Repower
/ Repower #12
/ Repower #13
I didn't have a particular repower in mind just wanted to read about what people had tried ,yours look interesting ,my previous posts list the projects I have attempted.
What do you mean by "attempted", was there a degree of success at the end of some or all of the projects?
I have idly considered replacing the smokey IH D239 engine from the IH 75 Hydro of my Chisholm Ryder grape harvester.
Apart from the obvious changes to the front of engine mount (easy enough) I've no idea how one would go about mating the new (different) bell housing to the old transmission or even harder - making the transmission and pto splines compatible, not much room for adaptors there.
Do you have any pics of your repowers?
/ Repower
The 1086 was 100% successfull but that was staying in the same series engine just changed timing cover to accept a different engine mount I enjoy the extra 20hp or so on my pto combine.The Versatile 700 was 99.9% I have a bit of heating issue in hot weather can't say it is overloading I pull the same load as I had on my 1086.I had to buy a flywheel from a wrecker for a 3208 in Steiger and a fan mount from a MF1800 I modified the front mount from the 4166 engine I had a local mechanic fabricate a hydaulic pump mount with double belt drive and dual exhausts .The pump drives off the crankshaft with a double pulley .Only thing is I haven't located a tacometer cable long enough to reach from the front of the cat to the instrument panel.
Only pictures are on my phone don't know how to get them here.
/ Repower
Allenr ,Go to Redpower Magazine .com there are some very informed IHC people and good reading there I'm sure you could get some insight to your job there ,my guess is you could make a swap it is wheather it is justifiable, I considered doing a 1206 IHC to a 414 but couldn't see putting that much money in a 12000 hr tractor that was virtually wore out in all areas.
/ Repower #17
Thank you Whatswrong.
Just had a look at the redpower site, looks interesting!
/ Repower #18
I'd love to put a Cummins 4BT into my jeep....also like to put a HPCR Cummins into an early Ramcharger....or even a small...say 30HP Yanmar/Kubota into...maybe......an early Austin Healy Sprite, or one of those little brit convertibles....course I'd have to rewire everything and get rid of all the Lucas elect parts...specially the headlight switch that reads "on" "off" and "flicker"...
hehehehehehehe:D
/ Repower #19
How about going from a 12 HP Kohler single to a 35 HP B&S Vanguard Twin in a garden tractor? Required a new adapter, hitch, wiring, and tranny, but it worked. The adapter had to be made from scratch.
/ Repower #20
hehehehehehehe:D
Is Lucas elestrical gear as highly regarded over there as here in Australia?
Don't suppose I've come across any of their stuff for quite a while - have they suffered the fate they deserved?
2021 Deere 550K LGP (A60462)
2021 Deere 550K...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
Iranch IRGC40 High End Mini Golf Cart (A60463)
Iranch IRGC40 High...
40' High Cube Shipping Container (A60463)
40' High Cube...
2019 GALLEGOS TRAILER PNEUMATIC TRAILER (A60736)
2019 GALLEGOS...
Bush Hog RDTH84 (A60462)
Bush Hog RDTH84...
