How many hours on your hst transmission no matter who made it.
   / How many hours on your hst transmission no matter who made it.
Late 70's IH2500B. Over 4500 when I got it. In 10 years I probably put another 4-5 hundred on it before I sent it off to the big salvage yard in the sky. The tranny was still running strong. The steering castings, cab, gas tank and sheet metal were trashed and the engine had some issues, but the tranny was just fine. It was a 50PTOHP 4 cylinder gas industrial tractor loader. That is, non-removable FEL on the front and 3PT hitch on the rear. Weighed about 8000#. Was thoroughly abused. ;)
This industrial tractor had an HST transmission. WOW I didn't know they were in larger machines. I wonder now why they are not still used in larger machines.
   / How many hours on your hst transmission no matter who made it. #12
When I was buying my tractor I knew nothing about tractors but friend of my told me that they had fork lifts with HST and they were the most reliable machines. After deciding between Mahindra 3510 and TYM 330 (they are identical tractors except the trany) we selected the 330 mainly because of the HST.
My TYM 330 has about 220 hours 80% of FEL work on it.
I would have never chose a HST except I ended up with this old Cub Cadet that was really used up and I got a good deal and decided to install a new old stock motor and use it. I plowed snow/dirt, pulled wagons and mowed 3 acres with it for about 13 years. I loved the HST because of how much faster it was to change directions. It was the best thing I had ever used on the steep hillsides and I never had to used the brakes. So when it came time to upgrade the bigger tractor (IH424) I started looking at the CUT HST line of tractors. A friend of mine has a JD in the 40HP range and I run it and it felt and responded just like the old faithful Cub Cadet. I feel safer on the hills and again I only use the brakes when I park the machines. I ended buying a L4400HST and a BX1500HST and I feel like they were good choices for what I do on my property.
   / How many hours on your hst transmission no matter who made it. #14
John Deere 4100 with 850 hours.
John Deere 4720 with 75 hours.
All are with HST.
   / How many hours on your hst transmission no matter who made it. #15
They are. Look at articulated loaders.
I also have an HST in my little Power Trac PT425. It only has 350 hours on it. :D
   / How many hours on your hst transmission no matter who made it. #16
330 hours on my L118. Still works like new.
   / How many hours on your hst transmission no matter who made it. #18
1969 IH624 - 8560 hrs ... original "agriomatic" - one of the first generation "HST" made by International in Germany
   / How many hours on your hst transmission no matter who made it. #19
I wonder who makes the Kubota HST.
I think it is made by Kubota....at least I could find no other markings on the
new HST+.
Eaton/Vickers (same company now) may be the biggest maker of HSTs, but
that is only my guess.
If you go to buy a new 20,000# dozer today, it will likely use HST, with
electronic controls.
My B21 project had over 2300hr on it, but more amazing was how good
its HST looked inside. There is a good chance that your HST will outlast
your engine if you keep the oil clean and full.
new HST+.
If you go to buy a new 20,000 dozer today, it will likely use HST, with
Good info dfkrug. Thanks for the post. On the larger equipment like a dozer do they use a swash plate type transmission? If not what design is it? Just curious. How come you had your HST apart.
set of 4 tractor trailer tires Roadforce (A56436)
set of 4 tractor...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56438)
2019 RAM 5500...
