Worklight Wiring
/ Worklight Wiring #1
dfeck
Gold Member
Western, NY
Kubota B3200
I want to add a rear worklight to my CT230. I see there's 2 wire terminals that are just above the area where the rear hydro lines go. Is this to plug in a rear light? There are exposed terminals that look like bullet connectors.
Doug
/ Worklight Wiring #2
I'm planning to add lights to my tractor soon. I checked those leads and they have power when the key turned on. I have all the supplies except for a rocker switch. I plan on putting the switch into the grommet/cover next to the head light switch. I'll post some pictures when its done.
/ Worklight Wiring #3
Does anyone have a WIRING DIAGRAM for the CT230?
I'm sure BOBCAT (and KIOTI) pre-wire a lot of accessories - in case the customer wished to add on any.
Which brings up the other question: just WHAT electrical accessories are available for the CT230? I cannot find anything in the website or product literature.
Thanks in advance!:)
/ Worklight Wiring #4
that is exactly what those wire are for. the factory work light ($19) plugs in there.
/ Worklight Wiring #5
Does anybody have a picture of the factory work light? How is it switched?
/ Worklight Wiring #6
I not sue on the Bobcat light but the Kioti light is a round black light with a switch built in.
That is why there is power to the wire already.
Now again not sure on the BC but the Kioti has a aux fuse in the fuse panel down to the right of the steering wheel by the brake pedals under the dash.
There's not really any electric accesories out there.
/ Worklight Wiring #7
The bobcat light is the same light. Do a search in here on the worklight installation someone posted some pictures of a CT120 Kioti equivalent. The light is the same, different brackets for CT12x versus CT2xx. CT2xx has no bracket, bolts into the body hole to the right of the tool box. Both are 19 bucks from BC dealer.
Dfeck, werent you about the first person in here to get a CT and one with the biggest discount, and you're just now getting around to a light? Thats funny.
/ Worklight Wiring #8
I got the rear work light as an option when I bought the tractor. (CT225, early June) It was on all the time, not just on with the lights. The dealer swore that was the way the factory wiring said to install it, but they did install a toggle switch right next to it for free when I complained. I asked if nobody else complained about it, they said I was the the first one to buy the work light option.
/ Worklight Wiring #9
Does anyone know what size fuse is on that circuit? I wanted to run three lights with it (rear work light and two on the ROPS)
/ Worklight Wiring
That's me!! I haven't had time to do much playing with the tractor due to my heavy work schedule. I think I have a whopping 20hrs on the meter since may. Now that's it's fall I finally have time to plan some tractor mods. Light, bucket hooks, etc. I was able to pick-up a used 3pt brush cutter, 100gal PVC water tank, rear blade for snowplowing, weight box over the summer but that's about all. I'll need a light soon for night snow plowing.
Wallace - Can I purchase the light from you? Let me know the cost w/shipping to zip 14472. I can make payment through PayPal or call in a CC.
Doug
/ Worklight Wiring #11
Doug, Just give Wallace's place a call. 570-689-7494 They'll be happy to take your cc number over the phone and ship out the part. I get my parts from him that way for my Kioti. If it's in stock, and he seems to always have what I need, you should have it in a few days. I'm in NW Pennsylvania.
Have fun snowplowing. By this time last year, I already had seat time and the rear light does make it nicer. Just a thought, but some of the Kioti guys have mounted their lights on the ROPS. Some face forward for extra light when the fel blocks the headlights and other lights to face the rear. If you check the Kioti forum, you should find some posts with pictures of their designs.
/ Worklight Wiring #12
Okay guys I am going to post this up here...
Someone emailed me today and I forwarded to my parts counter on prices and I'm sure my parts people gave you the expensive kit..
Just so there is no discreptinces...
There is a work light that mounts right above the SMV sign and then there is a work light kit that allows you to mount the work light using 2 bolts from the roll bar fender bracket.
Don't ask me why but that's what Kioti offers it.
Just the work light is around 30 bucks.
The work light kit is around 55 bucks.
/ Worklight Wiring #13
Wow that's pricey compared to the 19 bucks I spent at my dealer. I posted their phone number in T600's thread.
/ Worklight Wiring #14
I agree, when did you buy yours?
Kioti was priced like that last year.
/ Worklight Wiring #15
At my dealer about 2 weeks ago.
The other guy that posted the pictures of installation on the old worklight thread in this BC section, got his from Michigan Steel I think? I assumed it was a Kioti product? He had a Kioti (CT120 equivalent). They quoted me about the same, 20 bucks.
http://www.tractorbynet.com/forums/bobcat-tractors/148726-work-light-ct230.html#post1715137
You guys might already be aware of this, but the Kioti factory rear work light with the bracket (actually two, depending on how you want to mount it to the ROPS) is ~$20 from Michigan Iron & Equipment. Works quite well and includes a switch mounted to the light, and proper pigtail to match the factory wiring of course. I'll try to remember to snap a picture.
I don't have the P/N but Bob @ Michigan Iron can get you setup 517-625-4590, just tell him which model equivalent Kioti tractor you have.
I finally snapped a couple of pictures, see attached. Couldn't get a picture of the wiring because the tractor was backed up to the wall and I was running late for work!
Josh
/ Worklight Wiring #16
Rick is right, they were priced like that last year. Unfortunately, they aren't priced like that any more. There was a pretty significant price increase on the KIOTI CK20 work lights this year.
The pigtail on the CK20 worklight may need to be modified if you use it on other models. The worklight harmess ends vary from model to model on the tractors.
/ Worklight Wiring #17
Well ain't that a kick in the pants.
/ Worklight Wiring #18
I have been waiting to post a reply to this topic because I wanted pics of my setup but when I went to take pics my flash wouldn't work. I will try again tommorrow.
I recently did the work light addition to my ct235 and can add a little advice here.
1. The factory light location which is right next to the tool box is too low for a light to be mounted if you want your light to shine on a tiller or snowblower. I tested mine in that location with both attachments and it is just too low and is blocked by too much of the implement. I higher light mounting location like on the roll bar is very beneficial because it gets that light shining down from above the implement a lot better.
2. The rear work light wiring is tied onto the same circuit as the rear tail lights. That is a 10 amp circuit. That means that if we use our old forumla of amps=watts/volts then if our tail lights are running about 20 watts each (which I don't know but it should be close) then a third or so of our available amperage is taken by tail lights. So to be on the safe side I would say to stick with a 65 watt (maybe 75 watt max) work light on the rear. I could figure out exactly what wattage we can run on the rear but haven't taken the time. Either way, only one light can be attached to that rear circuit if you run a halogen fixture. LED or HID are a different discussion.
3. The rear work light wiring is powered on whenever the key is on. In my opinion you need a separate switch on this circuit because there is really no point in running that light unless you need it.
4. For the front work lights I installed a relay to a switch in the dash. The switch is located in the recess by the key. I ran a fuse holder and a positive and negative off of the battery to power the lights. The fuse panel has a spare circuit worked into it. You need to remove the fuse panel, then carefully remove the fuse holder connectors from the back of the fuse panel. The top three all need to come out as one unit since they are one piece jumpered together to a keyed source. You can power your switch off of this spare circuit. Just solder your wire onto this spare spot once you get it out of the circuit block, then run to the switch, then to the relay. This way your front work lights are able to handle whatever wattage you want, and your fuse panel won't burn out because of over amperage.
I will take some pics of my front work light brackets that are bolted onto the loader frame and of my rear work light bracket. I blew snow tonight in pitch black darkness and it is literally a night and day difference. I have absolutely 0 lack of light to blow snow or do loader work at night. If anybody has any further questions about this feel free to email me or whatever. I would be happy to help talk you through your work light project.
I hope to get pics up tommorrow night.
-Justin
/ Worklight Wiring #19
-Justin
Sounds like good work!
/ Worklight Wiring #20
I had the bobcat rear utility light installed on my tractor when I ordered it. It does have a switch build into the light and only works when the key is on. As far as I can tell, its a good quality light and only cost 45 installed, which means its probably only 20-25 bucks for the light.
I would say, if you want a light that has a switch already built into it, you should consider getting the bobcat light. Seems to be better quality than the local TSC store.
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
2006 International 4300 Altec LRV58 58ft Forestry Chipper Bucket Truck (A61568)
2006 International...
