88 Ford 2120 Repair
   / 88 Ford 2120 Repair #1
cic317
Looking @ a 88 ford 2120 TLB w/ 1050 hrs. appears to be in good shape but needs front axel seals, wondering if it a major job. Machine would fit my needs perfectly otherwise.
Thanks for any advice
   / 88 Ford 2120 Repair #2
Front axle steering swivel and hub seal replacement is not difficult or time consuming. I change them regularly in the field using common hand tools and a properly sized seal driver. Sometimes axle bearing replacement is required as well, but that isn't difficult either. Raise the front axle and see if their is excessive play in the axle bearings. If the axle/wheel wobbles much at all, bearings and prehaps more will be required.
Thanks for the reply Rick, You mentioned if it also bearings & possibly more..
What else would you be considering if it turns in more, because it usually does
Thanks
   / 88 Ford 2120 Repair #4
Catastrophic outer bearing failure can be accompanied by outer hub cover breakage. Inner axle bearing failure can take out the lower swivel housing. Running for long periods with either axle bearing out can damage the lower bevel gear pair. None of this is especially common. Mainly happens due to an unresolved leaking seal. If the axle shaft isn't loose in the housing, it's probably just a seal.
   / 88 Ford 2120 Repair #5
Thanks
see.. I toldya rick would fix ya up!
soundguy
Thanks, I'll be taking another look next week & hopefully it just seals. I'll post back w/ an update.
Seems to be a all around great tractor for it's size, & from what I've read they have a loyal following, surprised they were only out for a few years.
   / 88 Ford 2120 Repair #7
They were in production for over a decade.
Morooka MST 660VD Tracked Dump Truck (A50397)
Morooka MST 660VD...
2016 21ft Holden Equipment Trailer (A48836)
2016 21ft Holden...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A45679)
2019 INTERNATIONAL...
More info coming soon! (A48081)
More info coming...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A45679)
2015 VOLVO VNL...
2025 Kivel 48in Forks and Frame Tractor Loader Attachment (A49346)
2025 Kivel 48in...
