Hydroback Cable
/ Hydroback Cable #21
Would you tell us how the valve works. and some pictures.
/ Hydroback Cable #22
Thanks JJ, do we know which we use the 10 or 20 pound?
Also anyone able to post pictures of the hydraulic replacement for the Hydroback cable--as used on the new machines?
Thanks
Bill
No, I really don't know which one PT uses. There have light duty Hydrobacks, and Medium duty Hydrobacks, with cable movement of 2 in, and 3 in. You might be able to cheat and add spacers in the unit, which would compress the springs .
/ Hydroback Cable #23
These are the best that i have.
Ken
/ Hydroback Cable #24
On the 400 series PTs with hydroback cables, there are three grease zerks on the treadle linkage and a couple heim joints. They are supposed to be greased regularly. Is everyone doing that? I do it. One of the advantages of doing that is that it forces you to remove the side of the tunnel covers and clean out all the sticks and clippings. It is also a good time to inspect the hoses that are in there.
/ Hydroback Cable #25
I did some searching and had to go back to some posts back in 2003.
Here is our PT425 treadle with hydroback cable. Note the grease zerks and heim joint.
Here is the other side.
There is a total of three zerks and three joints that should be lubed every 8 hours.
Now here is a picture of PJ's valve that replaced the hydroback.
/ Hydroback Cable #26
Thanks. That is the first time I have seen that valve. Logic tells me that the pedal is operating a lever that sends fluid to the transmission to shift the pump swash plate, which will vary the speed of the wheel motors.
/ Hydroback Cable #27
Iinstead of having an external arm on the variable volume pump that is moved by the hydroback cable, the hydraulic fluid from the treadle valve moves some internal mechanism inside the pump.
Here's is a picture of PJ's. The top hose going into the variable volume pump is from the treadle valve.
Here's a pciture from the other side. You can see it in the shadows.
/ Hydroback Cable #28
How come everyones tractor is so clean in the engine compartment? No matter what I do it is full of oil and debris. I think I pull and wash the junk out and it just crawls back in to tick me off...
/ Hydroback Cable #29
David,
Do you know the manufacturer of that pump? I see what looks like the letter P, and I can't see the letter beside the P?
It looks so clean because it probably was pressure washed.
/ Hydroback Cable #30
Hee hee!!! Because we all took pictures of them when they were new because we know what they'd look like in a few weeks of use! :p Those pictures are from 2001 and 2003.
/ Hydroback Cable #31
David,
No I do not know the manufacturer of that pump.
/ Hydroback Cable #32
I grease the grease fittings every 10 hours, but have not been lubing the heim joints. I guess I should start. I leave the covers off. I don't see that they are needed except for appearance. Is that right.
/ Hydroback Cable #34
I removed those covers about five years ago with no problems because of it. I lube the linkage more often because their out in the open. I would also like to come up with a quicker system for removing the floor plates.
/ Hydroback Cable #35
I lubed the cable by sliding back the small black cover on the end near the petal. I then worked the cable in and out and kept spraying. I wiped off black gunk occasionally. On the other end I just sprayed into the hydroback cover. I used a Dupont teflon dry multilube. Does anyone put lube in differently? I probably should have taken the cover off the spring, but did not immediately see a way.
/ Hydroback Cable #36
We had this special clamp for motorcycle cables, Rubbery thingy clamp that compresses around the opening of the cable. There was a small hole for the spray nozzle to fit in and it pushed the graphite right on down. Used it on motorcross bikes.
Doubt I still have it, not sure if it is still made....
AHHHH Here we go
http://store.royalenfieldusa.com/cable-lubrication-tool
/ Hydroback Cable #37
Would that fit on the Hydroback cable. Seems a little small. A good idea though. I will order one if you think it will work. Probably work on the throttle and choke cable.
Edit: I ordered one.
/ Hydroback Cable #38
If I leave the covers off all the grass that blows down the tunnel seems to go up my nose! :D
/ Hydroback Cable #39
Moss, if I could put your nose on my tractor then I would not have to wear a dust mask. Clone it.:D
/ Hydroback Cable #40
I found a company that sells the Hydroback cables locally, and the cost to replace my cable which is 84 in, is about $111.00, and the Hydroback unit is about $65. This was for a Medium Duty, 3 in travel, and 20 lbs. If the cable could be hooked up directly, it would work better. Right now, my foot pedals pull a bracket that pulls or pushes the cable, and the other end also pushes or pulls a bracket that moves the lever on the transmission. Do no not tighten the floating brackets to much, it will add extra lbs to the cable. Just tighten up the bracket and back off about one turn. Those of you that use a pressure washer on the PT, try not to squirt water/soap into the cable assembly.
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
2016 ISUZU NRR 4X2 S/A CAB AND CHASSIS (A67148)
2016 ISUZU NRR 4X2...
1995 FORD F-SERIES S/A GRAIN TRUCK (A64278)
1995 FORD F-SERIES...
2022 EZ-GO ELITE...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
