Vertical Exhaust on a 4520..??
   / Vertical Exhaust on a 4520..?? #21
It may have also been to keep fumes out of the cab, so they didn't get sucked into the cab intake.
Could be, although the cab intake is located at the rear. In any case IMHO horizontal exhaust on 3 and 4 series tractors is just not a good idea and JD should have designed these with a fixed vertical pipe like the 5000 series. Running the pipe through the hood is a little awkward, although not really a big deal. It looks great though.
   / Vertical Exhaust on a 4520..?? #22
Yeah, but the problem is that hot air rises, and with the horizontal exhaust outlet the exhaust fumes aren't able to clear the cab before it's sucked into the air intake on the back of the cab, thus getting in the cab.
I agree, the horizontal exhaust on any of the 3 or 4 series tractors is extremely stupid.
   / Vertical Exhaust on a 4520..?? #23
The vertical exhaust on the JD CUTs, does not increase the exhaust smell in the cab. I can see why some suggest the possibiltity, but it is not an issue. Guess where most ag tractors have their exhaust? It is right at the A pillar of the cab and no exhaust smell in the cab and lots more exhaust comming out of the stack.
   / Vertical Exhaust on a 4520..?? #24
Of course it wouldn't, the vertical exhaust will vent it up and over the cab.
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
2019 TAKEUCHI TL8 SKID STEER (A52705)
2019 TAKEUCHI TL8...
2005 Ford F-350 4x4 Dually Truck, VIN # 1FTWW33P35EC55643 (A54865)
2005 Ford F-350...
10 FT Poly Bunk Feeder (A55218)
10 FT Poly Bunk...
UNUSED IRANCH 15" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 15"...
