Where is dependable computer help? TBN
/ Where is dependable computer help? TBN #1
gotrocks
Phenix City Alabama
B-2910 delivered 8/23/01
Hi Folks,
Back again with a computer question.
I just pulled out a stack of old CD-R Verbatim 74min 650MB,
They were created a few years back on my old setup using a HP CD Writer Plus.
Now when I attempt to read with my Acer DVD R/RW nothing shows up.
Properties indicates CD is FULL, but no files showing when opened.
What say you? Thanks for any and all suggestions.
Merry Christmas!
/ Where is dependable computer help? TBN #2
You could try a different CD/DVD reader. Perhaps the laser is a bit stronger. Depending on how the disc was handled or stored your data may be permanetly gone. Look here or here.
/ Where is dependable computer help? TBN #3
Are the discs finalized? If not, you may have to finalize them with burner software before you can read them normally.
/ Where is dependable computer help? TBN #4
Hi Folks,
Merry Christmas!
As another user suggested, they may not have been finalized when originally made and are only readable on the original system until they are finalized. I would look into that first.
Any time I make CD or DVD I take them to a different computer and test them to make sure they work.
/ Where is dependable computer help? TBN #5
MossRoad, I agree.
I've skipped by the closing process a few times and each time I kick myself for rushing too fast.
After burning, test on another PC just in case.
/ Where is dependable computer help? TBN #6
all the pc guys have been helping me with my netbooks this week.
soundguy
/ Where is dependable computer help? TBN #7
Does anyone remember when CD's came out, they told us this was the great new info storage tool? Now we find out they can degrade and your data can be lost. Need to back them up every couple of years. (See Kim Komando website komando.com). Now they are not suggested for long-term storage. What will the Japanese tech companies come up with as the next format to take our money? I still have some LP's and cassettes, and a few 3.5" disks. Tried to give away a bunch of cassettes, and few people will take them since they don't have cassette players any more. At least I don't have any more 5-1/4" disks left. Don't assume USB (flash) drives are the solution either -- there is no guaranteed loss-free data storage or music format.
/ Where is dependable computer help? TBN #8
If it is imortant to you, then I suggest more than one copy, on more than one media, stored in more than one physical location.
I use DVD's, USB media and the local bank vault.
/ Where is dependable computer help? TBN #9
in fact.. they are guaranteed NOT to work forever.. flash ram has a finite R/W cycle.
I have a small coffee cup full of flash drives ones back from 64 megs and up that have failed.. not thru r/w I suspect.. but just generic electrical/hardware failures.. etc..
soundguy
/ Where is dependable computer help? TBN #10
soundguy
Yep. They are good for transporting files from one place to another, but not for permanent storage.
/ Where is dependable computer help? TBN #11
The third time through the washing machine is what usually kills my flash drives.
Terry
/ Where is dependable computer help? TBN #12
There is a program called Isobuster that could well help you get at the files. If it reads the disks, you can copy the files to your computer and re-write the files out again to R or RW disks. I have a feeling I have seen freeware programs that may also do the same job. Or even a Linux computer will often read faulty disks I have found.
I have to say with many HP drives there are compatibility problems. It is not just HP mind but, they seem to have more of a problem when read with other drives, at least in my experience.
/ Where is dependable computer help? TBN #13
Terry
at least one of my drives was laundered.. and it was my favorite drive.. it was a usb caddie that held a memory stick, and made it into a usb drive... once thru the wash and the stick died and so did the usb caddy.... :( never say another one..
soundguy
/ Where is dependable computer help? TBN #14
alot of sector copiers will help with recovering discs like that.. at least pieces of files anyway..
soundguy
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
MAHINDRA 2538 TRACTOR (A65057)
MAHINDRA 2538...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
2016 JCB 3CX 4x4 Loader Backhoe (A68183)
2016 JCB 3CX 4x4...
Unused 2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
LINCOLN ARC WELDER (A67714)
LINCOLN ARC WELDER...
