what size quick connect?
/ what size quick connect? #1
gjock
Member
watertown, New York
Kubota B2920
I am trying to find a female quick connect coupler for my kubota bx2660. The ones that are on my loader have the following #'s IT BF 15-04 1/4" NPTF k08
I cant find a cross reference for it and i'm not sure what the numbers mean, any help would be great.
/ what size quick connect? #2
Remove the QD and take it with you to the hyd supply for a match. It is a National Pipe Thread Female, and 1/4 in size.
/ what size quick connect? #3
Since this is a quick coupler, and most of them do have female threads, JJ is probably right about being female. Still, I'd like to clear up a misconception that I encounter many, many times in my business.
The F in NPTF does not mean female.
NPTF stands for National Pipe Tapered Fuel. Both NPT and NPTF have the same threads-per-inch, pitch diameters, and taper-per-inch. The differences come in the major and minor diameters, the root and crest of the threads. The NPTF thread crests fall with in the parameters of the NPT requirements, but have a smaller range than the NPT.
ASSEMBLING NPT AND NPTF FITTINGS
NPT threads are designed to screw together. In most cases there will be no interference between the root and crest of the threads at assembly. The thread is designed to be assembled with some form of sealant to assure a leak free joint.
NPTF threads will screw together with NPT threads and should have no noticeable assembly problem. There will most likely be an interference fit between the root and crest on either the major or minor diameter of the thread, depending on which part is NPTF. To accomplish a seal on the joint, a sealant will be required.
NPTF threads are designed to screw together. They are designed to have interference at the roots and crests of the threads on both the major and minor diameters. This interference should cause no assembly problem. The thread deformation caused by the interference fit and the wrench tightening is designed to make a dry mechanical seal.
The requirements for NPT (National Pipe Thread) are spelled out in ANSI B1.20.1
The requirements for NPTF (National Pipe Thread Fuel) are spelled out in ANSI B1.20.3
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
2019 KENWORTH T680 (A65643)
2019 KENWORTH T680...
Kinze KM3000 Monitor (A65640)
Kinze KM3000...
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
2020 Ram 1500 Pickup Truck (A64194)
2020 Ram 1500...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
