Filling pool
   / Filling pool #1
dodge man
Super Star Member
West central Illinois
JD 2025R
We put in a swimming pool a couple of years ago, and it was kind of a high effort thing to fill it, it holds around 19,000 gallons. You don't have to drain it every winter, but you do have to draw it down quit a bit. So in the spring I have to fill it back up to the top, which is maybe 3000 gallons.
Here is the question, I'm trying to come up with the best way to fill it. We have a good well, but the water is hard and doesn't work as well in the swimming pool, plus I would like to save the wear and tear on the pump. We were suppose to get a rural watermain in front of our house but the project got delayed so any solution I use will be short term until we get the watermain. In the past I have hauled around 250 gallons in a tank in the back of my half ton truck from our city waterplant which has a fill station. The problem is this seems hard on the truck with that much weight and it takes alot of trips. I have a trailer and I could borrow more and larger tanks, but the problem is my driveway. Its about 600 feet long, and has a circle turn around at the house, but the turnaround is so tight I can barely make it in my truck without a trailer. I could back down the driveway but its fairly narrow and has some curves, so I know I would be all over the lawn with my trailer. I could unload the water and just back the trailer up and into the lawn to turn around, but once again, it would leave some ruts. My BX2350 will tow the trailer empty, which is a 7000lb 18 foot car hauler, and make the turnaround pretty easy, but it would be a pain to unhook it from the truck, hook it to the tractor every time, and then hook it back up.
Any ideas on an easier way to do this? I can just do it the way I have in the past which isn't the worst thing in the world, I'm just looking for a way to use the trailer and cut down on the trips.
   / Filling pool #2
(It's easy to spend other people's money...)
I would try to get ahold of an actual tanker truck. There's an excavation company near me that uses a 2k gallon truck to haul water. (They used it to leak test a 6k gallon sewer tank they built for me).
Any chance of talking to an excavation or well-drilling company to see if they could haul water for you? Know anyone with a milk truck?
-rus-
   / Filling pool
When we first built the pool, we also had a neighbor build an even bigger one, and they had trouble finding someone. I also know if you ask the right person on the fire dept. and make a donation, they will sometimes do it. This is one of those times I'm trying to do it myself. If I was completly refilling the pool again, I might try to find someone. Since I'm just topping it off, I'll do it myself.
   / Filling pool #4
Dodge man
If it is a inground pool I would invest in a looplock cover. After you drain down and clear out the lines and plug the returns and skimmer when you close it so water won't get in them and freeze expand and break the lines. The loop lock will let water through and keep out leaves and debre. If you have a above ground reply me back and I can give you some advice on them.
Carey
   / Filling pool #5
Many on and offs are more wearing on your pump then a nice long run. Fill it and forget it.
   / Filling pool #6
Isn't there an old song out there "It doesn't rain in Indianapolis in the summer time"? Collect your rain water before the summer time in the pool. That won't be as hard as well water.....
   / Filling pool #8
what about diverting your gutters so that in the spring the rain water will fill it.
   / Filling pool #9
I was sure this would be a silly idea, so I did the math:
3000 gallons = 693,000 cubic inches
2500 square feet (my house) = 360,000 square inches
WOW! :eek:
It would be less than two inches of rain, if I could divert *all* of my gutters to the task. I guess that isn't nearly as bad as I thought it would be!
If I could divert an inch of rain from my entire property, I would get over 1.4 MILLION gallons of water. Those numbers are really really surprising to me.
   / Filling pool #10
It gets alittle two cold in the winter for me in Indianapolis. IMOP. I would be afraid of a power outage and it freezing up the pump and tank. There is no need to have to run the pump at that low of a water temp in IND. to cold for Algae to form and the cover will keep out leaves etc.
Carey
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2006 Trail King RGN 45ft. Heavy Haul Lowboy Equipment Trailer (A60460)
2006 Trail King...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
