Bucket Hooks FEL Hooks
/ FEL Hooks #1
Bob Ha
DFW, TX
NH TN75, Kubota M9960, Kubota M7040, NH T4.85
I have my tractor at the dealer and thinking about having hooks welded on the bucket. They said it would be $15 for the hooks and welding.... should I do it since the cost is $15? Anyone have hooks welded on and what do you use them for?
/ FEL Hooks #2
Yes!! for $15.00 it's well worth it...as for uses.. use your imagination, or read all the uses people have posted here.. do a search on "chain hooks", or "bucket hooks"... read and learn
/ FEL Hooks #3
Yes, I would have it done. And you said hooks. As in more then one? If you can get two hooks welded on for $15, then I'd say go for it.
I cannot list all the uses. They will come naturally for you. Pulling posts, loading equipment on trailers, pulling roots, stumps, dragging limbs, etc. They are very handy to have.
/ FEL Hooks #4
Just be sure to tell them where you want them and which direction. Double hooks would good. Two hooks on each side facing different directions. That is so you can hang the chain off the back or the front of the bucket. Some people beef up the area where the hooks are mounted. Some put hooks in the center. There are some nice fixed up buckets on TBN.
http://www.tractorbynet.com/forums/customization/149200-bucket-hooks-d-ring.html
/ FEL Hooks #5
As well as hooks, a hole drilled in the lip of the bucket for a clevis or a ball mount is also very handy those certain times when needed.
It is deer season, and the hooks and/or clevis come in real handy. :)
/ FEL Hooks #6
$15..thats dirt cheap..couple good hooks cost about that.
/ FEL Hooks #7
Here are the hooks on the bucket of my Mahindra 5525.
My dealer welded them on the bucket when I bought the tractor new (I supplied the hooks). Notice that the hooks are welded to a 1/4" thick steel stiffener that in turn is welded to the bucket. Don't forget this stiffener.
/ FEL Hooks #8
Bob, get the hooks, I would get more that two though.
/ FEL Hooks #9
I'm not sure I would want hooks.
I've got two BIG D-rings mounted on my bucket and I think they serve better than hooks.
I can run a chain thru them and easily pull to tighten, versus unhook and rehook.
Plus I'm thinking of running a pipe thru them and hanging off some pallet forks.
/ FEL Hooks #10
I 'm following this thread gettin' ready to get hooks. I don 't weld and plan on having hooks welded on re-enforcing plate by a pro to bolt to loader. Question : how hard is it to drill holes through the metal on the loader ? I have pretty good drills and bits.
/ FEL Hooks #11
Very easy to do what you want.
/ FEL Hooks #12
Hooks are pretty versatile. I added clevis mounts to mine as well!
/ FEL Hooks #13
I have the heavy duty bucket and 400x loader on my JD 4120. There are 1/2" holes across the cutting edge for installation of a tooth bar, etc. I keep a couple 3/8 chain hooks in the toolbox, and a few 1/2" bolts. When I need hooks, I just bolt them into these holes. Having them on the lower edge is nice because it gives you more lift from the tilt function than you would get from hooks on the top of the bucket. That bucket is really strong. I also drilled a couple more holes further back on the bottom of the bucket in line with the lift arms, and bolt a couple pieces of heavy angle to the bottom for use as forks for lifting logs, etc. I dont think the standard bucket would work so well with these tricks however.
/ FEL Hooks #14
3/8" grab hooks are handy to have, but put them on the sides, save the middle for your receiver tube, you can just weld one on as well.
I bolted mine as I wasn't sure it was a good idea since mine was one of the earlier top center installs (that I had seen at the time). Now everyone has caught on for obvious reasons, it's versatility is limited only by your imagination.
http://www.tractorbynet.com/forums/...g/93535-bucket-buddy-instead-weld-hooks.html?
You can read about my reasoning for the receiver tube here.
JB.
/ FEL Hooks #15
I paid $5 each for my hooks so that is a deal. If I were you I would also pick up a step bumper hitch at HF or any auto parts store for $20 and have them add it also.
I put 3 hooks on each of my buckets. The pic is a old one when I had only 1 hook but soon realized I wanted more. I put 1 in the center on top of the hitch and 1 on each corner.
Chris
/ FEL Hooks
When I asked my NH dealer about this I was expecting $75 or $100 but like I've said several times in these threads... "I feel lucky to have found a dealer than aims to please" and I am pleased. :D This dealer is not looking to make every penny they can on every little job so I don't feel nickel and dimed to death. Thanks for all the info and pictures... TBN is great!
/ FEL Hooks #17
It is not hard if you have a strong drill and good bits. I drilled 4 holes to mount the plate for my PHD. I did not use my cordless, I prefer corded for that type of operation.
That said, I had my hooks welded on, I trust the welds. My hooks were welded to a plate which was then welded to the bucket (hopefully strengthening it) I paid about $100 at a local welder including the plate. I provided the hooks from AWDirect: Weld-On Grab Hook - Grade 70 - 1/2" - Mfg# 11-12WGH.
Do a search here. There are lots of good posts on bucket hooks including the one that I unashamedly copied.
/ FEL Hooks #18
JB.
Nice setup JB!
I made a pair of movable hook brackets that slide anywhere along the bucket. No
welding or drilling into the bucket. (not that it hurts anything)
2020 Ford F-53 Thor A.C.E 32.3 33.5ft Class A Mobile Home (A66738)
2020 Ford F-53...
2013 WINSTON AP22024-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2017 TAKEUCHI TL8 SKID STEER (A65056)
2017 TAKEUCHI TL8...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
MI-T-M HDS-3005-Z004 PORTABLE PRESSURE WASHER (A65054)
MI-T-M...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
