Mowing Power washing mower deck
   / Power washing mower deck #1
RMatty
Member
North Windham CT
BX 2350
Can I mess anything up on my 54in fine cut deck by power washing the underside of it?
   / Power washing mower deck #2
Can I mess anything up on my IN fine cut deck by power washing the underside of it?
Just the driveway where you wash it.
I power wash mine regularly and have not had any concerns.
   / Power washing mower deck #3
I done it with mine- just remember to use gentle tip as you don't want to strip the paint. Every so many years, you gonna want to repaint the deck anyways.
   / Power washing mower deck #4
Have power washed mine, no problems...A friend years ago drilled/installed a garden hose connector to the top of his mowing deck...He'd hook up a garden hose then run the blades while the water was on...Kept the mowing deck very clean.
Don
How many pumps of grease do you usually put in each spindle?
   / Power washing mower deck #7
Good question. I always put 3, but for no really good reason; just seemed like a good number.:D In other words, I don't really know how much you should use.:D
   / Power washing mower deck #8
Good question and this has been talked about a few time here on TBN. The spindles are notoriously low on grease from the factory/dealer when delivered.
What I would suggest anyone to do to make sure there is enough grease in each spindle is to set your deck up on its side so you have access to the top and bottom at the same time. Larry's Mower Axle's are great to accomplish this Mower Deck Axles,Carrera,Cayman,John Deere,Kubota. Take the blades and protective cups off the mower. Pump grease in each spindle until you see some come out the bottom side. This may take many pumps of your grease gun to get them full the first time. From then on, each time you grease your deck, the excess grease from the spindle will be inside the protective cup and not hurt anything.
   / Power washing mower deck #9
I wash mine all the time with no problems. I don't have much choice since I have a attached garage and it stinks real bad if you don't. I wish I could Teflon coat the underneath of the deck for easy cleaning.
   / Power washing mower deck #10
I power wash mine also. There are a couple spots where paint peeled off, but I keep them touched up. I wish there was an easier way to clean these decks. It's not easy even with the pressure washer and I do it two to three times a season.
2016 INTERNATIONAL LF687 SLEEPER (A57880)
2016 INTERNATIONAL...
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
2019 GALYEAN...
2010 FORD F-150 (A58214)
2010 FORD F-150...
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
