loader curl
/ loader curl #1
capt jack
North Texas
kubota M105,B21,Cat D6B
My DK55 tractor/loader is stopping short of full "curl back" on the loader with a large round bale of hay (about 1200-1300lbs). The loader will lift it up with ease, just won't roll all the way back. with a small load it is fine, fluid level is fine, Any ideas where to start?
Thanks, Jack
/ loader curl #2
Do you think you have reached the limit of what it will curl back?
Or is this something that just started, where some time before it would curl with ease?
/ loader curl #3
same question as beenthere.
My loader will keep lifting something on the pallet forks but not rollback due to leverage of load out front, the higher I lift it the easier it is to curl. Just need to be super carefull you don't curl it onto yourself if lifted high.
Joel
/ loader curl #4
Thanks, Jack
If you are in the full curl position, th relief valve should be relieving. If your pump is not providing the force as in pressure, you may be at your limit. Your pump could be weak, not building the pressure as when new. Valve could be bypassing. When my pump was on it's way out, it would only lift about half the rated load.
If your valve is not relieving, then you are not using full pressure.
Check out the pressure with a hyd pressure gage.
GHT Series Hopper Tank 75T Grain Bin (A65579)
GHT Series Hopper...
2012 WESTERN STAR  4900 SF (INOPERABLE) (A65643)
2012 WESTERN STAR...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
Schuler 125B Feed Wagon (A66408)
Schuler 125B Feed...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2006 JCB 506C HIGH LIFT TELEHANDLER (A62613)
2006 JCB 506C HIGH...
