CG placement
/ CG placement #1
nap61
There have been many threads about counter weight/weight boxes. I am planning on making a concrete and barrel type. The questions I have not seen answered is where to place the center of gravity.
1. Do you place cg above the pins? If so, how low to go?
2. Do you place cg below the pins? If so, does that eliminate the need for a top link?
/ CG placement #2
What size barrel do you have? If the CG is above the pins then you do need a top link. If the CG is below then maybe you don't need the TL but the ballast might tend to sway or rock.
You might want to look at some existing ballast boxes, lots to search for here and many good ideas. Some include a carry box / tubes for tools.
/ CG placement
mwb,
Thanks for the reply. I don't have a barrel yet but I do have a 35/40 gal square trash can I might use. I noticed the improvements that were made on some "boxes" such as the chain holders, tool carriers, etc., and I will probably incorporate some of those ideas.
Norm
/ CG placement #4
mwb,
Norm
5 gallons of concrete weighs 80 lbs, so 35 gallons would be 560 lbs. Should be plenty of counter weight. I recommend a top link just to keep things from swaying too much, even if center of gravity is below the bottom links.
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A64556)
2020 Mack Anthem...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
HARDEE 300 GALLON SPRAYER (A64278)
HARDEE 300 GALLON...
2017 Volkswagon CC Sport Sedan (A64557)
2017 Volkswagon CC...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
LONG 10 WHEEL V-RAKE (A64278)
LONG 10 WHEEL...
