Front-End Loader FEL Front Edge Float Pipe ... thingie..
/ FEL Front Edge Float Pipe ... thingie.. #1
CowwFace
Gold Member
Conifer, Colorado
Kioti DK45SE HST, 401FEL, RB40-96 pivoting Rear Blade
Hey List,
I don't know if this classifies as a full "Attachment" but here it is:
I was at the scrap metal dealer and saw some 3" steel pipe.. so I snaged an 8 foot piece for about $10.00.
I Cut it to 72" and weled some tang's on it so I can bolt it to the front edge of my FEL. I'm hoping this will keep me from taking all of the "new to us" re-claimed asphalt off of the road when I push snow. I tested it on a section in the yard, and it did not dig up the grass at all <Last pic>. Does this thing have a name? or do I get to name it?
It's suppost to snow 3" here tonight / tomorrow... so I may get to check it out.
I was going to paint it orange... but thought that would be too audacious for such a complicated attachment! <grin>.
Phill
/ FEL Front Edge Float Pipe ... thingie.. #2
Thats a pretty good idea it'll help keep you from digging down to far thats for sure.I put some skid shoe's onto my bucket of my bigger tractor as well to keep from removing gravel from the driveway,especially right around the first snow fall,as it's usually wet stuff and the ground isn't quite frozen yet.Once the ground freeze's it's a differnt story as you can do pretty much anything and it won't hurt it except let the frost go down deeper.Again good idea,As always Larry
/ FEL Front Edge Float Pipe ... thingie.. #3
I like that. I plow our horse paddock which is limestone and I'm always digging up some stone. Post some results after you try it.
/ FEL Front Edge Float Pipe ... thingie.. #4
You get to mane it, but the word "Thingie" must be part of the name
/ FEL Front Edge Float Pipe ... thingie.. #5
I have an 1 1/2 that I cut a slit in and tack to my TLB bucket when I clean out chicken houses. I learnd that from a man that owned a few. I have also used it to clean up where a mobile home has burned after gettin the bulk up with the thumb. I can use the round edge to load up al lthe ashes and fine debris without diving down into the pad. this saves regrading when a new unit gets put in. also good for scraping sloppy mud off the parking lot at work.
/ FEL Front Edge Float Pipe ... thingie.. #6
Phill,
Nice setup, I like it allot. Hope your don't mind if I copy your thingie? Looks like just the ticket for me as well. I wonder if somethingie like that would work on a 84" Dozer blade?
Larry
/ FEL Front Edge Float Pipe ... thingie.. #8
i suppose that will work.....
i still think that the horse mat strips are a better idea
But Schmism... $10.00!! Now with that said I will admit I don't know what horse mat strips are... Are they like conveyor belt like material? or Round Bailer belts?
Phill
/ FEL Front Edge Float Pipe ... thingie.. #11
Hey List,
Phill
You will like it.I made one similar last winter.Only I made it out of 1 1/2" black iron and attached it like you would a tooth bar.The curve around the edge of the bucket really helps it from digging in to. Maybe I'll get to use it if we ever get any snow up here. Tim
/ FEL Front Edge Float Pipe ... thingie.. #12
Tim,
Great idea attaching like a tooth bar, and the 90* bend at the ends is an excellent idea too. How do you bend 1.5" black iron pipe?
Larry
/ FEL Front Edge Float Pipe ... thingie.. #13
Tim,
Larry
I mounted it on the bucket before it was bent,then heated it with torches cherry red and had a crowbar stuck in the end of the pipe and just kept heating and bending.If you have access to pipe bending equipment though that would be the way to do it.:D Tim
/ FEL Front Edge Float Pipe ... thingie.. #14
Just a thought. It may also be useful for back filling trenches with the FEL. So you wont tear up a lawn.
/ FEL Front Edge Float Pipe ... thingie.. #15
Same idea has been around for a while using pvc, usually less expensive and perhaps less scrapes to the asphalt. Works well for clearing snow from gravel drives without digging. There is a thread close about clearing snow from gravel and perhaps photos of pvc thingie.
/ FEL Front Edge Float Pipe ... thingie.. #16
I'd call it "The Driveway Saver":)
/ FEL Front Edge Float Pipe ... thingie.. #17
Hey Phil,
That's a great idea, i think i will do the same thing. Let us know how it works
/ FEL Front Edge Float Pipe ... thingie.. #18
Great Idea
/ FEL Front Edge Float Pipe ... thingie.. #19
Nice design Tim. That gives me an idea of what to do with my toothbar mounting holes during the winter months when the toothbar is off.
Dang, I keep finding new things to make faster than I can get them built. :rolleyes:
/ FEL Front Edge Float Pipe ... thingie.. #20
Hey Matt,
I goto C&M Metal. They have new stuff in the building, but if you go into the yard (just north of the large building) and wander around.. it's like a toystore in that yard! When I was there it was 40 cents a pound for steel $20.00 minimum.
Link: C & M Iron & Metal CO - Recyclables - Englewood, CO- Home C & M Iron & Metal CO - Recyclables - Englewood, CO-
Phill
Phil:
Thanks for the tip on C & M. That's a long ways from me; but relatively convenient for you. However the next time I'm down in that area, I'll have to stop in and take a look. Based on C & M's web site picture, the place looks similar to K & K Surplus where I get most of my stuff as they are closest to me. K & K Surplus - Home Page I've also started buying some stuff from Altitude Steel when I can't find what I need at K & K. www.altitudesteel.com If you want aluminum, then ALRECO is a place to check out. ALRECO Aluminum Surplus & Supply ALRECO's web site is worthless; but if you want aluminum, they probably have it. I think ALRECO is cash or check only. I don't do much with aluminum; but when I do need some, I go there first and it's close to home.
BRANDT 5000EX GRAIN VAC (A63290)
BRANDT 5000EX...
KING 7 SHANK CHISEL PLOW (A63290)
KING 7 SHANK...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
6500 GAL PLASTIC STORAGE TANK (A63745)
6500 GAL PLASTIC...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
