deepNdirt
It sounds like the brush hog has two blades held from the end on a single shaft, so that it has some give when it hits something hard. Is this correct?
Yes in all technicality it does actually have 2 blades, but for the sake of telling them apart I simply stated 1-blade with 1-wheel to help with remembering the differences, but unlike the finishing mower blades the bush cutter blades have only 1-sharpen edge on each of the 2 blades, while the other end does in fact bolt the a steel T shape shaft from the gearbox, the stump jumper is a good thing to have when cutting thru unknown grounds
that may have stumps or bolders ect, I do a lot of woods thining of undergrowth and run over things I cannot see all the time, although the last thing I ran over ( small lawn mower engine) hidden in vines damage the stump jumper and took out a big chunk from it causing it to spinn badly out of ballance, so I removed the jumper disc and soon after sold the cutter and the tractor I use with it,.............. I think I am going to try and find a sickle mower and start cutting down the tall stuff and the run back over it with the Bush cutter,
