5525 or 5093E, that is the question
   / 5525 or 5093E, that is the question #11
I wasn't trying to sound negative, just throwing in a different view. No doubt the 5525 is a good tractor. Good luck with your decision!
   / 5525 or 5093E, that is the question #12
I think the fully loaded deluxe model is the way to go. I think this is less costly than trading again in the next few years to get what you really wanted to start with. I would love to have a new 6430 loaded (or its replacement).
Cost and or justification though throws that out the window, I don't need anything larger than what I have now to fix small congested properties.
   / 5525 or 5093E, that is the question #13
I'd get a bunch of them together and listen to the noise level of the engine before making a commitment from sitting on the seat. Some new tractors should come standard with ear protectors!
You might find the 4040 is relatively quiet!
   / 5525 or 5093E, that is the question #14
They are quiet inside. I like the new 5M series but they are pretty expensive.
6115D looks like a good value - especially for haying.
D.
   / 5525 or 5093E, that is the question #15
You won't be haying long with a JD24T or JD410. Both are nice machines, but not for high volume work. I might be inclined to upgrade balers before I upgraded tractors. A lot less capital up front and you won't be fighting baler problems (I remember those days). I would keep both the 24T and 410 as back-ups, because break-downs do happen. Keep in mind that a 4040 with 3500 hours is just getting broken in, unless it has not been well maintained. If you said 10,000 hours, then you are begging for trouble.
I love my JD5420 especially for haying. I wouldn't go any bigger for my baling tractor. The only reason I would want a bigger tractor is for running a larger mower conditioner, but in my smaller odd-shaped fields, I do not pick up a lot of efficiency going much bigger.
To answer your actual question, both tractors will do you fine.
   / 5525 or 5093E, that is the question #16
This is a good point! A New holland baler with the belt kicker could more then double your baling speed.
   / 5525 or 5093E, that is the question #17
6420s rock - I could not swing the extra $$$.
D.
Yes I agree 6420s rock. Mine has mudder tires and 16/16 power quad and its nice! Just not as clean on the inside has a weird dirt smell but its good to drive with the windows open in the cab!
   / 5525 or 5093E, that is the question #18
I have a 5420 my self, w/ 541 Nsl loader mfwd and a cab with the 9/3 transmission good to ride in. My 5420 is so old that the cab door hydraulics the doors can close by the wind!
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
Forklift (A59228)
Forklift (A59228)
Pedestal Filing Cabinets (A56860)
Pedestal Filing...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
43055 (A55851)
43055 (A55851)
2025 Mustang MP4800 2in Submersible Pump (A56860)
2025 Mustang...
