cylinder most likely the more cubic inches in the pump which means more HP in the driving motor.
https://www.surpluscenter.com/sort.asp?UID=2009120523083523&catname=hydraulic&keyword=HP2S
I have a 9 hp honda motor with a and am either using a 13 or 16 gallon per min, pump, I do not rember, (I am guessing the 13 gpm as the motor does not power down much on a hard split or a stall),
https://www.surpluscenter.com/item.asp?UID=2009120523083523&item=9-7503-13&catname=hydraulic
https://www.surpluscenter.com/item.asp?UID=2009120523083523&item=9-7503-16&catname=hydraulic
and a 4" cyclinder, (the only reason I some times whish I had a 5" is o 24" elm stumps and some crotches), I can usaly work through it in some way tho. With what I have.
I have works very well 98% of the time.
the two pressure log splitter pump it gives one the best of both worlds high speed with high power, it is like down shifting to first in a truck when you hit a hill and have a load on,
with relative low HP requirements,
I would probably suggest the single splitter to Begin with and then add the 4 way as a slip on unit, (it may not work as desired).
and there is nothing wrong with a slower speed when the wood is actually being split, (If mine was the high speed all the time I think it would be very easy to get hurt, with a log jumping out or shattering or some other unseen happening, IMO).
if you chose to go with a separate motor you most likely do not need a clutch the clutch is adding nearly Half to the cost of that unit, and if you can direct drive it, with a flex spider coupler,
(there are many diffrnet types to work with many diffnret shaft sizes and pump shafts)
https://www.surpluscenter.com/sort....=PSF3&catname=powerTrans&UID=2009120523083523
the adapter encloses all moving parts and is the way to do it, if your going to do it with a separate motor.
(there are many diffrnet types for diffnret pumps and motors),
https://www.surpluscenter.com/sort.asp?UID=2009120523083523&catname=hydraulic&keyword=HOPM
your best bet IMO is to copy a premade unit, or some ones here on the board that they like and how to improve it if any.
there is not a need to reinvent the wheel on a log splitter,
what i was trying to figure out was if after the log mostly split, did the pump go back to high speed to push the log through. sounds like it wont though. when you say "separate motor" you mean a motor dedicated to driving the pump and nothing else right?
Payton
   / powering a log splitter. ideas? #37
i might have put the wrong link in this is the one i meant to use High Pressure Hydraulic Clutch Pump 2.32Cu In. | Pumps | Northern Tool + Equipment
Payton
Go to junkyard and get Honda 500CX engine. Those engines are bulletproof, quiet and about 30HP at 6000 rpm (don't know exact numbers) have flat torque curve so they can run nicely at any speed above 3000 rpm. I basically gave my old motorbike away when I sold my house few years back and now I wish I kept it. It was about 30 years old had 30000 miles on it and there was no single drop of oil on the garage floor.
   / powering a log splitter. ideas? #38
Payton
If the log splits and the load on the cylinder is reduced significantly then the unit will switch back to high flow.
Separate motor as in "self contained".
I would match the engine and its rpm design to the pump specs with direct drive, cheaper and easier.
   / powering a log splitter. ideas? #39
Payton
an engine that is for the log splitter, not one on a SUV or other machine, but a motor that is dedicated to the splitter or it's power pack,
on my splitter,since I split elm and it is inter twined it will take pressure to push it all the way, if your splitting some thing like pine or woods that when it hits the splitter knife the wood jumps apart, it may kick back in to high, if all it is doing is moving the split pieces, but if it is still tearing it apart most likely it will keep in the slow mode and on mine that is not that slow,
YOU know if there is a rental in your area, I might suggest you rent one at first and see how they work and what you like and go from there, or see if you can go some place and "borrow" the use of one for a load of wood.
you would have a much better idea on what your looking at and what one will do, and what you will want in yours.
IN my opinion who ever is loading the unit should be the only one running the valve, mine will cut a 3" branch into if layed across the splitter knife, your hand is not stronger than 3" diameter limb, and fingers between the pusher and a log do not fair well either,
The key is not how fast one can split it but to be able to do it safely with reasonable speed, because if all you want is speed you could make one of these widow makers,
YouTube - Clarence's Wood Splitter
or
YouTube - WORLDS FASTEST LOGSPLITTER
It is not worth the lost of hand or limb to make a buck, make it safe and use it safely, just because some one is dumb enough to make and use it does not make smart or wise.
You want to be in complete control of the unit, I can guarantee you that even one your controlling, more than enough things can go wrong and the potential to get hurt is there, some thing that some one else is controlling or has no ability to stop it in an instant, (even if it is fast) is not worth it.
when your business picks up and your need the speed you then look into a fire wood processor, YouTube - firewood processors some of the machines here are really fantastic
or
I understand the safety issue and don't plan to have anyone touching the wood when it is being split. what i ultimately want is to have a table on all sides of the splitter so one person slides the log in front of wedge and runs the controls. the other takes care of the split wood, slides pieces to be resplit back towards loader, and puts rounds on table.
I don't expect the 2hp electric to keep up with this, but i don't think the cost to build a small one first will be to bad, and im sure i can find a good use for the hydraulics if i end up never using it after i get the big one built.
Payton
207273 (A52708)
207273 (A52708)
Case 930 Tractor (A59814)
Case 930 Tractor...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
2022 Ford F-450 Liftmoore Crane Service Truck (A59230)
2022 Ford F-450...
Cushman Electric Cart (A55851)
Cushman Electric...
2017 Ford F-250 (A55973)
2017 Ford F-250...
