Yanmar 336d
/ Yanmar 336d #1
yanmars
I have had spindle breakage problems with my 336d. I have a front end loader but do not load it heavilly, it is the factory loader. Also now a front wheel seal is leaking badly. Any of you have any similar problems or corrections. I just overhauled the motor and clutch so I do not want to get rid of it but this has been a problem.
/ Yanmar 336d #2
Yanmar made the front spindle in three different ways. Only the heavy duty one is worth installing. Although a little pricey, it is really worth it.
/ Yanmar 336d
I have been unable to locate the spindles now. They may have been discontinued. I bought two from a Texas company but they both broke in less than 10 hours while I was mowing. They were aftermarket made in China and perhaps the heat treat was bad. The Texas Co. asked for one back to exam. They just said I should not have a loader on the tractor. They never told me that when I was buying, never gave me a credit or a new part nor returned my old one after request and I paid the shipping to get it back to them. Frustrating to have a tractor one is now hesitant to use, especially with not many hours since the clutch and engine rebuild. Thanks for the information.
/ Yanmar 336d #4
look at the top of the page and click on the Hoye tractor ad. they should have them, they have about anything, they are in texas but i cant imagine them doing you that way those guys are great. Hoye tractor is there name a google will turn them up im sure also.
-i am not iffiliated with Hoye, just a satisfied customer that wishes to pass his good experience to others they are very helpful and im sure if this stays up longenough Aaron from there will chime in.
/ Yanmar 336d #5
It may actually be us :(. I think I may actually remember something about this. Unfortunately, with some serial numbered 336D tractors there is nothing that we can do at the moment.
There is only one company building those spindles to my knowledge (not from China though). We have had a fair amount of trouble with them but always
1) The customer has a loader installed
2) The factory spindles have always broken too.
We did send a couple broken spindles into our supplier and they said they were not defective & not covered by warranty.
It is our opinion that Yanmar must have had trouble with that design (since they upgraded it two times and the factory spindles are breaking too) and that any reproduction of that "not so great" design will have the same inherited design flaws- they are just too weak for loader use. Until someone reproduces a full upgrade kit including bigger shafts, gears, & gear housings ( I think it was around $600 per side from Yanmar) the problem will never be fixed on certain serial number machines.
We have been warning customers for at least a year when those spindles are ordered so, if you did get them from us it may have been before that.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
/ Yanmar 336d #6
My 169D has a similar problem. it is leaking badly there. Odly enough, the oli only spills out at certain times. it wont leak when im using it but it will leak when it is parked in the garage. In the garage, it will be fine but then one night it will just leak oil everywhere. I have it on newspapers to contain the spills but I have been wondering a few things. Is it hard to get a new seal? Are they very costly? Is it safe to use it this winter for possible snow removal? I would probably bring it down to my grandpa's in january to fix it and since im doing rototilling for some people in town. I dont have a FEL yet so there isnt much weight and i removed 120 pounds of weights off the front end to reduce weight. My yanmar was previously uded by a christmas tree farmer to mow in between rows and do some cultivating. What is the best thing to do?
/ Yanmar 336d #7
I have the YANMAR heavy duty spindles in stock. It is not difficult to convert your early model YM336D to the H.D. spindles. I have converted many of the early and mid production models to the heavy duty system and never had one break. Contact me for info and price.
/ Yanmar 336d #8
Does this issue also affect her sister machine the 3110D?? :eek:
/ Yanmar 336d #10
I'm interested to know what is considered an early modle. I have a 336D with a loader and have moved some pretty large loads with no ill effects. Acording to the stamp on the wheels it is a 1985.
Thanks
Joe
/ Yanmar 336d
I believe my tractor was made about 1982. Its serial number as I recall is 40379. I was told from a reliable source that the serial numbers started at 40000. I do not know how many they made overall.
/ Yanmar 336d #12
Does your tractor, by chance, have the front wheels reversed for a wider stance, (valve stems to the inside)?A major no-no. Incidentally, compact tractors were never designed to accomodate the added weight of a FEL, (a convenient add-on). Those that survive without problems are barely doing so.
/ Yanmar 336d
My front tires are not reversed. The loader I believe is a Yanmar factory unit.
/ Yanmar 336d #14
Still an add-on. Compare to a real front end loader or skid steer, major difference in construction.
/ Yanmar 336d #15
about this loader? how was it bolted onto the tractor? I know when trying to find mounting points for the loader I installed on my Yanmar
I could only find 2 sets of 4 holes on the underside of the transmission, I'm sure these were for hooking upsome sort of belly implements...... most tractors that are readily setup for a loader has bosses built into each side of the tractor, Mine did not!
I had to build up a custom mounting bracket to bolt to the 8 holes found on the underside in order to use a FEL on my tractor, although while building the bracket I also reinforce the tractor as well, so that now the front-mid- rear are all tied together, although this didn't do anything to help with the front spindles and most likely added additional weight to them, I have a Buhler loader takes 5 minute easy quick off and on, I don't plan on keeping the loader connected full time, although the bracket will stay on the tractor, i will only use the loader when necessary, I'm hopping this will ad a little more life to the spindles & bearings,;)
/ Yanmar 336d #16
I had two different 336D tractors with loaders. The first one had the serial no 00029. The powershift lever was on the tranny instead of up on the left side of the steering wheel.
The second one was up there and it had lower gears in 1st. Great tractors, wish I still had the first one. Never had a problem with the front ends and I used the loader heavily. I did not however use ballast in the tires. A tiller or mower out back, that is all.
/ Yanmar 336d #17
My right front spindle broke today. I got on the Hoyes site looking for info. I found this site and lo & behold others are having the same problem. What a relief, but it's not looking like it's not going to be a quik fix??
Just chime in w/ your thoughts.
Thanks
/ Yanmar 336d #18
.....Incidentally, compact tractors were never designed to accomodate the added weight of a FEL, (a convenient add-on). Those that survive without problems are barely doing so.
I think that your opinion on this is way wrong. Some manufacturers do and some don't. It depends on the manufacturer and how they approached the problem. To Yanmar's credit, when they make a mistake they keep working on it until they get it right...sometimes years after the model is no longer current!!
For the YM336D, Yanmar designed the tractor and the loader together but they completely underestimated just how popular the 336d would be as a construction machine. Even today you rarely see a 336d on a farm; it's usually on a construction site. The OEM loader itself is an industrial type - very heavy construction, industrial cylinders and valves, high oil flow, and frankly the front wheel spindles of the farm tractor weren't up to all the bouncing and abuse of the construction world. It was a conceived as a farm tractor with a loader....not a construction machine. That was Yanmar's mistake - which they compounded by offering the tractor with industrial tires as an option.
Still, the 336 was as close as you could get to a dual purpose small machine with real power, and it became a popular tractor all over the world. It was Yanmar's flagship during the 1980s. Yanmar changed the spindle design several times and by the middle of the ten year model run the changes were good enough that spindles were rarely a problem - but leaky seals still were. They finally got it entirely right in 1989 when they issued Factory Technical Bulletin T-079 announcing an optional heavy duty front drive gear for the 336d, bigger bearings, and a heavier spindle along with the associated redesigned seals, collars, and nuts. It was a complete assembly kit. Hopefully some of those kits are still available. The part number for the kit was P/N 794491-14 160x. At the time - twenty years ago - the price was $1,038.56 for a set to do both sides complete.
That kit was NOT a change to the production tractors...it was an optional kit specifically for using the YM336d in heavy construction type loader service.
It would be nice if some dealer would take a look around and see if those kits are still available and let us all know. Drop me a line too if you do; I wouldn't mind having a spare kit myself just in case....
all the best, rScotty
YM165d, YM336d, JD530, and a Kubota too..
New/Unused Landhonor Quick Attach Grapple Bucket (A65583)
New/Unused...
2025 24in Mini Excavator Bucket Attachment (A61572)
2025 24in Mini...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2008 Chevrolet Silverado 2500 Crew Cab (A62613)
2008 Chevrolet...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A61572)
2025 HT360W Mini...
