Mowers, finish or brush - What's the difference?
/ Mowers, finish or brush - What's the difference? #11
It sounds like the brush hog has two blades held from the end on a single shaft, so that it has some give when it hits something hard. Is this correct?
Yes in all technicality it does actually have 2 blades, but for the sake of telling them apart I simply stated 1-blade with 1-wheel to help with remembering the differences, but unlike the finishing mower blades the bush cutter blades have only 1-sharpen edge on each of the 2 blades, while the other end does in fact bolt the a steel T shape shaft from the gearbox, the stump jumper is a good thing to have when cutting thru unknown grounds
that may have stumps or bolders ect, I do a lot of woods thining of undergrowth and run over things I cannot see all the time, although the last thing I ran over ( small lawn mower engine) hidden in vines damage the stump jumper and took out a big chunk from it causing it to spinn badly out of ballance, so I removed the jumper disc and soon after sold the cutter and the tractor I use with it,.............. I think I am going to try and find a sickle mower and start cutting down the tall stuff and the run back over it with the Bush cutter,;)
I have an area (100 ft x 100 ft) which is damp until late July or August each year. The grass here gets 5-6 ft tall. When I had a ridding lawn mower years ago (before all the hidden obsticles distroyed it) the grass would wrap around the mower head. Does a brush hog have any problems with this?
I expect to buy a second mower next summer. It definately won't be a finish mower. The question becomes what type to buy, tow behind flail; sickle; or brush hog. One area I'll be mowing (100 ft x 1400 ft) along my front fence line was cleared by the power company as part of the requirement for the 10 ft easement I sold them and is filled with stunps from 4" to 15" diameter and about 4-6 " tall.
I'm slowly getting all the woody debris removed from the area and eventually plan to remove the stumps so that I can seed and hay it. The rest of that front seven acres still has trees, but the brush has been eaten away by my livestock and grass is replacing the brush which used to be under the trees. The biggest problem in this area currently, is all the alder sapplings trying to come up.
/ Mowers, finish or brush - What's the difference? #13
Another thing that may help you decide is price. I have never owned a flail mower, but I seem to recall that they are very pricey compared to a rough cut mower. I would also think that there would be more maintenance required on a flail mower. An awful lot of flails to sharpen compared to two mower blades. But maybe someone who owns one can chime in and set me straight.
/ Mowers, finish or brush - What's the difference? #14
Certainly not a professional with rough cut, finish or flail mower but have all three and use each yearly. For finish lawn not that thrilled with flail as all I have seen have rollers they ride on and for turning sharply causes the front end to want to slide of the tractor. Also if you have the "Y" cutters lawn really looks odd. For rough cutter really like the flail but the two I have used they are slower cutters than the rough cut or what many call Bush Hog cutters. They don't "cut" the wood, they gnaw through it or take little bits probably about like beavers or large chain saw teeth. That is also why they don't throw large debris as a rough cut mower will. They are smaller and are great on booms compared to the rough cut rotary mower and that is where I have really used them and there to me can not be beat.
One fact on them is especially on boom mowers they often will rotate either direction. Of course if doing so must have hammers or cutters that cut both directions. Normally if you are cutting like grass the cutter is rotating against the direction of travel so it throws the grass up and over where as if cutting larger stuff such as limbs or trees the rotation is normally the same as direction of travel so as not to have chunks come up and jam the cutter. You can cut larger tree or limb with flail mower if you are where you can allow it to slowly chew on it. But oak limbs for me they don't cut, just debark. Cutting the same size trees or such the flail mower leaves a much neater trash trail than a rotary cutter.
/ Mowers, finish or brush - What's the difference? #15
Also, off subject, how do you add the text at the bottom where everyone puts their tractor and attachments?
It is in your personal profile. The signature section is where this is located. It will add that information (signature) to every question or answer you send.
/ Mowers, finish or brush - What's the difference? #17
Regarding flail vs finish and bush hog I'd just add to what kthompson wrote that the flail kinda fits in the middle of the other two and overlaps both. It doesn't give (with rough cut blades anyway) as good a cut as a finish mower but it is a lot tougher and can be used as a bush hog. The differences with the bush hog are that the cut is much better and you don't risk shooting projectiles out from underneath but the trade off is higher maintenance costs (replacing flail knives or hammers every couple of years costs about $150) while most bush hogs seem to go at least a decade with the same blades (which are cheaper if you can get them off).
I'd advocate for flail if you want to get away with just one mower and are not simply maintaining an established lawn. Finish for lawn work. Bush hog for low maintenance farm/field and clearing.
If you have a big enough tractor, there is a hybrid which can do both jobs:
Woods Equipment Company - RM990 series 90?
Looks like it might work... I have a 68HP tractor with 50HP at the PTO. It shows Cat 1 for the hitch witch isn't a problem since I can bush down to that from my Cat 2, but what is it talking about when it says "Driveline: Cat 3"?
/ Mowers, finish or brush - What's the difference? #20
I believe that you have to separately purchase the driveline shaft which goes between the PTO and the power input. I think it means that the shaft is a higher and beefier category. Sorry that I do not know for sure.
I can say that Woods lists it as a rear finish mower. Nevertheless, it has 3 spindle "stump jumper" pans with heavy free pivoting blades like those on a rough cutter, a.k.a. brush cutter, brush hog, rotary cutter. If you search for "RM990" here on TBN, you can read first hand reports from those who own this unit. Most of those owners seem to believe you get the power to cut rough material with the cut quality being that of a finish mower.
By the way, there are some inaccuracies above regarding flail mowers. Flail mowers are available in light, medium and heavy duty models. Light duty use knives to cut grass; heavy duty use hammers to break rough material; medium is in between. Regardless of lawn or overgrown highway median, flails are for use in a location where you cannot afford to launch a projectile which might hit someone. A light flail is used in a park or on a golf course for a fine cut, and won't launch projectiles like a regular mower. A heavy flail is used on a highway shoulder instead of a brush hog so you don't send a 10# rock through a windshield. All flails are designed for safety in close proximity to bystanders. They are more expensive and there is high maintenance on the numerous parts. Unless you will cut in an area where bystander safety is a concern, there is no reason to buy or have one.
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
John Deere 6195R (A60462)
John Deere 6195R...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
Mini Margaritaville Truck (A55853)
Mini...
1605 (A57192)
1605 (A57192)
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
